Question about Miele CVA4070 Coffee Maker
THE TWO DOTS IN THE CLOCK DISPLAY KEEPS FLASHING--CVA4075--THE TIME IS WORKING BUT THE TWO DOTS FLASH CONTINUOUSLY how can I correct this problem?
  • 4 Answers
The flashing dots cannot be turned off they flash on all of Miele's products with similar displays. Do they really bother you?
Posted on Mar 17, 2010
How do you set the minutes on the clock?
There are two ways to set the clock on your coffee maker. 1- When you initially plug in the coffee maker, the unit will beep and "12:00" will flash on the LCD display for a few seconds. Press immediately the h/min button (o) to set the current hour. If "12:00" starts to flash, press the PROG button (n) for a few seconds until the "12:00" flashes again. Then press the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. 2- At any other time, you can set the clock or change the set time by pressing and holding the h/min button (o). The unit will beep and "12:00" will flash on the LCD display. Use the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. Notes: Your clock has now been set and will continue to keep the correct time, even after the coffee maker has been shut off. Unplugging the coffee maker or a power failure will reset the clock to 12:00 AM. Repeat the instructions above to reset the clock
Source : Krupsusa.com
Link to manual : http://product-support.groupeseb.co.uk/Download/Pdf/366/km730
Mar 21, 2016 | Krups KM730D Breakfast Set Coffee Maker...
On hipstreet maestro projection clock should dots be continually flashing?
When you say flashing I assume you are referring to the twin dots : between the Hours and the Minuets. If they flash every second that is normal, regardless of any type of digital clock.
Feb 15, 2015 | Audio Players & Recorders
How do I set the time on Timex T231 clock radio?
Setting The Time of T231
NOTE: The time can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows 'OFF' and then reverts to the time.
1. If the display is flashing, press the HOUR / REV button to advance the display to the correct hour. If the display is not flashing press and hold the CLOCK button until the display begins to flash, then press the HOUR / REV button to advance the display to the correct hour. Observe the PM indicator to confirm that you have set the hour correctly. If the PM indicator is 'On' the hour on the display is PM. If the PM indicator does not appear the hour on the display is AM.
2. Press the MIN / FF button to advance the display to the correct minute.
3. When the correct time is flashing on the display press the CLOCK / PRESET button once more. The display stops flashing and the clock begins to run.
Oct 01, 2014 | Timex Audio Players & Recorders
Sony XDR-C705DAB wont set time
please press all buttons at a time it will reset
Nov 24, 2013 | Sony Dual-Alarm AM/FM Clock Radio with...
How to set the time on a Bedol Squirt clock
The right button in the frame of the clock face is chooses mode; it cycles through alarm, date and time, in that order. The left sets alarm, date or time.
1)To set the time:
Press the right button 6 times until the hour display flashes. (Make sure it is the time and not AL = Alarm)
Press the left button until you have the correct hour (note AM or PM)
Press the right button again until the minute display flashes.
Press left button until you have the correct minute.
Press the right button then the left button; the colon should flash.
The clock is set.
2)To set the alarm time:
Press the right button twice until the hour display flashes. (Make sure AL is displayed in top right hand corner)
3)To turn on the alarm:
Press the right button once
Press the left button once
There should be a symbol which says "AL ON" near the centre top of the time display.
Press the right button 3 times until the colon flashes
The alarm is on.
There is also a way to get a bell symbol displayed at the centre bottom. (I didn't test what it does)
4)To set date:
Press the right button 4 times until the month display flashes.
Press the left button until you have the correct month
Press the right button again until the day display flashes.
Press left button until you have the correct day.
Nov 14, 2013 | Bedol International Group, Inc The Bedol...
Sangean h2o1 clock is flashing. The radio display doesn't flash - only the clock. I've reset the clock, changed the batteries, and generally played with the other settings. Can't figure out why the time...
Here's the thing: When you change the batteries, the radio thinks you need to reset the time, even though the time has been preserved and is correct even after you change the batteries. Here's what you do: Pretend you need to reset the time. With the radio off (recommended), press and hold the "Band" button with the "set" notation underneath it. The hour will flash. "Reset" the hour by using the tuning buttons, as you would if the radio were new, and then change it back to the correct hour. Press the "Band" button again and repeat the process for the flashing minute display. Press "Band" again to end the process. You will have successfully fooled the H201 into thinking that you have reset the time, and the time display will have stopped flashing. (This does not appear to work if you do not actually pretend to change the hour and minute and just keep pressing the "Band" button -- you have to go through the procedure as though you were actually changing the time.)
Aug 31, 2010 | Sangean H201 AM/FM Radio
Model # arg7600ww. Display clock keeps flashing,
The eoc has gone bad. Clock control. You will need the manufacturers number also starts with a P when ordering this part. Hope this helps.
Mar 09, 2010 | Amana Kitchen Ranges
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
OVEN SHUTTING OFF, CLOCK FLASHING
ve continually had the same problem for years. Now the display flashes F1 and beeps continually and I have to keep the unit unplugged. I can use the burners and manually light them but the oven is unavailable because there's no power.
Mar 29, 2009 | Tappan TGF657 Gas Kitchen Range
Miele CVA4070 Coffee Maker Logo
195 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
