Question about Coolmax HD-211-eSATA Hard Drive
Blinking Blue Light
My green light stays solid but the blue light will blink. I use to hear the coolmax spin and whine but now it is a very faint whine and spin but sounds like it stops. What is wrong?
0 characters
1 Points
4big Quadra drive not appearing in disk utility or LaCie desktop manager
Could be defective. Try swapping power cord and usb cable with know good ones. You could also plug it into a different (known working) usb port.
Good Luck
Nov 28, 2013 | LaCie 4TB Biggest Quadra U SATA II Hard...
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
250gb external by coolmax, not showing up on comp
The unit (more precisely the hard disk inside it) just died - nothing you can fix unfortunately.
Jan 07, 2010 | Hard Drives
What are the blinking light error codes for
the interphase between the raw drive and the usb cable is faulty or blown up.
use the raw drive from the casing to power it directly to pc it would start working
Sep 19, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Red and blue light alternately blinking. What can i do.
Remove the drive from the enclosure and either install it in your machine as a slave or you will need to buy a new enclosure and put the drive in it.
Sep 17, 2009 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
Blinking light in unusual pattern and ticking/clicking sound
TH eclikcing sounds like the heads are uffering from STICKTION give the drive a gentle but sharp jolt with the palm of your hane and see what happens
Aug 09, 2009 | SimpleTech (sti-u2f36/250) 250 GB Hard...
Blinking blue light
the only blue light that i know blinks is the Kmart blue light special .. we need model of things you're working with to properly diagnose.
is it external drive ? with a blue light blinking ? is it connected in usb ? sounds like if its external drive with blinking light could be bad hard disk or bad controller card inside that translates ide to usb.
Jul 29, 2008 | Hard Drives
Worked fine for a year, now not recognized or functioning
I had the same issue- light was blinking from red to blue, could not get my computers (I have a Mac and a PC) to recognize the drive, sounded like the drive wasn't powering up...
I replaced the Acom drive enclosure with a new one (CP Technologies). I don't know if the drive enclosure or power supply was at fault-- but it wasn't the internal drive. Plugged it in and amazingly all my data was back. For thirty bucks it was far less than sending out the drive to a 'data recovery' expert!
Jun 09, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Coolmax HD-211-eSATA Hard Drive Logo
32 people viewed this question
Top Coolmax Hard Drives Experts
Brian Sullivan
Brian Sullivan
Are you a Coolmax Hard Drive Expert? Answer questions, earn points and help others
