Question about Comdial Lands Phones
I have nine lines. but i only want the first four to ring. how do i fix that
  • Comdial Master
  • 2,460 Answers
You call your Comdial installer or find the system manual. Lines are programmed to ring per trunk and extension in system programming.
Carl
Posted on Oct 08, 2009
What are the 12 days of christamas in order
12) 12 Drummers Drumming
11) Eleven Pipers Piping
10) Ten Lords a Leaping
9) Nine Ladies Dancing
8) Eight Maids a Milking
7) Seven Swans a Swimming
6) Six Geese a Laying
5) Five Golden Rings
4) Four Calling Birds
3) Three French Hens
2) Two Turtle Doves
1) A partridge in a Pear Tree
Dec 01, 2015 | HP Computers & Internet
Phone line doesn't ring
First, lets get rid of the static. Try Feature #86. This will turn off background music. When a music source is not attached you get static.
Enter programming by using Feature XXX66344 password 266344. The display should show "Terminals&Sets" press the top right button with an indicator in the display. The display should show "Show set: ____ enter the extension number that you want to check or program. The display will show ***:name. Press the top right button three times. The display will show Show Line:____ with options to Scan or List. If you select Scan it will show the lines assigned to that phone. If you select List it will start with the first line in your phone system showing one of four states 1- Unassigned, 2- Ring Only, 3- Appear&Ring, 4- Appear only. Change the selection on the line by using the CHNG soft button. This is where line assignments are changed from the four states for each extension.
The only other thing that will keep an extension from ringing is "Do Not Disturb" or DND. Feature 85 and #85 will turn this feature on and Off.
Jan 31, 2014 | NorStar Meridian M7310 Phone
Green line screen
The green line wit plasma displays denote a fault to its panel. But before confirming it, a proper check should be done. Check the site lined below. There are screen shots to defective plasma displays. Pull up older posts there. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong. http://electronicshelponline.blogspot.com/
May 05, 2013 | Panasonic TCP50S1 50 in. Plasma HDTV
Green horizontal line
If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
May 05, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
Line 4 doesn't ring in coming call
The way 4 line phones work is that you need 4 lines on every jack that is connected to your phone.
You see the light probably because one of the phones has line conected and you see line appearance.
Mar 20, 2009 | Nortel Lands Phones
How can i change the ringer on my fax machine?
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Dec 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Number of rings before recording answers
Choose how many times the line will
RINGS IS...” ring before the system answers a call.
• Set for 2 to 7 rings, or choose
Toll Saver 2/4 or Toll Saver 4/6.
• When set to Toll Saver 2/4, the system
answers after four rings when you have
no new messages and after two rings
when you do. Toll Saver 4/6 causes the
system to answer after six rings when
you have no new messages and after
four rings when you do.
• During setup, the Message Window will
display the number of rings (8 for Toll
Saver 2/4, or 9 for Toll Saver 4/6).
Sep 05, 2008 | AT&T 1738 Digital Answering Machine
Ring delay on one of the four voice mail ports
Is it the 4th line or the 4th port of the voicemail?
May 22, 2008 | Avaya Partner ACS 308EC (108463001)...
Lands Phones Logo
244 people viewed this question
Top Comdial Lands Phones Experts
george  peters
george peters
k24674
Tom Chichester
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
