Question about Garmin 64 MB Memory Cartridge Maps Software, Data Card / Memory Cartridge
I do not know how to use it? I do not have a place to plug it in what do I need
Wrong card was sent to me!
Posted on Oct 10, 2009
How much fuel pressure for 91 acura
Acura legend says, 38--46 psi. I believe that spec is with fuel pressure regulator vac line disconnected and plugged. I'm not sure how you are checking fuel pressure? My info says there is a banjo bolt on fuel filter and a service plug in the top of banjo bolt. Usually after the vehicle sits over-night, not much pressure on the system, but, you still need to be aware. Place shop rags around service plug, slowly loosen service plug, then you may need a banjo bolt service adapter to screw in place of the plug so you can use fuel pressure gage.
If you have different model then I need to know model and engine size?
Apr 11, 2017 | Acura Cars & Trucks
What is the position of the ditriburator on yukon 5.7
Remove distributor cap, make sure you unplug ignition coil...remove no. 1 spark plug. have someone bump key slowly while you put your finger where the plug goes...you will feel pressure push against your finger...when the pressure stops, your No. 1 piston is at top dead center, your rotor will be pointing to where your No. 1 plug wire should be. Place your distributor just above without installing . If not aligning place your No. 1 plug wire there.. , and use that as a starting point for your firing order....good luck !!! Hope this helps...
Jan 18, 2014 | 1999 GMC Yukon
Need to know how to replace spark plugs and wires on a v6 mazda 2001
All you need is a deep socket that is the right size to fit your spark plugs and the new set of leads.
Spark plugs:
remove the spark plug end of the lead, use a screw driver and rag to place down the whole to mop up any oil that may be down there. remove your spark plug, place the new one in and replace the lead. simple as that really.
Leads:
These can be more difficult. As you pull the leads off the park plugs and distributor you will need to take note of which lead goes where and write it down. once all 6 are removed just simply reverse the process. A good rule of thumb is the length of the leadas to its location on the engine but dont take it for granted.
Oct 22, 2013 | 2001 Mazda MPV
How can i install a wlan card into my travelmate 240? I know where to plug in but i have no idea where to place the antenna for it. Does anyone know?
"How can i install a wlan card into my travelmate 240? I know where to plug in but i have no idea where to place the antenna for it. Does anyone know?"
Your laptop is equipped with wireless already, see here:
LINK to specs
If not, use any of the USB ports and if it prompts you for software you would need to get the driver onto a USB memory card to install it.
May 03, 2010 | Acer TravelMate 240 Notebook
Where does the power switch plug into on the motherboard, along with the two other plugs grouped in those wires?
to answer this question, your really need to know the motherboard type and name, as in some rare cases the switch does not plug into the same location as all other motherboards. In most cases though, looking into the computer case, on the bottom right of the motherboard there will be a place about 1/2 inch wide and 1/4 inch tall will 8 to 10 pins. That is where the switch will plug in. Knowing exactly which place to plug it into though, comes back to needing to know the motherboard type and model number. Then on the motherboard manufacturer's website, you should be able to find a user's manual about the motherboard, and in there there will be instructions as to where everything plugs in.
Feb 12, 2010 | Everex GA3400 PC Desktop
Video output and audio output rca connections came off of plug from rear of unit need to know were to put them to.model#xo 09013
Look at the rear of the player, the plug receptacle has a color ring, that should match the color of the RCA plug.
If that not the case, the two stereo audio plugs should be similar in shape and color, and placed side by side on the player, while the video one is just one plug, placed well apart from the other two.
Dec 04, 2009 | XO Vision XO9013 Car DVD Player
Need to replace Panasonic AC electrical cord.
If the burn is near the end I would put a new plug on it and run it. If it's near the unit I recomend replacing the cord. You need to find out why the cord burned through in the first place. There may be a problem on the circuit that needs to be resolved before plugging the unit back in. Do you have very many things on the same circuit the unit is on? If so the wiring either needs an upgrade or you will need to plug some things into different places.
Aug 11, 2009 | Panasonic CW-XC84HU Air Conditioner
Engine misfires
if they are in the riht place then the plugs need gapped..Or the the coils are bad and need to be replaced aswell any checl lights coming on?
May 18, 2009 | 2002 Land Rover Freelander
Garmin 64 MB Memory Cartridge  Maps Software, Data Card / Memory Cartridge Logo
23 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
