Question about Gateway GT4016 Desktop PC
Monitor will sometimes show graphics, other times will say no signal found or be totally black. I've tried 2 different monitors, and same problem with both.
  • Christopher Boivin
    Christopher Boivin May 11, 2010
    Are you using the onboard video, or an add-in video card?
    Sniper:
  • 77 Answers
Either way, it appears as though whatever video hardware you are using is on it's way out, due to your having tried two different monitors with the same results.
If you are using the onboard video, take a jaunt to your local computer parts store and spend a few bucks on a PCI-Express video card. If you're even remotely handy with a screwdriver it's a ten minute install process, and will save you the expense of having a tech do it for you.
By the same token, if you are already using a third-party vid card, remove and replace it.
Posted on Oct 08, 2009
Black screen
could be a problem graphic card , failing
if you have a plug in card , then reposition the cable back onto the mother board monitor connection to test
Jun 20, 2017 | BenQ G2412HD 23 inch Monitor
Black Monitor, (NO SIGNAL FOUND)
Start your computer with monitor attached to the onboard graphics poart,
go to bios,
search for graphics setting and change it to PCIE.
Exit while saving changes connect your cable to graphics card port.
This will solve ur problem.
Nov 25, 2012 | MSI N210-MD1G/D3
Packard bell imedia d3318 no vga signal
It is the video graphics card, or the motherboard, but you can sub out the ram memory one at a time as you test. It might be a bad stick of ram which would rule out the above mentioned
Apr 10, 2012 | Packard Bell iMedia Computers & Internet
Compaq D315 showing no input signal
Check if the cable between PC and the monitor is tight and re-plug it.
Try using a different monitor - to check if monitor isn't broken. If another monitor works - it's a problem with monitor. It could be just a wrong chosen input - if it's true specify please your monitor type.
Try using the monitor on a different PC - if it works then you've a problem with your Compaq D315. Probably a problem with graphics.
Dec 31, 2011 | Compaq D315 Business PC PC Desktop
My packard bell lcd monitor shows orange then sometimes green light but has totally black screen. If power supply giving insufficient voltage would this cause above problem?
> insufficient voltage cause ?
Well, anything is possible, but other things are more likely:
1. loose connections of the "data" cable between the monitor and the computer's video-card;
2. an electrical "short" in the data-cable;
3. a "dying" video-card.
So, try the "free" stuff first:
Check the connections.
Try a different cable.
Try connecting the monitor to a different computer (laptop?).
Try connecting a different monitor to your computer's video-card.
Then, consider buying & installing a new video-card.
Nov 18, 2009 | HP Computers & Internet
Power on - blank (black) screen
Disconnect the monitor signal cable from PC and switch on your monitor. It should show some logo with Red, Green and Blue colors with a message similar to "No signal". If so, your monitor is working fine. Sometimes if the brightness and contrast is set to zero using controls present in the monitor, it will not show up anything. check wheather somebody set your monitor brightness and contrast to zero. If so incease them. As a last try connect to different PC and check before approaching a service center. I hope this will help you out. :)
Aug 21, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
"No Signal" on monitor after boot
hi try to use different slot on your motherboard see if that helps if not try different video card...if that didn't help it might be your motherboard that went bad
Aug 23, 2008 | HP Pavilion a400n (DQ173A#ABA) PC Desktop
Dell 2001FP always in sleep mode.
I have a dell ultrasharp and at first it would not come on at all. Open it up and found loose connection on plug connectors 3 pin. Soldered and would come up but blinks in and out sometimes take longer than other times. Big Capacitor when open up Power supply was leaky. Check for bad caps
Sep 08, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Gateway GT4016 Desktop PC Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
