Question about LG Televison & Video
NO sound - LG Televison & Video
  • 2 more comments
  • John Pearson Oct 08, 2009
    The model is 32lc2db-ec
    serial number 701mapno8216
    when the problem first started we would leave the tv on for about 45-60 minutes them turn it of and then back on and the sound would start up. but last night it went off and will not come back on
  • John Pearson Oct 11, 2009
    The sound has now come back. But it takes about 1 hour for it to come on. I took it apart yesterday and checked the cards for any cold solder joints with a magnifying glass and every thing looks ok. I thought that maybe it was a dirt problem. That is not the case. Put it back together and it is still the samething. If you have any other ideas please let me know. I wil try the DVD player and let you know tomorrow.It dose seem to be heat realated. Other than the other night when it went off completly. I had done everything esles that you said to try.
    Thanks
    John Pearson
  • John Pearson Oct 12, 2009
    Model # 32LC2DB-EC
    Serial # 701MAPNO8216
    I hooked up the DVD playewr and it made no difference. I have unpluged it several time and left it but has made no difference. also have set it back to factory specs. Last night it was working fine after about a 1 hour wait and then it started to make a clicking sound like you where flicking a switch on and off then the sound stopped and would not come back
    John Pearson
  • John Pearson Oct 13, 2009
    yes it is an LG
  • 10,594 Answers
Unplug TV from AC wall socket for couple of minutes, replug back in and turn it On.
If sound does not come, let me know exact model number of your LG TV to provide you technical info to solve sound issue.
Thanks.
Posted on Oct 11, 2009
  • Shahid Electronics
    Shahid Electronics Oct 12, 2009
    Model # 32LC2DB-EC
    back
    John Pearson
    Is it LG brand TV?
    Please reply so I will check its schematics for possible cause of problem.
    Thanks.
    Shahid Electronics Oct 13, 2009
    yes it is an LG
    OK, LG 32LC2DB-EC
    Please check 18 Volt at L421 on power supply board that drives audio output amplifier IC in TV.
    If 18 volts are ok, audio amplifier chip TAS5122 is bad, replace it.
    and if 18 volts are not at L421, power supply board is bad, replace it.
    If 18 volt is OK and audio output amplifier chip is also ok then digital sound processor or sound processor is bad and main board of TV will be replaced.
    Let me know if you need service manual copy if you are repairing TV by yourself.
    Thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please connect the TV with a DVD player and check if the issue is with the TV or not. Also try changing the Component cables with an HDMI cable or Component cables if using HDMI. After this is checked.
If everything is fine then go to the menu setting and check for your input settings (audio options). Use the same menu to change other audio settings, and see that the TV speaker is not set to "Off".
If this doesn't help then MSP4450K IC (Main Audio Processor) might have gone bad and needs to be checked & replaced.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 08, 2009
  • 157 Answers
Can you get the model number,so I can research your problem.
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
Error ID = 0xC00D11BA, Condition ID = 0x00000000
Your sound card might be in use by another application.
0xC00D11BA: Cannot play the file
Windows Media Player cannot play the file because there is a problem with
your sound device, such as a sound card or sound controller. You may
encounter this error message for one of the following reasons:
Your sound device is in use by another program. Quit other programs that may
be using your sound device, and then try to play the file again.
Your sound device is not functioning properly. To troubleshoot the problem,
see the Sound Troubleshooter in Windows Help or refer to your sound device's
documentation.
You do not have a sound device installed on your computer. Install a sound
Apr 10, 2010 | Microsoft Windows XP Professional for PC
My sound card is not working
look for the model number on the card and goto the manufactures website and download the driver
Aug 21, 2009 | Compaq Creative Sound Blaster PCI 64 Sound...
Sound Quality Comparision
Slight difference.....The sound quality difference is observed.
You can find out the difference.In every motherboard on board sound is not so good.But in sound cards it is disigned specifically for sound.
if it helps
Pls RATE ME
Jun 25, 2009 | Intel D865GBF Motherboard
Free sound driver
i need creative sound card driwer
Sep 06, 2008 | Creative Labs Sound Blaster Live! 5.1...
SOUND DRIVERS
in your computer sound card problem. otherwise please check the control pannal in sounds and vedios.
then check the computer wheather the sound card installed or not. if the sound card not installed please installed the sound card drivers.
Aug 16, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
For sound driver
Check for sound drivers on www.support.intel.com
Jul 12, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
NO SOUND ON MY COMPUTER
i need help put sound on my computer, and where to go to download a sound device driver
Jul 04, 2008 | E-Machines eMachines Desktop PC
No Windows Sounds or windows sound functions but All media players work
Select control panel >Sound and audio devices >select Sounds> Sound scheme options check whether the windows default theme is set. if not then set windows default theme.
thank you !
Dec 24, 2007 | Creative Labs Audigy Gamer Sound Card
Televison & Video Logo
64 people viewed this question
Computer Repairing
Computer Repairing
