Question about Jane Powertwin - Navy Jogger Stroller
My front wheel hit a pot hole pretty hard and now it all bent in towards the stoller and it doesn't work to push it anymore. Just wondering if i can get the whole front wheel part.
  • 419 Answers
If you visit http://www.johnstonprams.co.uk/contact.htm
you will find contact information to purchase a new footplate and wheel assembly. Check that you do need a wheel as well as the footplate and you may just need the footplate only (that would be about £30 ish).
I hope this helps.
Posted on Oct 11, 2009
Car has a vibration in left front when acceleration
could be possible your wheels are not balanced properly or your rim is bent, did you hit a pot hole recently?
Mar 01, 2013 | 2000 Oldsmobile Intrigue
What is broken after the collision
you bent the lower control arm and sounds like the inner and outer tir rods
Oct 29, 2012 | Hyundai Motor 2003 Elantra
Hit a pot hole - car lost fuel power still will try to turn over but no ignition 1998 Ford Mustang
If you hit the pothole hard enough, your fuel cut-off may have actuated. Locate the cut off, (some of them are around the steering post towards the firewall) and push to reset.
Apr 12, 2011 | Ford Mustang Cars & Trucks
Feel vibration in front end of vehicle. Seems to be coming from both left and front tires. This occurs at low speeds and highway speeds.
lots of possibilities here. have you recently hit anything such as pot holes? try rotating tires from rear to front and see if there is a difference. Beyond that it could be anything from bent wheels to out of balance tires(less likely to be noticed at low speeds), or perhaps bad tires(choppy tread). Next is to check steering and suspension for worn or damaged parts.
Hope this helps.
Feb 17, 2011 | Ford Expedition Cars & Trucks
Hit a pot hole right side wheels car is zing zagging on the road had wheel lineament done better but not right
Check for a bent rim or separated tire. Should have been checked when the alignment was done.
Apr 15, 2010 | 1994 Mazda 323
The car is hard to control in the highway constantly steering
Your engine and transmission mounts need inspection. Replace as necessary.
Jack up your car and support it on jack-stands.
Rotate the front-wheels and pull it towards your chest to feel the condition of the wheel bearings.
Do the same for the rear-wheels.
As for rear bouncing around corner: your rear-shocks need to check.
Last resort is to do frame inspection.
Dec 01, 2009 | 1996 Audi A4
The front end and steering wheel shakes when i hit a hole or bump
This usually indicates a problem with the suspension components. Check for play in front end suspension, 1st thing I would check would be the steering damper, it's often overlooked, and could be the cause. If that checks out ok, jack up and check for play in wheels, which could be caused by worn ball joints, tie rod ends, wheel bearings. A lot of possibilities, generally play in any components can trigger the shaking you're experiencing when hitting a pot hole or bump. Good luck!
May 09, 2009 | 1988 Ford F 150
2001 hyundai santafe very wobbly wheel
If you've hit a pot hole hard then the wheel could simply be buckled. Remove the wheel and place it flat on the ground if it wobbles on the ground problem solved: buckled wheel!
Apr 28, 2009 | 2001 Hyundai Santa Fe
Hit a pot hole and now the front of car is squeaking. 2003 Alero.
Could be the wheel cover (if equipped) git a little bent against the wheel itself. Try removing cover and see if sound is gone.
Mar 19, 2009 | 2000 Dodge Caravan
Jane Powertwin - Navy Jogger Stroller Logo
219 people viewed this question
Top Jane Baby Gear Experts
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
john h
Are you a Jane Baby Gear Expert? Answer questions, earn points and help others
