Question about Maytag SDE3606A Electric Dryer
Dryer turns on, tumbles, and blows air, but not hot air
    President:
  • 1,304 Answers
Take off the bottom toe kick
look to the back left of the cabinet
you should see the heat element, inspect all the connctions, this model ahs a habit of burning connections
if all is ok it probably your heating element ive included the sears part number for you
37001134
its ver easy to repair this
the heater runs less than 30 dollars
Posted on Oct 08, 2009
4 Suggested Answers
aasc
  • 1606 Answers
SOURCE: dryer working but not blowing hot air
Either bad thermal cutoff or bad element .( first 3 numbers missing on model #)
Posted on Jul 06, 2009
astruttman
  • 45 Answers
SOURCE: dryer blows house fuse --keeps tumbling--no heat
If the dryer turns on, drum spins, but you have no heat, any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
Now, if your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. You have to remove the entire front panel on some models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two RED leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set.
Posted on Jan 11, 2009
  • 98 Answers
SOURCE: the tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Posted on Jun 07, 2009
White knight tumble dryer cl847 not heating
-Possibly one of the heater element blow out.
-Timer switch assembly stuck in low position.
Good luck
Mai
Nov 21, 2013 | Dryers
My defy tumble dryer is not getting hot just blowing cold air
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Apr 21, 2011 | Dryers
My dryer blows out hot air but it wont tumble what does this mean?
Most likely the drive motor for the dryer has burnt out and needs to be replaced.
Jan 11, 2011 | Roper RES7646KQ Electric Dryer
Turns on & tumbles but no heat. top got really hot b4 it quit drying
You may have a clogged vent.your machine gets to hot and safety switch kicks in or you lost the blower fan
when drying does it sound like air is blowing.... let it cool down and see if it starts again
Dec 19, 2010 | Frigidaire Electric Dryer
Dryer is running longer than usual, it's tumbling,
no make listed here...I would pull the hose off the back of dryer and see if a lot of air is blowing out of vent. if not, heres your answer a clogged filter area ..if air blowing out leave vent hose off and dry clothes with vent off for one cycle. if clothes dry with vent hose off..you have a venting issue and need your vent cleaned out...
May 15, 2010 | Dryers
Kenmore HE Dryer not blowing hot air
I have a gas kenmore dryer... the drum runs- it blows air and for just a few minutes warm air but after a few minutes the air is cold. I have cleaned the vent checked it good. I didn't see the fuse on the back I have the bottom latch open and see several wires that can be disconnected; snap together.
Mar 10, 2010 | Kenmore 63942 Dryer
Dyer really hot, not drying clothes
Is the dryer tumbling? If not, you may have a broken belt or some other drive assembly issue.
Also, turn the dryer on and go outside to the vent discharge - you should feel air coming out at a pretty good clip. If not, the vent line is obstructed and will need to be cleaned out.
Jan 07, 2010 | Dryers
My dryer is tumbling but not blowing air hot nor cold
then you would have a broken fan blade.
because the motor that turns the drum is also the motor that turns the fan blade to blow the air.
open the rear portion of the dryer and you can find the fan blade, made of plastic, being covered by the vertical duct that came from the drum. then the outlet of the fan assembly goes out to the exhaust of the dryer.
another could be problem would be a clogged exhaust duct. check the exhaust duct or the hoce that is attached to it. see to it that it is clean and no blockade.
tnx 4 using fixya,
drcool
Sep 30, 2008 | Dryers
Maytag SDE3606A Electric Dryer Logo
164 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
