Question about Wolverine S1000 (1 GB) MP3 Player
Mp3 its connected to the herd ware i cant get it to pop up on the screen it says pearl detected
0 characters
1 Points
My RCA pearl mp3 player will not go from the first setting and i cant listen to the music.
my RCA pearl mp3 player will not go from the first setting and i cant listen to the music.
Aug 23, 2011 | RCA TH1602 MP3 Player
My mp3 cannot be detected by computer.. the the screen cant appear anything, but the light still work.. it is already broken? can it be fix?
not broken to your computer and open all program and look for the name of ur mp3 then open computer in the folder and it should pop up
Jun 14, 2011 | Samsung YP-U3 MP3 Player
My computer wont detect the mp3 and connect
Is the player working normally otherwise?
If so, then try the player in a different USB port on your computer. When plugged in, the display of the Pearl should say that it is connected to a USB device and it will show up automatically as a removable external drive in your windows explorer.
If not, then upgrade the firmware in the unit and the computer will recognize it again. Download the firmware upgradefrom, and follow all the troubleshooting instructions that popup when you start the program:
start the program,
remove the battery,
hold the play button while plugging into usb,
release the play button the the term "initalizing" replaces "searching",
check the box that says "format data" (you can try it first without this checked, it may work and will save your music),
click the start button to replace the firmware.
After I did this, my pearl started normally, and my computer recognized it again.
Nov 16, 2009 | RCA TH1602 MP3 Player
RCA pearl th1602-a with new battery will not power on. Old battery will power on, but freeze at pearl logo. Player dosn't power on when plugged into USB of computer
Try a firmware recover. Download the firmware update from the RCA website and install the app. Start the updater and connect the player holding the PLAY button until it gets detected.
This is a similar player with the recovery procedure explained:
Oct 28, 2009 | RCA TH1602 MP3 Player
Windows media will nt detect my mp3 pearl (RCA
Quue I had many of the same problems as listed above. what worked for me was to go here and download the firmware upgrade installer. Follow the directions and be sure to check the reformat box b4 you start. My pearl th1100a is working fine now.
Hope this helps
May 27, 2008 | RCA TH1101 MP3 Player
Pearl mp3 player
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 19, 2008 | Philips GOGEAR SA6045 MP3 Player
Refresh database?Need Serious HELP!
Have you removed the battery, wait then reinstall it to try to reset it? Been the Sansa website and their FAQ or tech support?
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
Cant install mp3
You have to go the web site of the rca pearl and choose to download the vista version of the software for the pearl
Feb 01, 2008 | RCA H100 MP3 Player
Cant detect player
Do you have media player 11 installed? It wont work with media player 11.
Also make sure you have no traces of media player 11. When you roll back from 11 to 10 it still leaves a trace of media player 11. Check your add/remove programme setttings carefully to make sure there is no reference to media player 11. If there was and you have removed it, restart your computer.
Nov 10, 2007 | Samsung YP-K3 MP3 Player
Problem detecting my Mp3 Player
restart your computer and use different port.
Jul 24, 2006 | Samsung YP-MT6X MP3 Player
Wolverine S1000 (1 GB) MP3 Player Logo
Top Wolverine MP3 & Digital Media Players Experts
Are you a Wolverine MP3 and Digital Media Player Expert? Answer questions, earn points and help others
