Question about Sharp AR-168D Black and White Copier
How do you reset the error message : maintenance requred, call a service technician?
  • 388 Answers
You call a Sharp Service Technician and have them reset it. That code cannot be reset by a user.
Posted on Oct 08, 2009
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
Mar 19, 2013 | Ricoh MAINTENANCE KIT TYPE 6330N...
Our Sharp ARM455N Copier shows "Maintenance
this is message that the copier did certain amount of copies and it needs to be cleaned and ispected. The purpose of preventive maintenace is to stop or reduce problems before they occure. In most cases they occure when you need the copier urgently.
This can be reseted in simulation mode, but I recommend to get service technician to service the copier.
If you want to reset the alarm leave the email and I'll send you the service manual.
Sep 09, 2011 | Sharp AR-M455N Copier
Error 80 on a lexmark t642
Hello. Welcome to Fixya
Actually Error 80 is "Scheduled Maintenance Message"
You can reset the maintenance count by going to the Configuration Menu
Follow the given steps to solve it:
  • First of all Turn off your printer
  • Hold the 2 and 6 buttons while the printer is off
  • Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 seconds
  • On your Operator Panel, you should see "Configuration Menu"
  • Scroll down and look for "Reset Main Count" and select it.
  • Exit Configuration Menu and turn the printer off then back on
I hope it will be solved, If it doesn't work then
You are required to purchase the maintenance kit and have it replaced even if the printer is still under warranty. Some maintenance kits can be installed without the assistance of a technician. However, some warranties cover on-site installation of the maintenance kit by a technician after you have purchased the kit.
In this case you must be contact to LEXMARK service provider, To get support by LEXMARK on phone, then call at 1-800-539-6275
I hope this solution will surely helpful for u
If its is helpful then please don't forget to click on Four thumbs which are given below this solution
THANKS & Keep Using Fixya
Feb 28, 2011 | Lexmark T642 Laser Printer
Sony a100 error 56
The Error code indicates the Self diagnostic message of the Camera. This message can be clearly identified by the help of a Sony Authorized service technician. The
Error code 56 indicates an issue which can be resolved by the help of a service technician. This error code may be an issue with the Shutter mechanism. Try resetting the Camera by selecting the Reset Default option in the Setup Menu 3 option. Also, try removing and reinserting the battery after 1 minute. If not resolved, get the unit serviced.
Thanks.
Oct 21, 2010 | Sony Alpha DSLR-A100 Digital Camera
Error 77 message
The 77 error is caused by a fuser temperature sensor. The following steps can be used to possibly reset the Intellifax 4100 77 error.
1. Unplug machine then wait 15-20 minutes.
2. Hold down menu key. Plug in machine.
3. Release menu key at maintenance message.
4. press 91 then set button
5. press 99 then set button
6. Machine will warm up.
7. Press Reports key, then press 1. This will test if the machine can
print.
If these steps do not reset the error the thermal fuse would have to be replaced by a repair technician.
Jul 22, 2010 | Brother IntelliFAX 4100 Laser Fax
Maintenance Required message on. Purchased
this light can come on even thought service is not actually due. if the service was performed and the light was not on at the time, sometimes you cannot reset them if they are not actually lit, or 99% of the time the technician forgets if the light was not on. stop by your shop and they can reset it for you in just a few moments, and for no charge. good luck!
May 06, 2010 | 2007 Lexus RX 350 FWD
Error code 990 still after reset. what to do
Error 990 is an error message that has to do with the ink drying out on the maintenance unit. Unfortunately this is a fatal error and the printer will need to be replaced as the maintenance unit can only be fixed by a technician. You will have contact Ricoh for further information on possible replacement.
Apr 09, 2010 | Ricoh Aficio GX3000 InkJet Printer
Lexmark x642e MPF Reset maintenance counter
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
Jan 30, 2009 | Lexmark X642e All-In-One Laser Printer
Kip 3000 plotter
voltage error 031-034 on the kip 3000
Jul 05, 2008 | Office Equipment & Supplies
Sharp AR-168D Black and White Copier Logo
250 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
