Question about Hampton Bay 37225 Cameron II Plus Fan
Change light I would like to put a regular bulb in the ceiling fan. The blue light just doesn't give off enough light in my daughter's room. Is a regular bulb available for this product? Hampton Bay 52" Cameron ll blue neon light.
I just put fluorescent lights in two of these fans. it just takes a little fabbing and its done and simple.
Go to home depot and buy a lithonia lighting 11" low profile round light model# FM22 ACLR LP.
tools:
drill
rotozip or file
wire strippers
crescent wrench
screwdriver(phillips)
you can take the neons and the power supply off of the fan base but be sure to save all the screws, you will need them later. the ballast in the light will fit in the chrome base on the fan but you have to shave one of the bolt holes down first for it to fit (be sure not to cut the ones that the bolts go through). you do not need the green ground wire from the new light.
Next drill out the rivets from the bulb brackets on the new light base. now you can take the bulb and place it on the fan backing plate and get your bulb brackets and mark where you will mount them. then drill holes for them (but make sure the holes are for the screws that you saved earlier because you will reuse them for the light brackets). Be sure to mount the bulb as center as possible.
now once you have fabbed everything put the assembly up to the fan and pull the wires down through the ballast and through the center tassle bolt and wire it up. the bulb is an 8" bulb and thats all that will fit. home depot sells phillips 8" bulbs in several different brightnesess.
this picture was taken on my phone so it isn't that great. but the light really brightens it up.
Posted on Mar 22, 2010
I have a Concept II, I think, & need to change the light bulb. Because the light cover is opaque, it gives very little light in the room. This is the only ceiling light. Can I put an incandescent...
press down on the light button until the light gets to full brightness. Don't be afraid to read the directions that come with the fan.
Feb 26, 2015 | Dryers
Compact Flourescents won't work in ceiling fan
Simply use regular bulbs. It sounds like it is switched electronically probably via a dimmer. If the CFL lamps are not specifically labeled dimmable they won't work. I have seen the LED lights work where the CFL lamps will not. If you want to use CFL then replace the dimmer.
Dec 17, 2013 | Hunter 52" Ceiling Fan With Light And...
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
May 20, 2013 | Home
In my Hampton Bays ceiling fan is a circular fluorescent bulb which gives very poor light. Is it possible to put in a different lighting system like hallogen?
Yws it is possible.Check on the fan before changing anything, there should be a maximum wattage sticker. Do not go any bringter than the max, it is there for a reason. If your plans are to install incondesent light system, be aware. that, bulb puts out much more heat,
Oct 07, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Ceiling fans not bright enough
In this case, probably not. The issue is heat, and the limit is space. One suggestion, new fluorescent bulbs give more light with less wattage. If you can find one that will physically fit in the space, this might get you more light.
Oct 19, 2009 | Aloha Housewares Dryers
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
Changing light bulb in ceiling fan
At the top of the pull chain there is a metal piece; this is threaded on a bolt. Unscrew the metal piece and lower the globe to expose the bulbs then remove and replace the bulb(s). I recommend flourescents as they are more economical, run cooler and last linger than incandescents (regular bulbs).
May 17, 2009 | Hampton Bay 24002 Ceiling Fan
Changing light bulbs in Hampton Bay 60 in. Miramar Fan
You have to unscrew the small openings on top of the housing where the motor is to access the small nightlight bulbs.
Jan 01, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Ceiling fan wiring
blue would be your earth.
black and white are phase and neutral.
for the wiring in your roof you need to call a local sparky. just ask which is which and connect them appropriately.
Sep 01, 2008 | Hampton Bay 24002 Ceiling Fan
Wall switch
I had this same problem (sort of) - my daughter lost the remote to our fan and it would not work from the wall switch. What you have to do is go up to where your fan is connected to the ceiling, slide the canopy down, and remove the remote transmitter. Then just rewire the fan normally - white to white, black and blue to black, and the ground wires together. Turn on the power and your fan light should work with the wall switch. You will have to pull the cord for the fan to work.
Jan 07, 2008 | Honeywell HFS641P Stand (Pedestal) Fan
Hampton Bay 37225 Cameron II Plus Fan Logo
443 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
