Question about Philips 150S4FB 15" LCD Monitor
Horrizontal line in bottom of screen shifted the whole screen up
A horizontal line is at the bottom of the screen and has shifted my whole screen up so the top is also at the bottom. When i try to change the settings with the osd controls it says there locked. how do i unlock then and will it help if i do?
  • 1 more comment
  • e-abe Dec 24, 2007
    it doest have a reset button
    it doesnt * have a reset button
  • Steve Nordquist
    Steve Nordquist May 11, 2010
    I bet it secretly does have a reset command; hold Power for 3-10 seconds and see if something different happens. Also try powering on with 2 (contrary) controls held down. Phillips tends to make it simple, so it might just be power/brightness-down. They toss this in the manual but they don't want it named 'reset' and logged as a Phillips Failure so it's called something apart from that.
  • 74 Answers
If your monitor has a reset button, press and hold it for 3 to 10 seconds.
Posted on Dec 24, 2007
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
Horizontal lines on Samsung 42
Hello horrizontal ines are controlled by your buffer (drive boards) or your ysus board. They are located on the side of the tv and are 3 boards that are connected together and connect to the side of the plasma screen. the two drive boards separate the top and buton. if the lines are on the top then you might try replacing the top buffer and vise versa. if that does not work then its your y-sus. be very carefull replacing these they are very sensative.
You can get get parts for this tv at www.interliquidparts.com
Nov 26, 2011 | Samsung HP-T4254 42 in. Plasma Television
HI,i was whacthing the tv and on top the screen did appear 6-8 horizontal lines,i did try to turn on/off,......i need help.thankyou.
Normally this is an overheating issue or a power supply issue. For the overheating issue, take a vacuum and some compressed air and blow out the back of the TV. Dust can collect and cause components to retain heat that will cause the TV to produce horizontal lines called artifacts. Sometimes these are permanent but sometimes they can be repaired before replacement.
Mar 01, 2011 | Samsung HP-R5072 50 in. Plasma HDTV
I,M USING 42INC PANASONIC VIERA PLASMA TV WITH THE MODEL NO TH-42PX60B AND THE SERIAL NO IS 6562190 AND THERE IS A HORRIZONTAL LINE ON MY SCREEN SO I CAN SEE THE PICTURES WELL THE SCREEN IS DIVIVED INTO...
Hi, my name is John. Welcome to FixYa. Its your horizontal output transistor, and a few capacitors. I will post the tools and steps needed here......John
Nov 30, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
The bottom of the screen is black-as though there is a border along the bottom. I can't find a horrizontal adjustment anywhere.
It is a vertical issue, not horizontal.
Is the picture you have complete? Is there a black band along the top as well? If so, it may be because you are providing an HD aspect ratio of 16:9 instead of the TV native 4:3.
Try hooking up a VCR and watching a tape. Do you still have the black band on the bottom?
Aug 18, 2009 | Toshiba 36A40 36" TV
Screen
HI, need to see a picture of the line and need to know if you see it on all inputs and whitch ones are you using and does it do it on all of them.
If you cannot send me a picture then let me know what color is the line,is it from left to the right end of the screen and the top and the bottom of the line are they straight all the way horrizontally.
Wait your response then I will do my best to find the solution.
Sep 13, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Black horizontal line 1 pixel high
Depends on what area the line is in the bottom half or top?
Mar 10, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
Horrizontal fluttering when warmed up.
1. HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB
Oct 18, 2006 | Mitsubishi VS-60705 60" Rear Projection...
Can only see a horrizontal line
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Dec 29, 2005 | Panasonic CT-27G14 27" TV
Philips 150S4FB 15" LCD Monitor Logo
232 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
