Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Outer screen I need to replace the outer screen of my tv. I can't find the part at SONY.
  • 149 Answers
Look for it @ local tv shop they may have one they are discontinued
Posted on Apr 05, 2008
Broken screen sony tv from wii
you now have a parts TV, a replacement screen will cost more than the set is worth. I would suggest listing the set on EBay or your local Craigslist as a parts unit. If you get offered $40-$60, take the money and run!
Feb 12, 2013 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Cracked outer screen
there are a few sites other than sony who may no longer carry this part==tv
Mar 31, 2012 | Televison & Video
Can i buy just the screen for my 61' sony projector tv and where i moved my tv via bed of my truck on freeway about 85 mph and blew plexy glass off front of tv and the outer screen can i buy these...
A Sony dealer may be able to aquire them for you. They are very expensive, so be warned.
Contact Sony's web site for a list of dealers.
Hope this helps.
Nov 27, 2010 | Sony Televison & Video
I have a Sony KP-46S25. The screen is cracked. I
There are 2 screens for this set, a protective (outer) screen and a fresnel (inner) screen. Which one needs to be replaced?
Apr 08, 2010 | Sony KP-46S25 TV
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
Cracked outer screen on projection tv
No it can't be repair only replaced.
Part# 4-090-943-01 $76.15
Freight charges may range from $45 - $150
Jun 10, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony KP-51HW40 51 Screen Protector
this tv has three parts to screen , the most outer part is called CONTRAST screen part # 408195411 for the model you gave.This is available @ (parts&access) Please make sure this what you need and model is correct..Good luck
Nov 29, 2007 | Sony KP-51HW40 51" Rear Projection...
Screen replacement
try contacting for discontinued screen replacements
Nov 25, 2007 | Toshiba TZ50V51 50" Rear Projection...
Screen replacement
I replaced the screen on my 62 inch projection TV for about $50 and the the picture quality is good! Have a sheet of plexiglass cut to the EXACT size needed. BEFORE installation it MUST be frosted on both sides by either a fine particle sandblaster or by sanding it VERTICALLY on BOTH sides with a power sander and a fine grade paper.
If this is only an OUTER protective screen and the image is projected on the inner screen then DO NOT frost the replacement screen, just install it.
Nov 21, 2007 | RCA R52WM24 52" HDTV Projection Television
'No Signal' on Sony XBR
on the tv remote: press menu, external entry is highlight (yellow) right press on the outer circle then scroll down to video 4 (satellite entry) (it could be on video 3 depending of the satellite assignment entry) when video 4 is highlight (yellow) right press on the outer circle on the screen you will see 1080i if settle on an HD channel hope it will fix your Sony Bravia..
May 30, 2007 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
