Question about Car Audio & Video
Need help wireing sub
I have 2 12'' sonys. one blew and i wand to just use the other cuz it's still good. how do i wire the single woofer to the amp. heres the amp specs:
ARC Audio ks 300.2
Power output RMS @ 4 ohms 2 x 180 watts
Power output RMS @ 2 ohms 2 x 350 watts
Power output RMS @ 4 ohms bridged 1 x 700 watts
Transient Distortion (100 watts) <.01%
Frequency Response 20Hz - 20 KHz
Signal to Noise Ratio >98dB
Bass Boost +18db@45Hz
Crossover (Butterworth) 55Hz - 5.5 KHz variable 12dB
Fuse 30A x 3
Size 13.0''(L) x 8.0''(W) x 2 3/8''(H)
and here's the sub system:
Sony XS L120B5D
ported enclosure with two 12'' subwoofers
MDF construction with black carpet covering
two 12'' five-sided polypropylene woofers with rubber surrounds
4-ohm total impedance
frequency response: 20-2,000 Hz
power handling: 100-600 watts RMS (2,000 watts peak)
sensitivity: 89 dB
32''W x 16-1/16''H x 18''D1 x 15-1/4''D2
i want to remove the good sub and connect it to the amp... a also want to know how big of an enclosure to get
Additional Details
a diagram would be GREAT!!
the box is pre-wired to make it 4ohms, would each sub be 2 ohms or 4 ohms then??
    Problem Solver:
  • 15 Answers
Is the speaker a dual voice coil speaker? If so you can wire it up a couple of diferent ways, go to rockfordfosgate.com they have a woolfer wiring wizard that can show you the different ways to wire for 8 ohm.....4 ohm.....2 ohm....and 1 ohm...I would figure out how to get the most power out of the amp in mono mode, take that ohm load from there and see if you can wire your speaker to match it.
Posted on Oct 09, 2009
What's the best way to hook up my jl audio 13" w 7 sub to my jl audio 1000/1 amp
the best way? hmm. i would start off with some wire. Keep in mind that you will need to separate the positive (usually red or has a stripe or marking on it) from the negative (Black usually is the common color for this wire) and hook the up according to your amps positive and negative hook ups / terminals following your sub-woofers terminals. then depending on your sub woofers Voice coils (Duel or single voice coils) yours are duel or quad coils but i\'m sure they are duel (2 of each positive and negative equaling a total of 4 posts on each sub-woofer). figure out your amps ohm load handling and does your amp run hot (1,2 or 4 ohm stable some are even less like 0.5 or lower) i would run at a 1 or 2 ohm load as that is usually standard on 1 channel amps. make sure to check your wiring and if your not sure about ohm loads just Google wiring for sub-woofer ohm loads such as 0.5 ohm, 1 ohm, 2 ohm or 4 ohm loads. also make sure your box is not sealed do to the fact they are siht and cant produce sound like a vented / ported enclosure keep the size as big as you can fit in your car or truck the bigger the better. i had one 8\'\' sony sub pounding like a 15\'\' sub real loud . Also MDF particle board is garbage it causes port noise and absorbs water
Apr 28, 2014 | Car Audio & Video
Hi i purchased the bnps102 woofers and used them for 2 weeks i really enjoyed them and i also purchased the pyle 1400 watt amp and a jvc deck along with the boss amp kit installation now the speakers about...
If the lights on your sub box aren't coming on it's either your ground of power wire came loose or the transformer blew. As for the subs, make sure all the connections are good, especially on your RCA wires. If your amp is getting power, then check your speaker connections. Also, make sure to turn the gain know up. The gain knob is located next to the RCA input on the amp. Let me know if this helps.
Aug 21, 2011 | Pyramid BNPS102 Car Subwoofer
XA10002 dual channell amp pushing a single 12 inch JL Audio sub and continues to go into protection mode. All setting are turned to the lowest possible and remote wire, power wire, and ground wire are all...
Make sure you are wiring the sub to the correct ohm's. Some amps have a protective feature that will send them into protect mode if they do not since the right ohm load. If the sub is wired correctly double check your ground wire on the amplifier, and if that if also fine then your amp will need serviced.
May 31, 2011 | xXx XA10002 Car Amp
My xploid amp blows the fuses in the amp if my subs hit to hard and i dont know why?
It sounds like you have the levels improperly matched or the wiring to the sub woofers making an improper impedance match. Make sure you are not overdriving the amp by running the levels lower, or check if you need to rewire the speakers to get the right ohmic value at the amp. A good resource for sub woofer wiring can be found at this web site:
http://www.the12volt.com/caraudio/woofer_configurations.asp
Mar 15, 2011 | Sony XM-2150GSX Car Audio Amplifier
I have connected all speakers but not getting anything coming through the subwoofer? I have connected all of my existing Sony suround system speakers 4 corner and one middle and the sub woofer to the...
You need to use an amplified sub. The Yamaha receiver is only sending "Pre-Amp Signal" not amplified audio like the rest of your speakers. If your sub has a crossover built in, connect it's speaker level (wires) to the "B" side of the receiver which will send audio to your sub and it will cross it over internally. Not the best sounding, but it works. Amplified subs range in price from 200 and up. Hope this helps
Jun 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
I got a sony xplod amp 1000 watt everything is connected good the ground wire is on a bare metal surface 12v wire good power fuse ALL wiring is as it should but there is no bass? the green light is on but...
Open your sub-woofer and check the continuity of your bass speaker. Chcek also the fuse of the sub-woofer amp...the fuse might be busted already.
Jun 05, 2010 | Car Audio & Video
How many svc subs at 4ohm does it take to get this amp to 1ohm stable and can you reccomend a good sub combo for this amp whether it be dvc or svc
It depends if your sub is 4ohm svc, or 2ohm svc. 4ohm would take 4 subs wired in parallel, 2ohm would take 2 subs wired in parallel. But for a amp that big, subs that'll handle it are definitely gonna be dvc. I'd recommend 2 Orion 4ohm dvc hcca's. They come in either 15in or 12in. the 15s are louder if you have the space for them. As far as wiring goes, wire the voice coils on the subs in parallel to 2ohm per sub, then wire the 2 subs in parallel to 1ohm. Goodluck and congrats on the equipment, Orion is about as good as you can go for subs and amps. just be ready to lay down some dynamat cuz this system'll bloww your vehicle apart! good luck...
Oct 08, 2009 | Orion 2500D Car Audio Amplifier
Bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Sep 20, 2009 | JVC RX-554V Receiver
Amp light is on but no power to my subs!
Hi There.
When you say the 40 Amp fuse blew. Was it your mains battery fuse or was it the fuse on the amplifier? If it was the fuse on the amplifier then you may have hurt the amplifier. The Kenwood KAC-8101D is a 1000 Watt monoblock amplifier. Therefore if you say that 1 of your woofers is not playing, then it is almost certainly blown if you are sure it is connected correctly. Try disconnecting it and only running the woofer that tries to play. If this woofer is still working correctly, you will notice a drastic drop if the sound of your bass. The reason for this is because you have changed the impedance load on your amplifier due to the fact that the other woofer is not working. Have your working woofer checked and replace the faulty woofer then you should be banging again.
Hope this helps!!
Jan 30, 2008 | Kenwood KAC-8101D Car Audio Amplifier
Car Audio & Video Logo
188 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
