Question about Car Audio & Video
I need a wiring harness for Tevion Car stereo. Any ideas where I could get one?
SOURCE: Stereo wiring harness diagram
google!! i found it!
Posted on Jun 20, 2008
jmeyer847
  • 185 Answers
SOURCE: installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
Posted on Nov 21, 2008
  • 44 Answers
SOURCE: a new lanzar sd32mu car stereo
You need a factory wire harness for your car you can pick these up at bestbuy. The cord for the ebrake twist that to the ground wire its basically a safty thing so you can only work it while not driving. Hope this helps Good ratings help me out.. Have a good day.
Posted on Jan 13, 2009
jpk528
  • 95 Answers
SOURCE: color code for 01 acura integra factory stereo wiring harness
Battery BLUE/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) BLUE/GREEN
LF Speaker (-) GRAY/BLACK
RF Speaker (+) RED/GREEN
RF Speaker (-) BROWN/BLACK
LR Speaker (+) BLUE/YELLOW
LR Speaker (-) GRAY/WHITE
RR Speaker (+) RED/YELLOW
RR Speaker (-) BROWN/WHITE
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Posted on Feb 21, 2009
dj x
  • 61 Answers
SOURCE: Aftermarket Stereo connection
hi there
if you matched all the wires from the harness to the kenwood deck and its not working don't worry you just missed the last step........(all wires attached that a colour coded connected)
simply turn your car on.........now on the front of the kenwood deck there is a SOURCE button with all units it could be a (S, SRC, Power) hold the source button down till your kenwood unit powers up ..........if your unit still doesn't work check the fuse on back of kenwood unit should be a 10a fuse (blue) if the fuse is fine put the unit back in dash..........now check the fuse panel on driver side dash with the door open you will see this panel pull it off (some describe the fuse panel as looking like an air vent but its not its a handle to open) now on the panel that you just pulled off there is a fuse diagram on the inside look at it find radio fuse it will be a (blue fuse) located in the top row of fuses check it if blown replace and unit should work.............if this doesn't solve the issue than its a (sneaky) fuse not to many people know about if you pop the hood of your car there is a black plastic panel located just below the battery pins and just above the driver head light (usually black box with yellow writing on it......in this there are mini fuses check all of them do not touch the black relays in there just the small tiny fuses the fuse you will look at should be yellow 20a (this fuse is closest to engine and comes after the abs relay if you look inside the lid you took off it will have fuse locations cant remember which one it is for sure but check them..........now see if your kenwood unit powers up if not the last option is to ground to the black wire from back of kenwood unit to metal frame.............this last part is also done if your unit does power on but your car lights don't work if this happens ground the kenwood unit to the frame of car and open up fuse panel on driver side dash replace the blown fuse for lights or radio (make sure the kenwood unit is grounded to the frame before replacing the fuse in dash panel............if this doesnt help you than i would assume the kenwood deck needs to be repaired by kenwood.......
good luck
hope i was able to help and sorry this list is so long
Posted on Mar 05, 2009
What would cause no sound from my pioneer stereo
The harness might not match. Check the wires find out the where the speaker wires are and see it they go to the radio. I have had the same problem before in my shop someone cut off the harness got one from a year older and it didnt match few wires where off it would light up but no sound. Easy fix.. If thats not it got a few ideas let me know.
Aug 27, 2014 | Pioneer Car Audio & Video
I have Tevion 43744 car stereo. No sound from radio and bluetooth doesn't connect. Are these issues related? What's the solution?
Could be some bad connections with the speakers; are you check this harnesses and wires?
Additionally, about the Bluetooth, accorrding with the Tevion 43744 User Guide... first will need PAIRING paorcedure. Press and hold BND/ID3/TEL button until the word "PAIRING" blinks on the display waiting for the bluetooth device to connect.
At this blinking time, please run the bluetooth search and connect function in your mobile phone. The car radio model no "BT Car Stereo" will be shown on the mobile phone . Select this car radio and connect. When you are asked for a connection password, please input "0000" in your mobile phone to finish the pairing, there is "PAIR OK" to show on the LCD. Then the bluetooth icon will be shown on the car radio LCD indicating that the bluetooth function is ready to use.
Hope this helps.
Aug 19, 2011 | Car Audio & Video
I have a jvc kd-s27 i am very familliar with hooking up stereos,i have tripple checked everything and i am still getting no sound from the speakers i can plug in the original stereo and sound works...
Its because u probably u have factor amps like my car that has infinity sound system I used the wire harness adapter that plugs into the factory harness u need to plug the wire that is alone and not in the factory plug into the power antenna/remote wire sould fix that issue
Feb 18, 2011 | Car Audio & Video
Need a wiring diagram for 2002 chev, caviler stereo hooking up aftermarket stereo
ARE YOU AWARE THEY MAKE A VERY INEXPENSIVE ADAPTER HARNESS THAT HOOKS UP TO THE FACTORY HARNESS, NO WIRE CUTING,CAR AUDIO SHOP CAN GET THE ONE U NEED, ABOUT $12. HERE IS THE WIRING COLOR BREAKDOWN OF THE DASH HARNESS.
2002 Chevrolet Cavalier Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Ignition Switch (The radio harness does not provide a switched power source. Run a wire from the Ignition Switch.)
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 13, 2010 | 2002 Chevrolet Cavalier Coupe
Tevion 4187 car stereo cable required
Its simply called the wiring harness, but what it less simple, is sometimes finding them. You might try just to Google the model and put ''wiring harness'' at the end, or try the companies website if available. I have seen some wiring harnesses in places like Pep Boys, but unfortunately, people usually end up buying a new player. Hope this helps and good luck!
Mar 21, 2010 | Car Audio & Video
Need to find a wiring harness
I would need further information: What most people do not realize is that a wiring harness is not a "one size fits all" thing. There are two harnesses that you may need.
To remove your factory car stereo and install a new aftermarket car stereo there are wiring harnesses for most cars that will plug right in to the wires from your old factory radio.
For that, you will need to buy the correct wiring harness for the year and make of your vehicle. Say, for example: 1987 Toyota.
Then there is a wiring harness for the specific car stereo. You will need the make and model number of the unit itself. Example: JVC model KD-AVX77.
Jul 24, 2009 | Car Audio & Video
2005 Neon SXT Stereo Wiring Diagram
2005 Dodge Neon Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jun 19, 2009 | 2005 Dodge Neon
Need to install my stereo in my car with out the harness for the stereo
It would be best just to buy a new wire harness for the stereo & the aftermarket harness for the vehicle. If you give me the year, make & model of the vehicle & the model # of the cd player I can get you a price on the two pieces you need.
May 18, 2009 | JVC AM FM CD DET FACE CAR STEREO
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Good luck
Aduz
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
FACTORY CAR STEREO INSTALL
Look at Schoche.com for the Number of the Wiring Harness that you need . You may be able to get it at Wal-Mart. Please Rate my Response, I need all the Help That I can Get! Thanks!
Jan 28, 2009 | Car Audio & Video
Car Audio & Video Logo
781 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
