Question about Kenmore Refrigerators
Year 2002/2003 Kenmore 596.73502202 Yesterday I noticed our freezer was a little on the warm side, I though someone may have left it open a little. Closed it, and this morning everything was melted. The refridgerator part seemed cold as usual. The fan in the back is blowing cool air instead of the normal warm air. Any suggestions
  • 1462 Answers
SOURCE: freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Posted on Apr 09, 2007
  • 848 Answers
SOURCE: freezer foods thawed, still cold
thermostat problem exists in your freezer so replace it
Posted on Jun 19, 2008
SOURCE: Jenn-Air JCD2289AT side by side
The problem is that your computer board has stopped working. it is a small square white part that you can order from the jen-air website/manufacturer. Detatch the upper panel that includes your temperature control, and it will be located towards the right side.
Hope it helps!
Posted on Sep 29, 2008
  • 115 Answers
SOURCE: freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Posted on Dec 30, 2008
SOURCE: We left the freezer door open all night by accident two days ago
I turned the fridge side off on mine, and left it overnight (last night!). This morning there is frozen stuff in the freezer. I think the compressor motor just needed ALOT of time to cool down b4 it would work properly again
Posted on Jan 13, 2009
My ice maker on my kenmore refrigerator is not working. a red lightg is flashing on the ice maker. everything looks ok, no ice though!
I had the same issue with my frig. I read on line where Someone open the freezer and ran a hair dryer in it. So I tried it I turned off the water draned the water side out left my door open while I had the hair dryer running for a half hour then turned the water back on and sure enough after the line unfroze and it started making ice. there was a little blurb on the freezer about how much water presure was needed. I found this information just by doing a google search on my model frig.
Nov 24, 2010 | Kenmore Refrigerators
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to...
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to defrost.have not plugged it back in yet.but in the freezer behind the panel there was ice build up to the right of the evaporator fan on the plastic scroll.i cleaned that upturned it on and noticed that there was very little air coming through the top air scoop vent in the fridge side.when I open the freezer door it allows more air though(probably to compensate).anyway I read alot on this issue and some say it's the defrost timer boardsome thermostat.the compressor stays pretty hotbut the freezer works fine.please help.
Jul 07, 2010 | Refrigerators
Kenmore Side by side Model #53271... not cold
you have a defrost problem in the freezer,it is one or more of 4 things,freezer fan,defrost timer,defrost bimetal switch or defrost heater,check all until you find your bad part-mike
Jan 07, 2009 | Kenmore 53262 / 53264 / 53269 Side by Side...
Broke down after 3 years!! Any ideas on what wrong and how to fix it?
Hi Bill,
You will not like this repair at all. It is cheap and easy but usually really gross. So hold your nose and read on.
This time of year we have little visitors in our garages that like to find a warm place to cuddle up. They will crawl into the back of your freezer and find your warm compressor and start looking for places to build a house. While walking around they will eventually walk directly into the condensor fan and and usually they will not die, they will just be stuck in the fan blades. The heat that begins to build up will slowly cook the little critter and you will get a foul smell for a couple of days. Then you will notice the freezer has stopped cooling well. To repair simply remove the rat from the condensor fan and you got it fixed. In some cases the fan can burn out from the jam so you may need to replace it. I always hate to do this job, it is easy but who likes to handle a cooked rat??? Grossss.. Please dont forget to rate me and try to have a nice day.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 08, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frost inside freezer door
there is a small electric heater along the door gasket where you see the frost building up, this heater has apparently stopped working. this will also cause the door to pop open due to a poor seal. feel around where the door gasket contacts the refrigerator and it should feel a little warm. if not then a service company can replace those heaters. should not be too expensive.
Jun 28, 2008 | Kenmore 73262 / 73264 / 73269 Top Freezer...
My Kenmore Fridge (bottom freezer type) not freezing
Look for problems you can see. Check for frost on the back wall of the freezer, If you find frost on the back wall locate the defrost timer and rotate the clutch head screw clockwise SLOWLY until you hear one click. With the timer now in the defrost position you will hear sounds in the freezer compartment such as expansion, sizzling, after a few minutes. If after say 25-30 minutes the system does not return to cooling mode ( Compressor starting) rotate the timer again SLOWLY until you hear a second click. This would indicate a bad defrost timer. If you get no defrost your problem could be a defect in the heater circuit such as an open heater or defrost thermostat. Normal defrost time would be 18-22 minutes.
May 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrigerator Model #596.76522500
Let me pul the book on this and get back to you BTW is one of the lines (the one going to the coil under the unit) really warm??
Jan 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore coldsopot 55536400
best thing is to give freezer a thorough defrost.this would in effect allow components to reset and start fresh
Aug 23, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Freezer works but refridgerator warm
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
191 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
