Question about Mtd Garden
How do I replace the coil on a mtd yardman 15 HP
  • 389 Answers
If, by coil, you are referring to the ignition armature and since you didn't specify what brand of engine you have I will give you instructions for Briggs: ((The instructions are similar with MOST engines with a few variances.))
Disconnect the spark plug wire from the spark plug, remove the blower housing from the top of the engine (That is the half round/half square metal cover on top of your engine, this will give you access to the ignition armature:
Installing And Adjusting A New Ignition ArmatureAn ignition armature must be set at a precise distance from the flywheel. Ask your Briggs & Stratton Authorized Dealer or consult our Engine Check Chartfor the proper gap for your engine. Common armature gap ranges are .006- .010" and .010 - .014". Armatures are often packaged with a shim toassist in setting the gap. Microfiche or index cards of the properthickness also work well.
  1. Remove the old ignition armature mounting screws (image A). Then, disconnect the stop switch wire from the flywheel brake and remove the armature.
  2. Attach a replacement armature from the original engine manufacturer, using mounting screws (image A). Then, push the armature away from the flywheel and tighten one screw (image B).
  3. Turn the flywheel so the magnets are on the opposite side from the ignition armature (image C).
  4. Place the appropriate shim between the rim of the flywheel and theignition armature. While holding the shim, turn the flywheel until themagnets are directly adjacent to the armature (image D).
  5. Loosen the tight screw so the magnets pull the ignition armatureagainst the flywheel and shim. Then, tighten both mounting screws androtate the flywheel until the shim slips free.
Posted on Oct 08, 2009
Testimonial: "Thank you so much all is working well "
  • Jgrissom21 Jul 29, 2011
    What exactly is the green wire for going to the coil? And if I disconnect it will the spark plug still fire? I'm not getting any fire to the plug even after replacing the old coil with a new one.
Can anyone help me and tell me the part number for a blade for a dx70 Mtd yardman 8.5cc
Duncan, Blade #, MTD Part No 742-0578, 27.5" should be replacement bade for Yardman DX70. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GENUINE 27 5 Blade for Yardman DX70 MTD Beatle Lawnflite 503G Ride on Mower
YARDMAN DX70 MODEL 310 SINGLE BLADE MOWING DECK FG424 5900
Yard Man 13A 325 402 Operator Manual
May 21, 2016 | Mtd Garden
How do I get a copy of the owners manual for 14.5Hp MTD yardman ride on mower
Here's the link to the manufacturer's site http://www.mtdproducts.com/webapp/wcs/stores/servlet/mtdproducts/our-products/riding-lawn-mowers
When on the page, towards the top of the page click on "Owner's Center" and it has links to the manual and other helpful information.
Sep 17, 2014 | Garden
Mtd yardman
There is probably a switch in the reverse lever that shuts of the mower. It is probably a normally open switch so when you pull the lever to reverse it pushes the switch closed killing the engine. If you unplug the switch or cut the wires going to it, it would never think it is in reverse and you could always mow.
Feb 03, 2014 | Mtd Garden
Yardman 42" . I just replaced the belt and now the
my moor goes a lot slower than useal pleas help me it is mtd 32.ins about 9 years old
Mar 12, 2011 | Mtd Drive Belt 42"
Drive belt diagram for mtd yardman 42"
i need a diagram showing for a 20hp yardman tractor model number 13AT605G755
Dec 07, 2010 | Mtd LAWN MOWER PART # 983-04162A-0638 DECK...
Where can i get a free download manual for a yardman mtd 12.5 hp briggs with 38" deck
http://manuals.mtdproducts.com/mtd/Public.do if you want a manual for you motor you can go to http://www.briggsandstratton.com/maint_repair/manual_and_more/
You will need your model number and serial number for both the tractor and the motor.
Aug 18, 2010 | Mtd Garden
MTD Products- Yardman
The part number is 770.8637M, You can find it at www.mtd.com, click on yardman logo, click on owner's manual. Put in Model # 13ag675g196, Serial # 1a027130180. It will bring up the manual you are looking for.
Merry Christmas
Dec 22, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Replacement carburetor OHH55 tecumseh 5.5 hp rear
Need the 5 numbers and a letter following the model number to tell you that. :)
Jun 06, 2009 | Mtd Garden
Garden Logo
658 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
