Question about Garmin n?vi 750 GPS - Piano Black
My kawai BL-51 serial #k613407 , how old is this piano and how much is reasonable?
Hello! Can you date my old Thurmer grand piano. The serial number is 13562.
I can't find a thing on Thurmer pianos.
Get in touch with these people and see if they can head you in a direction.
Piano Serial Numbers Search Find the Age History of Your Piano
Jan 09, 2018 | The Music
I have a piano made by Laffargue piano co ewyork. The serial number is 70805. The piano has Seaverns written on it. Can you tell me the age of my piano please?
(1905)!! Please Read On How To Tell How Old Your Piano Is !! I Learned This From Grandma !!
Piano serial numbers usually have five to seven digits, but may have fewer or more, depending on the manufacturer and age of your piano. Serial numbers may also include a letter as well.
Here are the TOP FIVE places to locate the serial number of your spinet, console, or upright piano:
Serial number locations are found:
1) On the piano's cast iron plate. After lifting up the lid, look along the top front area of the plate. The serial number may be to the right or the left, or in the middle.
2) Under the opened lid on the ledge, stamped on a little plaque, to the right or to the left.
3) Stamped on the back of the piano; near the top of the wood frame.
4) Printed on one of the hammers, found on either end of the piano (newer or imported pianos).
5) Printed on one the keys - behind the nameboard, inside the piano (newer or imported pianos)
Aug 25, 2017 | The Music
How to reset kawai z 1000 piano
RESET / Hold these buttons or keys and power on Insert System disk. Hold POPS and power on. Display shows FIND SYSTEM and starts the loading process. Which version do I have? / Hold these buttons or keys and power on Input the following number code: 00009584 or look at Start Screen Which version is the latest? 2.46 How can I get the factory sounds back? RESET
Mar 24, 2016 | Kawai Music
Is the serial # printed on the wood inside the piano. That is the only # I see
Finding Serial Numbers on Pianos and Organs
www.omara-meehan.com/help/flash/serial.cfm
The Serial Number -- usually somewhere between four and six. wood or stamped onto the model plate. digits -- is probably located inside the piano on the metal ...
Piano Serial Numbers Search - Find the Age & History of ...
www.total-piano-care.com/piano-serial-numbers.html
Piano serial numbers help to identify the age of your piano and the history surrounding its ... 3) Stamped on the back of the piano; near the top of the wood frame. ... 5)Printed on one the keys - behind the nameboard, inside the piano (newer or ...
Piano Age Request How Old Is my antique piano when made
www.amadeuspianos.com/agerequest2.htm
Jan 01, 2016 | Music
Kawai mr-370 digital piano. Why is it stuck on the loudest volume and does not respond to the volume control slide?
The solder contacts on the fader may not be connected to the board. It may also be a software glitch. If you reboot / initalize the instrument it may fix it.
Dec 28, 2015 | Music
What is the piano age by serial number 1872
Hello, you will need to look inside the Factory's site. Generally, they put a link to this purpose. If not possible, try a search section in Google, using words like: "serial number" age piano Kawai, changing the Kawai word for the name of the maker of your instrument.
Aug 24, 2014 | Music
Piano age by serial number How old and what value
Sorry, but at the very least, we need the BRAND of piano, style, and model number.
Jul 19, 2014 | Piano Showcase Kohler & Campbell Piano...
My components: WindowsXP SP3 DMX6fire 24/96 (Sound Module, not USB) Kawai Digital Piano CA71 (with Kawai's driver for USB connection to computer) Dear Sir/Madam, The driver for the above...
By now you know you have a driver issue. I am going to point you to a site that will correct your issues and should get you going again. Go to Reimage.com. The software will cost you $69 for one licence and if you have 3 PC's then by the 3 pack for $99. Why do I point you here? Easy your time is worth something. Don't waste it guessing. Driver crashes are the hardest to solve. You don't know what the conflict is or what DLL is corrupt. I use this company to fix clients like you. The end result is always a happy one. You should do a disk repair under properties of the C drive and then a defrag. Too many blue screens leaves the drive in a mess. If there was a better answer for you I would tell it to you but I think your better off with this company product. It is the real deal for repair. Good Luck.
Jun 28, 2011 | Microsoft Windows XP Professional SP2
Garmin n?vi 750 GPS - Piano Black Logo
662 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
