Question about JVC AV-48WP30 48" Rear Projection Television
Red lamp gives off ghostly blurr
When I look in the red lamp the picture is not clear. it looks like a bad tv reception from an antenna. on the screen it gives a double vision in red
  • eicdog Dec 31, 2007
    How do I replace the STK IC, where do I buy a part?
    Could you please tell me the part numbers Of the Red Convergence IC and the part numbers of the STC IC When I looked at the part store on line there are tons of IC's
    Genius:
  • 1,694 Answers
Red convergence IC is bad...replace both STK IC for durable,
long-lasting repair..............................T.
Posted on Dec 26, 2007
  • Vista Electronics Dec 31, 2007
    1) Look inside on large heatsinks..verify STK392-110 's
    2) Replace with Brand name only ! JVC,PAN,NAP,etc.
    For upgrade, I use STK394-160 HITACHI PART # CZ 01341
    3) Check B+ feed resistors located near IC's (burnt ?)
    4)Reassemble....activate magic focus.....
    ......................................T.
My Sanyo Vizon 32 inch flat panel has times when part of the picture becomes a "white ghost". How do I adjust?
Actually that is quite a rare case on today's modern digital flat panel TV's. You're not saying where you live, and you're not saying if you have previous issues on older TV you had before digital, and (again) you're not even saying whether you're on a hill or deep into a gorge. No TV has ghosting these days, but if you're living in an area as above, go see the TV people and they will probably recommend a set top box. But that isn't really necessary if you have a modern flat screen TV because most of these TV do two things, they give you a crystal clear picture or they don't. Digital TVs have a channel searching system that does the searching for you, and, as the case may be, these only pick up the best channels that give the sharpest picture. Anything that is of poor reception they ignore, so you're actually missing all the channels available because of this ghosting issue. AN there is nothing to adjust on the ghosting, snowing and vertical or horizontal bars, etc. These issues are things from the past, e.g. old analog TV's.
Dec 28, 2014 | Sanyo Televison & Video
My Lg colour tv is getting these weird red and blue shadows that makes the picture looks like it's in 3d can I fix this?
thats called ghosting its usually down to your tv ariel try putting your ariel on a mast for a better clear reception.
May 05, 2014 | Televison & Video
Hi! I am experiencing the following three
Hi Rafael,
First of all thank you for posting your question here at Fixya.
Please confirm if the brand and model number above is correct.
Blinking of the the LED (yellow and blue) at the front panel indicating that the lamp door cover is not seated properly. This cover will engaged to a micro switch giving the signal to the processor, once it is in open position, the unit will not power up and will experienced that kind of blinking error code. Go back to the lamp door cover and ensure that it is properly seat-in.
3D, 2D, red/green/blue ghost on the picture and letters means that the convergence circuitry gone bad. Symptoms is not connected to the light engine. The faulty parts is the convergence chips(IC). This chips are mounted on the large aluminum heat sink and starts with STKXXXX-XX (X means number). The most common STK chips used on Projection TV's is the STK392-110. You have to replaced them both on the board to resolve the issue(red ghosting). It is necessary also to check the resistance value of the resistors around its circuitry using the multimeter. For more info how to repair a convergence problem, watch the video below.
Jdvillanueva
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
Ok here you go, I needed to replace my lamp on my Sony KDF-50E3000, lamp XL-2500. Easy replacement, however now only the picture is HD and any words, at the bottom of the screen are blurry. The blurr...
Only getting HD has nothing to do with a lamp change. I would start by seeing if your antenna settings got changed. For example from cable to over the air antenna. As far as the blurry words on the bottom of the display, I think you didn't get the screen lined back up all the way.
Apr 05, 2011 | Sony Televison & Video
My tv antena is broken and i ma trying to assembe the cable to the thing that goes into tv. Any instraction please? The tvcable is not conected to the conector which goes into tv. I peeled the placstic...
Hello
If your TVs internal telescopic antenna has broken, you can us an external antenna from connecting to the rear antenna socket. For that you have to buy some extend of antenna cable, and a yagi antenna; as it is better for reception. If your TV screen size is 14" or below, a small wire of length 2 mteres or so is enough. Buy one Balun coil assembly fro electronic sparepart shop, and connect this wire to it, connect it to the antenna socket at the back of the TV, and with picutre just wave it to some side where you get the maximum picutre clarity.
If you TV screen size is more than 14 inches, external yagi antenna shoud be used for claear transmission reception, and it must be directed well towards the tranmitter also. Alaingning it is a trial and error process, at which position you gets the clearest picture, without any Ghosts. OK.
Dec 29, 2010 | Philips Televison & Video
My 2 year old Toshiba 42hl57 has developed what I can best describe as a ghosting problem, small white lettering appears with a clear shadow to the left of the lettering and some lettering seems to flare,...
LOOKS LIKE U HAVE RECEPTION PROBLEM WHERE U LIVE......IF U USE A INDOOR ANTENNA MOVE IT AROUND UNTIL U GET A CLEAR OR BETTER PICTURE OR BETTER CONNECT TO A OUTDOOR AERIAL///////
IF PROBLEM PERSIST GO IN CONTACT WITH TOSHIBA SERVICE CENTER
Nov 19, 2009 | Toshiba 42HL167 42 in. LCD Television
Ghost on the screen one is a circle in the middle of the screen, the size of a quarter, the second is a black could the size 2"x 5"
Usually when you get this "ghost effect" the caused by signals reflecting from large buildngs.To improve move antenna for best reception or install an aerial wit a small pick up front print.
Or check you have the correct aerial for the tv installed.
Nov 02, 2009 | Protron PLTV-32 Television
Toshiba 32'" tv wont give sharp picture
no rocket science here - my son fiddled with the cable cord attachment, until presto, the screen became sharp. Then we moved away as fast as possible, lest we shifted it and it put us back at square one.!!
Jan 26, 2009 | Toshiba 36A50 36" TV
GB4308 Ghosting
The cost I don't know, but this can be fixed. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Jan 02, 2009 | Apex Digital GB4308 43" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
