Question about Ruud Central System Air Conditioner
Tempstar central air conditioner The AC unit is not comin on How can you tell if the unit is bad
  • 40 Answers
Check to see if you have a safety cut off switch installed on your inside unit's drain line. if so, pull it out or unscrew it they are easy to access the little float switch that will cut your unit off if the drain line is clogged.
most of the time this is the cause of a unit not doing anything at all.
if this does not work the next step, if nothing is happening at all, is to open the inside unit and check for control voltage (24v).
Posted on Oct 10, 2009
Tempstar indoor outdoor central air unit is so noisy you can't hold a conversation. any lubricant's i could use and where.
I'm assuming you have an air handler that is inside. Turn the power off and make sure there is nothing that the fan is hitting. If not the bearings are probably bad. These motors are sealed and cannot be lubricated. You will need to replace the fan motor.
Jul 16, 2016 | Heating & Cooling
What kind of refrigerate does a 2003 tempstar central unit use?
it will say on the face plate on the outdoor unit they made units with both r-22 and 410a froen at that time please give me a rating and a vote
Sep 20, 2010 | Heating & Cooling
Tempstar air conditioner CA3036VKA1 will not run. Is it too old to fix?
My exact Compressor. Each year for the past 4 I have had to replace the AC push on connectors inside the unit. The compressor connectors are corroded and hard to get good contact on.
Jun 27, 2010 | Heating & Cooling
Tempstar phad42n1k1 heaters come on in ac mode and compresor or fan wont run in heat mode. was able to make heatpump go in defrost mode and compressor runs.
sounds like u have the thermostat wired wrong or bad wires i would check that first make sure you have the wright thermostat
Jan 05, 2010 | Ruud Central System Air Conditioner
Tempstar High efficiency 5000 It is not blowing enough cold air
if the unit has cooled fine in the past then it is most likely dirty you need to look at the return side of coil,you may be able to look thur your return grill.if it is dirty it is best to call a a/c service company to clean it for you,what ever you do,Do Not clean with a brush it can damage the coil and cost a lot to replace.also check your suction line at outside unit,it the big line it should be sweating if not it can be low of freon. Average cost to pull and clean a coil is about 375.00 no more then that.
Aug 12, 2009 | Ruud Central System Air Conditioner
No air blowing inside the house thru vents;starts fine than stops
You are likely low on charge and the unit is freezing up. You need some with gauges to check. You should not try to run this unit until then or it will burn out the compressor.
Jul 18, 2009 | Ruud Central System Air Conditioner
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Wiring Diagram for a Emerson Motor in a Tempstar Central A/C
EMERSON 1/4 HP MOTOR 5 WIRES BLACK BLUE BROWN WHITE RED LOST MY DIAGRAM 115V1075 RPM 3 SPD HOW DO I WIRE IT TO THE COMPRESSOR
Sep 26, 2008 | Emerson Heating & Cooling
Ac heat carrier thermastat model no.hh01ad042
GOto the iside unit itself. and remove the door and look for a terminial strip that the thermostat wires from the thermostat connects to and write down the colors wires and the letters they're connected to and connect the same to the thermostat .... they should be... r--red=power w-white=heat y--yellow=cool g-- green=fan! See which wires/ colors they're not using and bend back! Thank-you-very-much!
Aug 31, 2008 | Heating & Cooling
Ruud Central System Air Conditioner Logo
373 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
