Question about Microwave Ovens
FRANKLIN CHEF FIM-90 ICEMAKER STOPPED MAKING ICE SO I SERVICED IT BY FOLLOWING THE CLEANING ISTRUCTIONS BY USING NU-CALGON . CLEANED THE SUMP, SPRAYER ARM INSIDE AND OUT, SLIDEWAY, ETC. IT DID HAVE QUITE A BIT OF CALCIUM BUILD UP IN THE SPRAYER ARM AND JETS BUT EVERYRTHING THING IS "CLEAN AS A WHISTLE" AND IT STILL WILL NOT MAKE ICE. ONLY PUTS OUT ABOUT A DOZEN OR SO VERY IRREGULAR CUBES OVER NIGHT WHICH IS WHAT IT WAS DOING BEFORE I SERVICED IT....PLEASE HELP!!
  • 313 Answers
Hi my name is Randy, I have a few things for you to check.
  1. Clean the condenser, the dirt build up often causes poor ice production.
  2. Clean the bin drain
  3. Make sure the ice maker has room to breath.
  4. Make sure that is is getting enough water. Take the water suply off and see if you are getting good flow.
The condenser is usually the problem. Give these thing a try and see how it works. Let me know.
Thank you for the chance to help,
Randy
FixYa Support Team
Posted on Oct 08, 2009
Magic Chef MCO160UQ Carousel turning slowly
The turnable motor is going, the buzzing indicates the magnetron is about to fail. I suggest using the microwave oven until it dies and replace it, not cost effective to repair.
Apr 14, 2012 | Magic Chef MCO160UQ Microwave Oven
I have a Kenmore refrigerator model#106 56562400 and my icemaker is not working.I cleaned my refrigerator on 8/24/11 and since then the ice maker has stopped working.My refrigerator settings are as per...
Is the arm (on/off) switch down into the tray? You may have moved it up during the clean operation and inadvertently shut down the ice maker. Your temps are perfecto.
Sep 23, 2017 | Kenmore Microwave Ovens
My GE Monogram ZDIS15CSS ice maker fills the bin with water but does not pump water over the plate to produce ice. We did drain and shut unit down for 2 weeks and it would not start on our return. Can...
I would check the ice level sensor... it is shown on page 9 of this manual...
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60440.pdf
If the sensor thinks that the bin is full it will not do anything...
That is why that would be my first area of interest..
heatman101
Mar 24, 2011 | Microwave Ovens
I have inherited a Kenwook Chef with various attachments that I would like an instruction manual for.
Try this site. It even explains how to make Ice Cream with your Chef, mmmmmm ice cream...
http://www.kenwoodworld.com/uk/Products/Kitchen-Machines/
I'm off to make some in my Kenwood Chef now.
Dec 14, 2010 | Microwave Ovens
When I try to change the power level on my Magic Chef microwave, it only lets you put in one digit. How do you make sure its on 100% or 50%?
The oven always starts at 100% power. When you enter a power level from 1 to 9, the control board reads it as 10 to 90% of full power. So power level 5 is 50%, 3 is 30% and so on.
Nov 27, 2010 | Magic Chef CMV1000B Microwave Oven
Not making ice. water is getting to the water dispenser but don't know why it is not getting to the ice maker itself. how do i check it/repair it.
Hia and wl;ecome to FixYa, I am Kelly.
We really need a make and model number to provide you with specific unit applicable information but.... in general, here goes:
1. Ice makers must have a freezer temp below 16 Deg F. If there is an airflow problem in the freezer caused by a fan or ice build up the ice maker will no longer make ice.
2. The ice maker has a thermostat that controls the harvest and fill cycle. If the thermostat fails it will stop making ice.
3. There is a water valve in the back of the unit that has TWO electric solenoids on it. One for water in door and one for ice. If a solenoid fails it will stop providing water to the applicable function. I.e water in door or ice. You can briefly remove the fiberboard back cover to gain access to the water valve. Then switch the installed terminal connection between solenoids. Left to right or front to back depending on how it is mounted. Then try the water in door. If water flows to the ice maker when water in door switch is actuated then the solenoid for making ice is good and the probem is with the icemaker. (Reconect wires in original positions.)
Note that anytime you remove power from the unit you must wait 10 - 15 mintues before re-applying power so the coolant system can stabilze. Other wise the compressor will not start.
Here is a web link that will help most people troubleshoot ice maker problems:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The link above is pretty good.
There is a 48 page job aid also for whirlpool in door ice that is also a big help:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
This should help you find out why it is not making ice.
Thanks for choosing FixYa,
Kelly
Oct 26, 2010 | Microwave Ovens
Magic Chef MCO 153 UQ heats but doesnt' turn
You can still use it, but must be aware that this is a relatively high power microwave, so food will burn if it isn't turned.
Jul 28, 2009 | Magic Chef Microwave Ovens
Over the Range Microwave Oven
my microwave oven have inside a a metal papel i remove becouse sparks when turn on .this pece of paper is necesari
thanks
alexas
Jun 15, 2008 | Magic Chef MCD1311ST Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
