Question about Philips Magnavox 51MP392H Rear Projection Television
60 inch phillips magnavox projection tv
How do i drain crt coolant and what are the steps for replacing the fungus/mold from the 3 color tubes ritab@gorge.net thanks Dave
  • 2 more comments
  • TEJANO1971 Feb 07, 2008
    SAME THING
  • Stan Dilley Aug 01, 2008
    I have a Philips/Magnavox 9p6031 C103,SN: 50467605, 60" projection TV,
    that I believe has fungus in the coolant. I have too much red and the edges of the screen is very red. White areas
    "bleed" white into surrounding black areas, which becomes much worse
    when I attempt to bring up the Blue and green to offset the red. The
    screen is also too dark. I would appreciate instructions
    on replacing the coolant fluid. Does this include sterilization, to
    kill remaining fungus, before replacing the fluid?
    that I believe has fungus in coolant. I have too much red and the edges are very red. White areas
    on replacing the coolant fluid, please include instruction for sterilization, to
    kill remaining fungus, before replacing the fluid.
  • dalyle Aug 18, 2008
    I also hav ehte same problem Anyone out there that can give us info?
    Problem Solver:
  • 4 Answers
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
Posted on Jun 29, 2009
I have a 60" rear projection tv and the picture looks like its missing a color the picture isnt distorted or anything but the colors are bad what could be the cause and the fix
sounds like a Phillips or magnavox that has bad CRT coolant which needs replacement. If so you can get the Phillips CRT coolant repair kit from www.tvrepairworld.com it comes with instructions and the coolant for all three CRts,
Mar 01, 2013 | Televison & Video
Philips 60PW9363 60-Inch Widescreen HDTV-Ready Projection TV discolored. possible crt fluid issue??
Thats sounds like the classic sign of CRT coolant needing to be replaced you can get the phillips CRT coolant kit from www.tvrepairworld.com and it comes with the coolant for all 3 CRTs and the instructions
Nov 08, 2012 | HP Philips 60Pw9363 60-Inch Widescreen...
I have a 52 or 55 inch phillips magnavox ptv 805 rear projection tv but the color isnt right on it everything else works fine i can see the picture fine but its just the color what can i do
Thats a common problem caused by the CRT coolant needing replacement. The Phillips CRT coolant kit is available from www.tvrepairworld.com which contains the coolant and the CD with instructions.
Jun 30, 2011 | Televison & Video
Picture faded model number is fp4620w103
This sounds like the coolant fluid needs to be changed - the coolant turns milky after awhile and you'll get a dull image.
Google TV repair world . com and look for philips/magnavox coolant replacement:
PHILLIPS CRT Coolant Replacement Kit This is the complete coolant kit for Phillips CRT rear projection televisions. Kit contains 48oz of top quality High purity optical grade coolant with complete detailed instructions produced in clear easy to understand terms with detailed photos and illustrations that takes you through the process step by step safely dischargeing the CRTs and eliminating the need for complete realigning proceedures.Restores the vibrant colors and focus issues commonly associated with coolant that needs replacement
Oct 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
"Halo" Effect
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 19, 2009 | Philips Magnavox 55P9271 55" Rear...
60 inch philips big screen, fluid accidently drain out .
Yes you sure can , call electronixs 1-800-223-3205 ask for projection fluid/high purity.
Dec 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60... Problem
You need to change the coolant in the CRts ( picture tubes) you can get the Phillips coolant replacment kit at the following link with the coolant and the instruction CD with step by step instructions on how to do the replacment with pictures. Its listed under the repair kit category. Heres the link.
http://servicemanuals.vstore.ca/
Aug 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnovox 9P5531 C102
you need to change the coolant in the CRTs. Thats a common problem with the blue and green CRT in phillips magnavox rear projectionsIt makes the color and clarity as good as new after the coolant has been changed. If you need more info let me know, as there is a kit that has the coolant for all 3 tubes and CD with the step by step instructions with pictures available.
Jul 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 51MP392H Rear Projection Television Logo
1,068 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
