Question about Maytag Neptune MAH5500B Front Load Washer
Washer over fills and water comes out the door. Water continues to run even durring the pump out cycle just before the spin cycle
    President:
  • 632 Answers
  1. Water inlet valve. It may not be able to shut completely when the electricity to it has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow. Remove the washer's cabinet to access it.
  2. Water level switch. This switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the air pressure in the tube increases and activates the switch when the water reaches a certain level. When the switch is obstructed, it cannot tell the water to shut off and the machine overflows.Clear it from any obstruction.
  3. Air-hose. It is connected to the water level switch through a tube. If the tube or hose is cracked or broken, no enough pressure builds up to trigger the switch and shut the water supply off. Check it for any obvious damage.
Posted on Oct 08, 2009
Frigidaire Affinity front load washer model # FAFS4473LW . The washer tries to drain during when clothers are not being washed. This happens at all times of the day or night. Setting all of the washer...
Washer fills with water then drains:
My advice is free because God is so good!
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
May 09, 2014 | Frigidaire FAFS4473LW Washer
KENMORE DISHWASHER, WATER CONTINUES TO FILL AFTER WASHER IS SHUT OFF.
You're correct you have a faulty water inlet valve. At the end of the wash cycle the solenoid in the valve is not closing properly to not allow water to re-enter the tub. For further assistance with this repai
Jan 21, 2014 | Computers & Internet
I have the LG wm2487h*ma front load washer.My washer is filling up with water when not in use. When I wash a load, the water does not go in the washer. Have opened the door thinking the wash cycle is done...
The problem would appear to be the water inlet solenoid valve.
The valve is not operating correctly for some reason allowing water into the machine even when switched off
Sep 02, 2017 | LG WM2487H Front Load Washer
My washer goes through the cycle but the cold
This sounds like your water fill valve is bad and will need to be replaced.
Feb 01, 2010 | Maytag LAT2300 Top Load Washer
WILL NOT STOP FILLING
Hello Friend, You either have a bad water level/pressure switch or your water inlet valve is bad. If you unplug the washer from the wall and the water stops filling the washer then it's not the water inlet valve. If it only continues to fill when wash cycle is started then you will need to replace the water level/pressure switch behind control panel. This should solve your problem. Happy to help, Tim.
Jun 30, 2009 | GE WHRE5260E Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer won't stop filling
if you can turn the washer off while it is still filling. and the water continues to enter the machine you have a bad inlet valve.
Do me a favor turn the washer to fill, with the washer still running unplug from the wall. If the water is still entering the unit you have a bad inlet valve
Jan 05, 2009 | Roper RAS8445KQ Top Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Dec 28, 2007 | LG WM-2277HW Front Load Washer
dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at catriver1@gmail.com Catriver..post back.
Feb 19, 2007 | Maytag Performa PAV2200
Maytag Neptune MAH5500B Front Load Washer Logo
200 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
