Question about Maxtor One Touch III 500GB FireWire/USB2.0 External w/16M buffer Retail ****... 500 GB USB 2.0 Hard Drive
Maxtor not able to connect
When i try to start up for back up,the screen reads windows encountered a problem and needs to shut down i tried to take out the program and relod it,still same problems thanks
  • 180 Answers
Posted on Jul 28, 2008
I did complete install to windows 7. Now when I shut down, closrs windows,then blue screen comes up (can't tell what it says,goes to fast to read all)
Disconnect printer,/scanner, camera, USB stick connected to the computer. Try to start it in safe mode by hitting F8 key at the start-up.
Jul 08, 2013 | Computers & Internet
Computer does not recognize Maxtor OneTouch
Sounds like you need to remove the cable, uninstall the software, Restart, and then shut down. Now, from a cold power off power on. I know this seems tedious, but it has to do with the Last Known Good Recovery File and what is in Device Manger.
Now reinstall the software and if the software should call for you to "now" connect the USB cable, do so only when prompted or when the installer is done. Re: the latter, attach the cable. Windows ill say it discovered new hardware, point windows to your CD drive where the installer disk is located and allow Windows to locate the software.
Shut down and restart and your drive should be recognized now when you have a desktop. If not, post this back using the comment box below.
When replying to mine or anyone else's reply please address us in your reply, such as Worldvet: that doesn't make sense, please explain. And so on and so forth. This allow US to track what you've tried and from whom you were provided the solution.
Thank you for you indulgence on this. And, please be aware that, we all here want to see you fixed up and on your way. We all have a pretty good track record. However, there are times when a repair from a warranty service center is the only solution. However, I'm certain we all can get you taken care of and thanks for using Fix Ya.
Aug 06, 2008 | Maxtor OneTouch II external hard drive...
When I try to turn on my laptop, it starts loading and freezes while loading files. then the "Windows Boot Manager" screen appears and it reads, "Windows has encountered a problem...
Please make sure all devices are connected to your computer properly. Access it in safe mode and I am sure it would run, in in the safe mode just clean Windows registry database using some reliable software such as Reginout Cleaner. After cleanup process, start your computer normally.
Hope it would help you.
Jun 01, 2011 | Toshiba Satellite P205D-S7802 Notebook
Trying to get my maxtor II to work with windows 07 software but it wont read the usb connection? After i have installed the software for maxtor.
Check Control Panel, System, Device Manager and make sure windows see's the connection. If you see a yellow triangle, that means the drivers are not correct. If you don't see it at all, that is a problem. Give Maxtor a call. You may need to update your motherboard bios, chipset drivers. At worst, you might have a problem with the motherboard or maxtor II device.
Feb 26, 2010 | Maxtor Shared Storage II N01R010 1 TB USB...
My laptop had window on screen that said windows encountered a problem and automatically shut down. i rebooted my computer and now i can't get the computer to start up again, i type in my password and the...
Go and try to start on safe mode and see if you have any error or new driver that need to be removed...remmber what you did last as new update, new software, new setup, etc. and start from their...if not try the function recover to put the computer to the last good date...good luck
Sep 09, 2009 | Computers & Internet
Computer (thinkpad T40) shut off abruptly, and now won't re-start
your windows files are corrupted try reinstalling your windows or try a windows repair
Aug 26, 2009 | IBM ThinkPad T40 2373 Notebook
Blank/black screen at power on
This is hopefully a possible fix. I have encountered a similar problem with windows xp and vista. the fix I found that will eliviate this problem and a startup-reboot-startup-reboot... If you have your original windows (xp or vista) CD lounch it like you would do to do a system install. As the installation starts it will show ask you if you would like to do a recovery using the recovery console, just press ESC and go on. Press the F8 to accept the license. If Windows is not completly broke, it will find the original installation on your hard drie. It will ask if you want to repair. Press the R key and windows will reinstall your operating system, without destroying your software or data. After it is done the system will go to the windows startup screen. You will need your windows product key located on your machine or on the original software packaging.
I hope this will fix your problem.
Mar 17, 2009 | Dell Inspiron 6000 Notebook
Windows start up failure
Sounds like you could have faulty RAM or your HD has bad read/write sectors on it. Difficult to say without swaping out parts. Take it to a shop so they can figure out what needs to be replaced.
Sep 08, 2008 | Microsoft Windows XP Home Edition
Maxtor One Touch Mini Issue
Somehow find another XP system to test your MAXTOR. I would suspect a connection problem with the docking station and/or a USB PCI card compatibility issue. PCI USB expansion cards are notorious for chipset/driver related problems.
Nov 29, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Just got a Maxtor MaxAttach 4300 used and need to reset to factory...
Since no one has posted on this I?ll give you my best guess. Disclaimer, I don?t have one of these, Maxtor is now owned by Seagate, they have discontinued support and I can?t find a manual. Having said all of that from what I?ve read this runs Windows 2000 server and allows you to physically connect a keyboard, mouse and monitor to it. I would try connecting these external devices to the box, boot up and try logging in. If you literally don?t know ANY of the passwords you can try booting the system with a utility tool that will find and remove the administrator password. There are several of them readily available (usually Linux based) available for free, here is the link for one: That will allow you to log into the operating system and configure it as you wish. Be aware that this is not supported by Microsoft and could wind up corrupting the operating system. At that point the only option would be to rebuild the server software from scratch. Good luck and let us know how it goes or if you have any other questions.
Mar 13, 2007 | Maxtor MaxAttach NAS 4300 (E640DAA) 160 GB...
Open Questions:
Maxtor One Touch III 500GB FireWire/USB2.0 External w/16M buffer Retail ****... 500 GB USB 2.0 Hard Drive Logo
114 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
