Question about Shimano Cycling
Unable to select bottom gear shimano 100gs
Unable to select bottom (lowest) gear Shimano 100GS - looking for range adjustment?
  • 484 Answers
Here is a link to a tech sheet for a Shimano Deore rear derailleur. It is not your exact one, but all Shimano derailleurs are more or less the same. Make sure you have thoroughly cleaned your drivetrain with a degreaser (like Simple Green) and a brush to clear all grease and debris before making adjustments. The second step is to shift into your highest gear (the smalles cog) and then release the cable in the derailleur, pull taut and retighten it. Check again to make sure you can not get into low gear, because it may have been a problem with cable tension, which you just fixed. If it still does not, then adjust the "L" setting on the derailleur so that the jockey wheel on the derailleur will move just ever so slightly past the last cog on the cassette when the shifter is fully engaged.
Hope this helps,
matt
Posted on Oct 08, 2009
Can i adjust this to allow backpedaling?
There can be many reasons that you are not able to smoothly backpedal, none of which have to do with a specific derailleur. The derailleur could be out of adjustment or bent out of alignment, the chain could have tight links, you may be in a gear where the chain is at a big angle from front to back, the rear cogs (cassette/freewheel) might be sticky, etc, etc. Impossible to diagnose and fix without much more info, and even then very difficult to do so remotely.
I would strongly suggest you get a diagnosis by a bike shop, a friend who is experienced in bike repair, or if you have a bike co-op in your area they can both determine what is wrong and help you fix it yourself.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Apr 07, 2017 | Shimano Cycling
How to replace front cable shimano comfort 050 ?
Put the bike in the lowest numbered gear, put chain on smallest spocket/chainring. Disconnect cable from derailuer, pull cable, then replace with a new one by following steps in reverse. For detailed pictures, go to Utube or sheltonbrown .com.
Sep 01, 2014 | Shimano Cycling
Adjust cycle gears
Chain shifter or derailleur is improperly adjusted. Take to nearest bike shop for service
Aug 05, 2014 | Shimano Ultegra BB-6500
Shimano 200GS STI, upshift lever moves freely but when released, it returns the derailluer back to the lowest gear. How do you take the shifter apart?
"Upshift lever" could be either one since they both shift up or down.
I'd make sure it's a lever problem before embarking on that project. Is the cable actually being controlled by the lever?
A simple web search for "Shimano 200GS STI assembly" yields all kinds of resources.
Another good start would be http://www.shimano.com/
Other web searches like "how to.." work, too.
Aug 02, 2011 | Cycling
I have replaced the cable on the 7speed Shimano SIS derailler and Ithink I ran the cacle through the shifter wrong. I can only get three gears to shift. This is a combo brake and shifter handlebar mount.
All shimano derailleurs have two small screws located on the mechanism itself that allow you to adjust the position of the derailleur relative to the gears. The top one adhusts how far towards the wheel the chain can go and the bottom of the two adjusts how far towards the stop it goes.
Put the bike on a stand or just prop it up so the rear wheel can spin freely when you turn the pedals by hand
Put the shifter in the highest gear and turn the pedals, the adjust the top screw until it enters the top gear, you may need to adjust the cable tension also to do this.
Once you have it going easily into and out of the top gear adjust the bottom screw so that it easily goes into the bottom gear.
You should be done! Don't forget that for the first few rides the cable will stretch out a little so you may need to tinker with those screws a couple more times.
Hope this helps:)
This website might help you also http://sheldonbrown.com/derailer-adjustment.html
Jul 18, 2011 | Shimano Lx Rd M580 Rear Derailleur
I require an instruction manual on how to maintain and set the gears and brakes on the shimano alivio system which is on a giant strata 2010 mountain bike
Below is a link to the tech docs for the Shimano Alivio system look for the specfic componet you would like to adjust. The links with SI are the Service instructions. EV are the parts lists.
Shimano Alivio System info
Hope this helps.
Zeppelinx12
Mar 16, 2011 | Shimano Cycling
Shimano 105 flight deck diagram?
If this is not the diagram you are looking for, please check techdocs.shimano.com for the proper one.
http://techdocs.shimano.com/media/techdocs/content/cycle/SI/CycleComputer/SI-0045A-001_v1_m56577569830684407.pdf
Oct 04, 2009 | Shimano Cycling
Cycling Logo
2,202 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
john h
Paul Bade
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
