Question about Ultra Products Pride Go-Go Ultra 4 Wheel Travel Scooter - Blue
Battery will not charge, need a wiring schematic
  • Ultra Products Master
  • 1,263 Answers
Are you sure its not the charger ?
The connections are easy to follow, located the motor controller , normally a black box, now you 'll have have B+ B- make sure they are a good connection, make sure the charger connector is not faulty,
the batteries are then suspect, so can you try other batteries ?
Regards
GeWiz.
Posted on Oct 09, 2009
My 2003 rendevous is not charging, it has a neww battery and the alternator is good. What could be going on?
Check the fuses first. Ignition and PCM fuses. Check the big wire from the alternator to the battery. Check battery clamps. On any of these corrosion could and will cause no charging. After that, you need a wiring schematic. You'll need to check wires from the PCM to the alternator. The PCM is what turns the alternator on. If all those wires and cables check out good, you looking at replacing the PCM. 2003 is year specific. Meaning you can only put a 2003 PCM in it. The PCM also has to be programmed for your vehicle.
Feb 24, 2015 | 2003 Buick Rendezvous
How do i get a wiring schematic for travel trailer dc converter ?
contact manufacturer tech support they will help you find it and send you a PDF file of wiring make sure the battery disconnects are on off
Jul 30, 2014 | Holiday Rambler 2010 Presidential 36RET
Lumina wiring diagram
check the alternator.
Dec 17, 2013 | Cars & Trucks
Need Homelite Mower UT13122 wiring schematic to check switch problem. Battery fully charged
Check the switch for current flow with and without the key. Then make sure the ground switch is disengaging when you pull the handle.Possible stretched cable.
Dec 11, 2012 | Garden
Field wiring taps - wire 480 or 208 3 phase need schematic
Hi:
Follow the link for the trailblazer owner's manual, check section 10 for wiring schematic.
http://www.millerwelds.com/om/o4426ab_mil.pdf
If this was useful to you please vote. Thank you!
Feb 24, 2011 | Miller Trailblazer 302 Welder Generator...
Front panel audio connection to the asus motherboard
hokuwho,
you seem to have found what i seek. im looking for a schematic for my dell latitude d600 to determine which pins of the 9 or so pin battery connection on the mother board require which voltages and or resistances to both supply the 11.1v battery voltage to run the computer, and the other signals voltages resistances etc from the two circuit borads inside the battery case that tell the computer to use the perfectly good fully charged li battery cells or not depending on number of charge cycles. my batttery stopped putting the 11.1 v, it still has alive and well inside, out to the computer mobo, and has stopped charging, or so the computer says, eventhough its fully charged, and yet will not run the computer. i ordered another battery and know why dell in thier infinite though misguided wisdom decided to prematurely kill the good batteries to avoid possible overheating and exploding. but i want for my own knowledge to determine how they are killing the output and possibly design my own circuit that does what they actually needed and meant to do, rather than have the number of charge cycles rule. id just detect battery temperature and ability to charge, and eliminate any counting of charge cycles which is useless, and results in killing perfectly good batteries for no reason. do you know what numberds i actually need to find a schematic. each time i attempt to search with the computer model number, i find schematics of other mfgrs completely different equipment with d600 in the model number, or rar files i cant open, and usually with added notes that downloading this file can harm my computer.
i have always built my own desk tops and fear no electronic circuit but software and file suffixes and wanings of damage to my computer and various types of files apparantly engineered only to confound and confuse give me a little trouble. i started in electronics at a time when each simple circuit stage was built around a single huge glass tube the size of a body builders forearm. and now im working on entire computers with less surface area than one of those tubes. but back when those tubes ruled, manufacturers were trying to build the best longest lasting curcuits they could and drew schematics that actually were intended to be capable of being read by any good tech, and were easy to find with model number, of the equipment. given a schematic i can repair most anything but i cannot find the schematic. but current circuits are desigend to purposely fail for no reason that makes sense so the manufacturer can sell more to replace them, and schematic are well disguised not only in the way thier drawn and marked but even where they are located. ive learned to read nearly all schematics and interpret any schematic symbol, but locating schematics online and getting them to my computer, is difficult for me, eventhough i have desigened and built my own electronic circuits my self all my life.
Nov 15, 2008 | Computers & Internet
Acer Aspire 1360 d/c input port
I have the exact same problem, the dc jack port pin as come off of the motherboard circut..so I do not know where to even try to solder it. I hate their input jacks, the laptop, a Acer aspire 5570, is only 6 months old, and useless, because i cannot charge the battery or use the charger directly. What a poor design, designed to wear out. So I just end up buying a stand alone external battery charger online from www.portatechs.com at least i will be able to charge the battery and put it in the laptop
Nov 29, 2007 | Computers & Internet
Ultra Products Pride Go-Go Ultra 4 Wheel Travel Scooter - Blue Logo
280 people viewed this question
Top Ultra Products Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Ultra Products Health and Beauty Expert? Answer questions, earn points and help others
