Question about LG DR787T DVD Recorder
Can't pick up signal on the other room for my dstv
I ahve two television sets at home the one is down stairs and the other one is in my bedroom, the one down stairs is picking up dstv and the one up starirs is not pick up instead it is very snowy. what could be the problem with my connections.
  • 12 Answers
Chances are your problems lie with your connections themselves, most cases its with the splitter box if you are using one, if u are then rather remove the splitter box altogether, u will then need a set of RCA cables (the red white and yellow cables that come with DVD players) use these to connect the first point directly from the decoder to the TV using a free AV input behind the TV. form then on proceed to connect the cable going to the room directly to the RF OUT port behind the decoder (make sure the copper and aluminium wires dont end up touching, but use both, the copper on the inside and the alu on the steel outer casing) if this doesnt work check your connections and if all fails replace the cable as a last resort
Posted on May 03, 2010
Tip
Using a network extender at home
Network extenders and repeaters work to extended the range of your wireless network. You don't have to live in a big house to need an extender, where I live houses are made of concrete which makes the wireless signals a little weak when you're not in the same room as the router. I had played with the idea of getting another router to put upstairs since the signal wasn't reaching from the office on the first floor to the bedrooms on the second floor. But setting up the router and the network was going to be time consuming and I was just trying to make the signal reach a little farther. That's when I discovered repeaters, I set up one repeater at the top of the stairs in my house where the signal began to weaken and ta da! The network now reaches the whole house at full strength and I didn't have to set up a new network.
on Sep 17, 2013 | Computers & Internet
What can be the problem if my Dstv decoder model DSD 1131 doesn't have signal strengh or signal quality I'm staying in Pretoria how can I fix the problem
The best that I can give you is at this link:
http://hopeafrica.tv/index.php/component/content/article/40-schedules/202-dstv .
It should be noted that Africa does not have digital tv so you should probably hook an antenna to the tv without the box and have the tv search for analog tv stations as that will stand the best chance of picking up what few channels they do have.
Good Luck!
Rich Lilja
Jun 12, 2015 | Televison & Video
How much should i charge for painting a two bedroom apt. Inteior only. walls and cealing two bath one living room kitchen and laundry room
About 50 cents a square foot would be a reasonable price for a straightforward paint job (no stairs, cathedral ceilings or furniture to move).
May 28, 2014 | Measuring Tools & Sensors
I just purchased another RS120 to put in bedroom, have one in liveing room, the one in the liveing room works great but the one in the bedroom will not work, it will pick up the show from the liveing room...
is there a frequency channel selector on the headphone base, and on the headphones? the two pairs must be on different frequencies, or they will pick up the same show as the other
Oct 21, 2013 | Sennheiser RS 120 Consumer Headphones
How do video transmitters work?
A transmitter works by turning the audio/video device it is connected to into a audio and video signal broadcaster. So that when a receiver is connected to another device within range of the transmitter it will be able to pick up the signal from the transmitter and play on this second device. Say you have a TV in the family room and one in your bedroom, if you connect a transmitter to the one in the family room and a receiver to the one in the bedroom they will both be able to receive the same transmission.
Sep 08, 2013 | Televison & Video
Hi, I'm having problems connecting to the router (Virgin) to my bedroom from lost of signal strength, so i brought Sitecom Wireless Range Extender 300N to boast the signal. I've installed the Range...
1. did you first try to connect to the router via wire directly with it in the same room? then set up the wireless to work in the same room too.
2. once you've done that and it worked then move it to your bedroom. If it doesn't work there it could be that there is something inbetween the two rooms that is blocking the signal...ie a furnace can do that
3. if it won't work try relocating the router to another location. Try a different location in the same room first
but as i said , first get it set up and running in the same room so you know for sure it works.
Mar 21, 2011 | Computers & Internet
I have just purchased three First Alert carbon monoxide alarms. My home has a basement and bedrooms on the first and second floors. My questions stem from the installation. Should the installation...
When I worked Electrical in a Hardware store we were told by Nighthawk and f\First Alert and we told our customers that you want the detectors 4-6 feet off the floor never near a water heater or furnace since this can cause false alarms. The CO will rise, so one on each floor should be enough near a central stair if possible. Other wise make sure at least one is in the bedroom.
Mar 01, 2011 | First Alert CO400 Battery Powered Carbon...
Can't pick up channels itv, channel4/5 and itv2 on my bedroom freeview tv and down stairs doesn't pick up film4 and a few others?? I have only recently connected the bedroom aerial to the ariel which was...
hi when fitting an new aerial line you need to put a splitter in the line.
4963215_1-oo4k03phwtyaxld0gomgkgbv-2-0.jpg it looks like this. they say satellite/tv on them this will stop interference from the boosters and the tvs on the same line, you connect it on the main arial line. you can then use both boosters if signal is weak but most digital aerials are good enough without them. it you have the right arial for your area. there are meany sizes. but say you are 15 miles from your tower then use a small aerial has the same fitting as this pic. that is out side aerials, inside aerials ie in loft you need a high gain aerial , long type. hope this helps. also if the aerial is not lined up it will not get great signal there is an app you can use on iphone or androids, tables etc to help you position the aerial in the right place it's called Uk aerial alignment . tool on app shows you the towers in your area and the best ones to use and shows you the aliment to the tower for best results. good luck
Jun 22, 2017 | Samsung LE40R74BDX 40 in. LCD Television
I want to couple my DSTV Decoder through my new THT-3017HDMI Home Theatre System to the TV. How do I do that? I am very much technology disatvantaged.
THT-3017HDMI to hook with TV.
Get RCA Cables, red and white from your DSTV straight to your DVD.
The Yellow (Video) Straight from your DSTV to your TV yellow input.
Set your TV to Input 1 or 2 depending on the port you used. PLease but your volume will be only controlled via DVD, if you switch your TV off it will still sound the TV channels via DVD speakers,
Sep 03, 2010 | Televison & Video
LG DR787T DVD Recorder Logo
263 people viewed this question
Computer Repairing
Computer Repairing
