Question about Plumbing
I have some EVA (Ethylene-vinyl acetate) sheets that got soaked in Hydraulic Oil and absorbed it, therefore making it not usable because adhesives can no longer stick to it. Is there any way to rinse the hydraulic oil off the EVA sheets?
  • zobianenterp Oct 10, 2009
    Thank you for your tip, will try your solution...
  • 530 Answers
The problem with attempting to clean all the residue of the EVA is that most solvents capable of removing the oil will reactivate the resins and accelerators that make up the EVA.
However there may be a cleaner that will work. To acquire this "SUPER SECRET" compound you will need to brave difficulties best left to professionals. Most who attempt this undertaking do not survive. Those that do succeed are never the same. Hunted by nightmares and flashbacks. If you have even the slightest fear in your heart you should stop reading now.
If your still with me then let me say this, you are a great warrior and a credit to your kind.
The location: usually in the kitchen under the sink. The name: "DISH SOAP"
It may seem an odd choice but think about it, it breaks down oil and grease. It doesn't matter what kind of oil and grease.
I worked for Jeep and out of all the different chemicals used in the assembly process, dish soap is by far the most common.
To your specific issue, when a vehicle needed paint repair it would be covered by what we called a car condom. Basically it was a big EVA bag. It would cover the car and the area that needed paint would be masked off. The problem was that when any oil or grease got on the plastic it needed to be cleaned before entering the paint booth or really bad things would happen. We used dish soap and hot water (mix ratio of about 1/3 soap to 2/3 water).
It worked great and the masking tape adhered fine.
Hope this helps.
And for heavens sake watch out for the all powerful guardian of the dish soap. They eat any intruders would venture in to their kitchen lair :)
If you are unaffraid
Posted on Oct 09, 2009
What adhesives can be used over vinyl tile?
Most glue will stick to vynil tile however it is recommended to flash the floor with a b Portland cement leveler and make sure loose tiles are glued or filled
Jan 03, 2015 | Roberts 2 Gal. Wood and Bamboo Flooring...
Adhesive removal from vinyl floor
If you are removing latex adhesive from under a vinyl floor then just soak it with water and TSP to help attack it
Nov 30, 2013 | Cars & Trucks
E260 will not print labels
This printer has capability to print on labels. Here are some tips when printing on labels:
· Use labels designed specifically for laser printers. Check with the manufacturer or vendor to verify that the labels can withstand temperatures up to 210°C (410°F) without sealing, excessive curling, wrinkling, or releasing hazardous emissions.
· Labels can be printed at a higher fusing temperature up to 220°C (428°F) if Label Weight is set to Heavy.
· Select this setting using the Embedded Web Server, or from the printer control panel Paper menu. Label adhesives, face sheet (printable stock), and topcoats can withstand up to 25-psi (172-kPa) pressure without delaminating, oozing around the edges, or releasing hazardous fumes.
· Do not use labels with slick backing material.
· Use full label sheets. Partial sheets may cause labels to peel off during printing, resulting in a jam. Partial sheets also contaminate the printer and the cartridge with adhesive, and could void the printer and cartridge warranties.
· Do not use labels with exposed adhesive.
· Do not print within 1 mm (0.04 in.) of the edge of the label, of the perforations, or between die-cuts of the label.
· Be sure adhesive backing does not reach to the sheet edge. Zone coating of the adhesive at least 1 mm (0.04 in.) away from edges is recommended. Adhesive material contaminates the printer and could void the warranty.
· If zone coating of the adhesive is not possible, remove a 2-mm (0.06-in.) strip on the leading and driver edge, and use a non-oozing adhesive.
· Portrait orientation works best, especially when printing bar codes.
· Use only paper label sheets. Vinyl, pharmacy, and dual-sided labels are not supported.
For further assistance, please contact Lexmark Technical Support.
Mar 04, 2011 | Lexmark E260dn Laser Printer
How do i print onto acetate using an epson sx200; it doesn't recognise any paper... thanks
Some printers use a light sensor to tell if paper is loaded or not. If printing on clear acetate, try loading a regular sheet of paper under it. It should pull the acetate sheet through and leave the regular paper in tray. Since the Epson sx200 is an inkjet printer be careful not to smudge. I would allow a good 5 to 10 minutes to dry. Good luck!
Mar 01, 2011 | Office Equipment & Supplies
Where do I get more shredder Care Lubricant Sheets?
I usually make my own. Find out what type of oil it uses then soak a sheet in that oil and run it through the shredder. You can probably use machine oil like the kinds they use on sewing machines.
Found this on a site (4 ways to oil your machine, the other two are the sheets and oiler attachement):
1.) The old-fashioned way. The most common way to oil your shredder is by applying the lubricant directly to the machine's cutting head. It's easy to do this if your oil is stored in a squirt bottle. Just squirt some of the liquid on their entire width of the cutting head and then run the machine in reverse for up to a minute. Doing so will ensure that the lubricant is applied evenly. It will also cut down on the amount of dust in the machine. When you're done with that, run some paper through your shredder to absorb any excess lubricant. That's all there is to it.
2.) The zig-zag method. Another quick and easy method is by dampening a sheet of paper with the lubricant. To take advantage of this method, all you need to do is apply the liquid to the sheet in a zig-zag pattern and then shred it. Use the reverse mode on your device to ensure that the oil reaches all of the blades. If you want, you can repeat this process a couple of times to make sure your machine is fully oiled. Note: you don't need to soak the paper. Just make sure that your zig-zag covers most of the sheet.
You can find the complete article here:
http://www.papershreddertips.com/fellowes-shredder-oil/
Dec 14, 2010 | OfficeMax 0M96431 Shredder
The coating on the body of my glasses has become stickey to the touch
You don't state the make and model, but this is common on older models of binoculars, cameras and all other kinds of optical devices with rubberised coatings. Basically the coating is not as chemically stable as the manufacturers originally intended and has started to break down into a sticky mess. In most cases it only happens once the product has ceased production and when spare parts have become as rare as fresh **** **** . If this applies to your binoculars then there's nothing you can do to arrest the decay of the coating. All you can do is to carefully remove what's left, and sparingly use a solvent to remove what remains. Be careful what you use as many common solvents may attack other materials used in the binocular construction as well. If in doubt, careful use of a little vegetable oil is safe and works by preventing the rubbed off goo sticking back to the binos or to itself. To replace the coatings you may need to think laterally. I've used textured vinyl, blown vinyl, leathers (including sharkskin and fake crocodile) and various textiles, preferably those which are water resistant or which can be treated to become water resistant.. I've also used sections cut from old discarded truck inner tubes (much thicker than car or bike inner tubes). I've also had success by buying new bicycle tyres and cutting them up: the gaps between the tread blocks provide a good way of hiding **** joints between adjacent pieces. Usually I use those contact adhesives which allow a little bit of repositioning before they fully grab hold of the parts to be joined. Recently I've also been experimenting with silicone baking sheets; they come in lots of interesting colours, are really durable and relatively cheap, but it took me a while to find a suitable adhesive. I settled on clear silicone sealant, but it must be the type which does not release acetic acid (vinegar) as it cures other wise your binoculars will corrode. It's also vital to fully ensure that both surfaces are totally grease-free and that the rear surface of the silicone is roughened. I hope that my reply has been of some assistance, please return the favour by rating my answer.
Mar 05, 2010 | Bushnell Optics
Printing on acetate sheets with a epson dx7400
i had the same problem i solved this by sticking plain whitecopier paper to the direction strip with double sided sticky tape printed asultra gloss photopaper
May 15, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Shredder Malfunction
Unless you are going to take the entire shredder apart, you are not going to be able to get to the blades unless you were going to pour some kind of liquid adhesive removal into the blades.
This wouldn't be my 1st suggestion.
One thing you can try is, go to your local hardware store and purchase a pint or quart of 3 in 1 household oil. With the machine UNPLUGGED. **** Also I would place some sheets of paper towels inside the catch bin to absorb any excess oil that drips out. **** Pour the 3 in 1 oil into the blades and let it soak in. I would start with about 2- 4 ounces, then wait about 10 minutes to allow the oil to soak into the labels. Plug the machine in and try running 1 single sheet through the shredder. With any luck, some of the labels will either stick to the paper or drop into the basket. You might have to do this about 3-5 times.
** Remember to UNPLUG the shredder each time you are pouring the 3 in 1 oil on to the blades just as a safety precaution.
I hope this helps.
Please let me know if it worked or not and also post a feedback / rating for me.
Have a good day.
Mac =)
Mar 14, 2008 | Fellowes 3011001 Shredder
Plumbing Logo
53 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
