Question about Panasonic PT-47WX53 47" Rear Projection HDTV
I have red shadows on my tv. Just started all off a sudden. I have read in other places of a convergence issue. Is that easy to fix
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
Posted on Oct 08, 2009
snakehead
  • 1074 Answers
SOURCE: Red Shadow on scheen
your tv needs to be align take it to a tech so that the tv can get a convergence adjustment it is call color bleeding.these things when a set gets old this wil cost between 440.00 TO $75.00,in this the comb filter and the screen voltage will be checked.
Posted on Mar 30, 2007
SOURCE: Toshiba model 61HX70 convergence issue
I'm having the same problem where the red if out of line and will not calibrate. Which board controls this? Thanks for any help
Posted on Jan 15, 2008
circuitcity
  • 137 Answers
SOURCE: Blue Convergence
Hello All Above,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Posted on Jun 22, 2008
Ecollier2012
  • 3459 Answers
SOURCE: PT-53wx53g Convergence issue?
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 26, 2009
Ecollier2012
  • 3459 Answers
SOURCE: I have a sony Projection TV KP46WT510 convergence
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
Here are some photos of convergence problems.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on Jun 19, 2009
I have a 60 inch Mitsubishi and there are light red shadows in the tv. is this an easy fix
It sounds like you need to re-adjust your convergence. The purpose of adjusting your convergence is to align your red, green, and blue colors. Moving your TV often causes this problem. I hope you get it going.
Sep 02, 2014 | Mitsubishi WD Televison & Video
I have an Akai 42"
Its usually the convergence board just replacing the old board with a good one should solve the issue. You can get the convergence board for the PT4298 at the following link just scroll down the page. http://www.tvrepairworld.com/samsung__akai_circuit_boards
Jun 24, 2011 | Akai PT4298HD Rear Projection Television
Color distortion, hazy snowy screen with thin red lines, suddenly happened had perfect pic 24 hours ago
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi VS-50705 50" Rear Projection...
On the screen I see on the sides of every object a shadow, it,s green on the left side and red on the right side accompanied by some little horizontal red stripes. It started doing it all of a sudden a...
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Hitachi 65TWX20B 65" Rear Projection...
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
RCA projection is having color shadows and blurred picture.
Hi, this is failed convergence and it is due to a faulty convergence board chip set. simply replacing the convergence board in this set Will fix your issues.
May 21, 2009 | RCA HD52W56 52" Rear Projection HDTV
  • Screen looks 3D
Mar 02, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Image on tv casts a red shadow.
TRY THE MAGIC FOCUS BUTTON. IF THIS DOES NOT CORRECT THE PROBLEM YOU WILL NEED A SERVICER TO GO IN AND REPAIR CONNECTIONS OR REPLACE THE CONVERGENCE IC'S AND OR RESISTORS. AND READJUST CONVERGENCE IN THE SERVICE MODE.
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Red shadow on PT-56WX33G projection tv
The cheapest way is to replace both convergence Ics they are both STK392-110 and you can get replacements at the following link, and they provide free instalation instructions with pictures, plus free online instant messageing while you do the actual repair. Its a very easy repair. Here's the link.
http://servicemanuals.vstore.ca/
Jul 26, 2008 | Televison & Video
Tv has red
you need a repair tech. you probably have a bad convergence ic
Dec 26, 2007 | JVC AV-56WP30 56" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
293 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
