Question about Sony Televison & Video
Remove disc-C 13.02 cannot finallize,not format i have lost now many dvd
    President:
  • 1,653 Answers
You should be able to finalise any such disc by using the Roxio or Nero applications and then be able to successfully use the disc in the SONY.
Posted on Oct 08, 2009
Hi..I have a Panasonic VDR-D160GN video camera. I only know the basics of its use. eg, I know i have to format/initialize a new disc and have to finalize it before playing it somewhere else other than in...
When i have had that happen to a customer i have had to replace the dvd drive assy to take of the problem. Your videos on your disc should still be retieveable once the drive has been replaced, also ask for any firmware updates for your drive assy. I hope this helps
Sep 04, 2010 | Panasonic VDR-D100 DVD Camcorder
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
Finalize DVD
I have a dvd recorder with vcr it is a model # zv427mg9 we have lost our manual and do not know how to finalize the disc. We have transferred video from vcr to dvd and can't figure out how to finalize, please help?
Dec 22, 2009 | Philips Magnavox DVD/VCR Dual Player
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
I burned & finalized a DVD+RW with family
while u were burnin the disc which format of disc u selected.......if u selected data disc then some of the dvd players will not read those dvds..............u should not select data disc .................instead there r some options to burn the disc....it depends on which version of nero or the cd burner product u use
Oct 14, 2009 | Sylvania Televison & Video
Sony DCR DVD108 not finalizing disc, lost data
I noticed that too with my "VR" (and NOT "Video") formatted disks. I don't think you can finalize the VR ones. Instead you have to use the Sony Import tool to grab the videos. If you are like me you probably remember using the import tool with Video formatted disks BEFORE finalizing them and it takes forever to copy them. They must be finalized to view on other devices, copy using the import tool quicker, etc., but VR formatted disks seem optimized for importing (and can be edited on the camcorder directly.
Sep 26, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Cant finalize dvd on a magnavox zc320mw8
you have to push stop from the title menu, then push setup. Then go to disc edit and finalize is there
Jan 11, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Can't Record DVD's
use a different format dvd disc. try -R or -RW
Nov 30, 2008 | Cyberhome CH-DVR1500 DVD Recorder
Disc formating
Did you try A DVD LASER LENS CLEANER?
Mar 07, 2008 | Panasonic DMR-E50 DVD Recorder
I can't see the dvds into any dvd player
Most DVD players can't play DVD-R or DVD-RW unless it's finalized (if you record to DVD+RW, it may work ok, but fewer DVD players work right with RW format discs).
Obviously, you need to ensure you are actually writing to the DVD (eg, will they play back on the camcorder). You should see if there's a menu for finalizing the DVDs, that might do it. There are occasionally problems with finalizing discs on some of these DVD camcorders... these discs may not be readable on any DVD player, but might still work in a PC.
The other problem is that some camcoders record in DVD-VR format, which is a special "easily edited" format for DVD camcorders only... regular DVD players don't usually support this (well, some new ones might... this is one of those "evolving standard" issues). You'll probably need a PC to read the disc, edit, convert to a conventional DVD, etc. if you're using this format.
Jan 02, 2008 | Samsung SC-DC164 DVD Camcorder
Televison & Video Logo
18 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
