Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Husqvarna gth 2448t 48'' 24 hp riding mower 2007
Husqvarna gth 2448t 48'' 24 hp riding mower 2007 ,engine ignition shuts down when mower is engauged.Is there some kind of safty switch that failed???
  • 472 Answers
YA IT SOUNDS LIKE YOUR SEAT SWICH IS BAD THATS THE MOST COMON THING I SEE A LOT OF LET ME KNOW IF THIS HELPS YOU
Posted on Oct 08, 2009
Will the transaxle from a Husqvarna GTH 2448T Hydro Gearr part # 316-0610 bolt into a Husqvarna LGT 2654 that currently has a broken axle in a Tuff Torq transaxle
Yes, the axle will fit the frame, but the pulleys and idlers will need to be set up. There is no cross reference chart so you would have to create the belt routing by trial and error. Belt length would also have to be determined.
Aug 07, 2016 | Husqvarna Garden
Parts diagram for Husqvarna GTH2654 riding mower
go here and find yours,you need more info for the right one,i would of got it for you,but,i need more info too Model Search Results for Husqvarna GTH 2654 PartsTree com
Apr 20, 2015 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have oil coming from carburater , then mower starts to bog down no power, after it heats up for 15 min.
Without what engine you have I can only make a guess but it can be a couple things. Either the engine is full gas from a leaking carburetor or you have a blown head gasket.
Jul 23, 2014 | Husqvarna Garden
Model 2254 deck belt jumped loose, need diagram as to how it winds "top view"
hi there senator359
pauly46 here
please find web site for a manual that has belt roueting in it
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_O0802053.pdf
it is lgt2654
go to web site down load and print
here is husqvarna gth 2254 web site for diagram
http://www.partstree.com/parts/?lc=husqvarna&mn=GTH+2254+XP+(96023000201)+(2005-06)&dn=86020023
check them both out
let me know if helps
dont forget the thumbs rating
cheers pauly46
Jul 08, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Clutch adjustment
I had the exact same problem on my Husq 2148 which arose just after a new drive belt was put on. There is a cage around the front, engine, pulley which keeps the belt from flying off I guess. After staring at the belt for a long, 2 beers, time I discovered the repair guy had put the belt inside the cage on one side, where it is supposed to be, but outside the cage on the other side. This caused the problem you described and it ran much better in reverse than forward. If your problem arose after a belt change, I would start looking there, if not then I would check the 2 springs which keep back tension on the pedal. It took me 3 more beers to get the thing put on right.
May 30, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
2007 Husqvarna Riding mower blade will not engage when switch pulled out. Fuse blows & mower dies! Help!
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Apr 25, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna gth main belt keeps breaking
Make sure the mower rake angle is not too much,On level floor point one of the blades in a front rear orientation,measure height of blade from floor the front measurement should be no more than 1/4" lower than the rear measurement.If the front of the mower is too low the angle the belt has to run is too much and the belt will twist and wear rap[idly.To raise the front of the deck there are either one or two adjustment rods that attach the front of mower deck to frame tighten this adjustment up to raise the front of mower deck.
Jul 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
732 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
