Question about Dishwashers
Grinding sound when cleaning mode starts -- cleaned out the bottom -- found glass, but still making the same sound. This unit is about 6 years old
  • johnk3301 Oct 08, 2009
    Thanks for your response ! Yes - it is a maytag quiet series. Not sure if maybe the motor is going out ?
  • milten1
    milten1 May 11, 2010
    is this a maytag
    President:
  • 1,304 Answers
It is not your motor
it is you emacorator scapping on the screen
you probaly have something stuck down in the blades
if you have a t-20 wrench and are pretty handy you can fic=x it yourself
Posted on Oct 08, 2009
Testimonial: "Thanks a million !!! This helped me instantly !"
My unit is only 2 months old and its making a squeeling grinding bearing kind of noise in front of the the unit and its on the bottom where youu can feel the grinding on the outer casing. What could it be?
I had the same issue with my Soleus PAC unit making a squealing, grinding noise.
I took the unit apart to locate the issue and found out that the water pump on the lower right side was the issue.
I removed the water pump and used warm water and a little bit of dish washing soap along with a qtip to clean the water way.
Squealing stopped.
Not sure if this is the same issue with your unit - but it can be a starting point.
Just be sure to unplug the unit while working on it. Also be careful not to puncture the coolant lines.
Good luck.
Jul 22, 2011 | Soleus PH3-10R-03 10000 BTU Portable Air...
I have 48 " 6 burner stove natural gas.Stove is
the glass in the ovens should not crack when self clean is used. it could be that there was a minut crack in the glass or a build up of moisture in between to door windows that expanded at the extra heat but this should be brought up with the manufacturer for replacement.
I hope this was useful.
Jan 05, 2011 | Viking 48" 6 Burner, Griddle Professional...
A grinding sound coming from inside the camera (PanasonicHVX200A)
If noise occured during while OIS function is on,then must lubricate the axis inside lens underneath the ccd block.Due to friction of the movement of the coil used for moving lens for optical stabilizing function makes noise,but if this is not the problem, camera board must be next suspect,so first clean and lubricate and after ask service for cost.So generally speaking ,the problem is on the lens unit ,or the camera board which drives it...
Jul 15, 2009 | Panasonic AG-HVX200A Mini DV Camcorder
Saeco vienna saying brewunit blocked !
Hi There is a test mode for the Digital and we can see if you have a bad power board. Turn the machine off in back. Push and hold the small coffee button and the menu button (top left) at the same time and while you are holding the buttons turn the machine on. Release the buttons and you should have numbers in the display. If you can push the bottom left button and the machine makes a sound like the motor is moving, turn it off and then back on. If you don't get the message now you should really clean and lube your brew unit.
Jun 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
Diswasher doesnt clean and leaves
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
May 31, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Dishwasher will not go into wash cycle.
On the LG LDF6810 dishwasher, the best you can do is remove the bottom spray arm and then the 10 phillips screws that hold the filter down.
Pull the filter out and clean it as best you can.
Inspect the sump area beneath where the filter was. Be careful of broken glass and remove all debris. Use a flashlight and look into every little spot down there. Reassemble the dishwasher and operate your DW.
If you still have problems, I recommend a service call. Check your manual to confirm but most LG dishwashers have a 1 year parts & labor plus a 2 year parts only. Have your proof of purchase ready.
Apr 02, 2009 | LG LDF6810ST Stainless Steel Built-in...
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Goes into 'Self Test' after grinding the beans or even using the pre-ground mode
You have a power control board(PCB) problem. The machine is restarting while trying to make coffee which would be like you turning the power off then on again. The only way to correct this would be to change the board.
If you would like to order the board you can do so by contacting us at www.cerinicoffee.com
Gaggia Parts and Cleaning supplies from www.CeriniCoffee.com
Jun 10, 2008 | Gaggia Syncrony Espresso Machine
Brewing stops mid cycle
Sounds like dosage is too high and grind is too fine.
Rule of thumb with any saeco unit.
Do not grind any finer then 2 or your looking for trouble.
Open grinder, clean it out with a vac. Slapped it back on.
The reason it stops is grind is too fine, and the machine doesn't have enough pressure to pass threw the grinds, creates back pressure in the machine and the unit failsafes after a certain amount of time with and pressure.
Back pressure is what blew your boiler.
May 16, 2008 | Saeco Magic De Luxe Espresso Machine
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
Owen Barnes
