Question about EliteGroup P4VMM2 Motherboard
DVD/CD Driver I can,t play CD or DVD and I try to update driver but following was given: Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
  • 121 Answers
U have to get your registry fixed or windows, there is a problem in your windows registry, reinstall windows would fix the problem otherwise try updating the firmware of your dvd writer
Posted on Oct 08, 2009
Testimonial: "Many thaks for solutin"
Hi, The DVD/CD Rom Icon has dissapeared on My Computer. When I go to control panel - device manager and click on the dvd/cd rom drive icon I get the following message in the genaral...
You will need to re-install the driver. Right click the device in device manager and select properties. Navigate to the driver section and uninstall all existing drivers. (It may *not* give you the option to do that, depending on how corrupted the driver is, but it should.)
Reboot the PC.
Upon reboot, Windows should find the new device and install generic drivers. It will probably ask you to reboot a second time.
Apr 07, 2011 | LG GSA H62N Super-Multi - Disk drive - DVD...
Am getting error no 41 i.e my laptop is not recognozing my dvd
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Nov 25, 2010 | Philips (JR4DVDRWK/00) DVD+RW Burner
I cannot play a cd on computer tried setting info into windows media
If you cannot play a CD on your computer. Please try the following: 1. Make sure the IDE cables are properly seated in the CD Drive. Also try to reseat the power cable connecting your power supply to the CD Drive. 2. Make sure the CDROM is recognized by your system. To check if its recognize go to system properties then hardware. Choose Device manager and look for CD/DVD drives - check if it has a yellow question mark on it. If it has install a driver for that device or use windows update to update the driver. 3. If you can find another CD Drive. Try installing it on your system. 4. Install or update your windows media player. You can also use VLC player.
Thanks. Please rate. Let me know if you need further assistance.
Apr 29, 2010 | Computers & Internet
Hi: My computer is not recognizing my ts-h492a
Please go here and download the live update from Samsung. This software is designed to automatically update you to the latest firmware via the internet. To get this service, customers have to install the Firmware LiveUpdate program on their computers.
Please download the live update full version if you have not used this software before. See link.
http://www.samsungodd.com/Eng/Firmware/liveupdate.asp
Simply follow the instructions as given and your software will be updated to the latest version required to run your CD/DVD writer with your computer.
Hope this helps. If so please do leave a vote for the solution. Thanks.
Mar 01, 2010 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
I have 12 Drives All 12 Drives are found but when I burn a DVD The Some drivers fail and it is not the same ones all the time
Usually, a driver update is used as a solution to an issue with how Windows works with a piece of hardware.
Updating a driver can also enable new or updated features for the hardware.
To access Device Manager, use any of the following methods:
  • Click Start, click Run, and then type devmgmt.msc.
  • Right-click My Computer, click Manage, and then click Device Manager.
  • Right-click My Computer, click Properties, click the Hardware tab, and then click Device Manager.
  • Type the following command at a command prompt: start devmgmt.msc
You can use Device Manager to change the way your hardware is configured, and to change the way your hardware interacts with your computer's programs. With Device Manager, you can update device drivers for hardware installed on your computer, modify hardware settings, and troubleshoot problems.
Device Manager enables you to:
  • Determine if the hardware on your computer is working properly.
  • Change hardware configuration settings.
  • Identify the device drivers that are loaded for each device and obtain information about each device driver.
  • Change advanced settings and properties for devices.
  • Install updated device drivers.
  • Disable, enable, and uninstall devices.
  • Reinstall the previous version of a driver.
  • Identify device conflicts and manually configure resource settings.
  • Print a summary of the devices that are installed on your computer.
If the device is experiencing a problem, the type of problem is displayed. You might also see a problem code and number and a suggested solution. If you call a support line, this number can be useful for determining and diagnosing the problem.
How to install a new driver from Device Manager loadTOCNode(2, 'summary');
  1. Double-click the type of device you want to update or change.
  2. Right-click the specific device driver you want to update or change.
  3. Click Update Driver to open the Hardware Update Wizard. Follow the wizard instructions.
Rolling back to a previous version of a driver loadTOCNode(2, 'summary'); Use this feature if you encounter problems after you install a driver, such as error messages when you access the device, faulty behavior of the device, or even the inability to start Windows.
Windows XP provides this roll back to a previous, working, device driver:
  1. Right-click the device for which the previous version of the driver is desired and then click Properties.
  2. Click the Drivers tab.
  3. Click Roll Back Driver.
If you cannot resolve the problem with these instructions, contact the manufacturer.
Dec 04, 2009 | ASUS QuieTrack CB-5216AG CD-RW/DVD-ROM...
Code19 on sony cdrwdvd willnot reconize on inspiron 1525
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program or Windows Vista.
This issue may have occurred after one of the following situations:
  • You upgrade a computer to Windows Vista or install Windows Vista Service Pack 1.
  • You install or uninstall CD or DVD recording programs.
  • You uninstall Microsoft Digital Image.
You may see one of the following error messages:
  • One of the following error messages appears when you view the CD drive or the DVD drive in Device Manager.
    Error message 1 The device is not working properly because Windows cannot load the drivers required for this device (Code 31). Error message 2 A driver for this device was not required, and has been disabled (Code 32 or Code 31). Error message 3 Your registry might be corrupted. (Code 19)
  • An "error code 39" error message.
  • A message that resembles the following appears in the notification area: Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
  • you can find this information and more at this site..
  • http://support.microsoft.com/kb/314060
Nov 08, 2009 | Dell OptiPlex GX260 PC Desktop
My CDR/DVD doesn't work. I have a yellow ! over the hardware device. Using the Windows Add Hardware Wizard it shows that Windows has successfully loaded the device driver for the hardware but can not...
Hello, if looked this error code from Microsoft self, just have a lokk and see if you have tried all of these.
This problem occurs if you install a driver for a non-Plug and Play device, but Windows cannot find the device. Here are some things that you can try to resolve this problem.
If the Troubleshooting Wizard does not resolve the problem, do one of the following:
  • If the device was removed, uninstall the driver, connect the device, and then click Scan for hardware changes to reinstall the driver.
  • If the hardware was not removed, the driver files might be obsolete. In this case, update the driver from Device Manager. In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
  • If the device is a non-Plug and Play device, you may have to install a newer version of the driver. To install non-Plug and Play devices, use the Add Hardware wizard. Click Start, and then click Run. In the Open box, type hdwwiz.cpl.
If that doesn't work, i tried this program once at a frined of mine with the same problem as you have now and it worked perfectly.
Link below:
http://microsoft.pcerror.info/errorcode/code%2041.html?gclid=CMKowK-575wCFdYB4wodDjz1kg
Really hope hat this can help you.
Sep 13, 2009 | Dell OptiPlex GX520 PC Desktop
Driver/Firmware Problen on a Lite on CDRW
Here ya go straight off the Microsoft Knowledge Base. Geek Squad too lazy to research:
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41) Recommended resolution
4 diamonds pls
Mar 01, 2009 | Gateway 510 X PC Desktop
Cd drive showing instead cd-rw/dvd drive
Step 1: Unplug any cables that are connected loadTOCNode(3, 'moreinformation'); a. Unplug any cables that are connected to the video outputs of the computer. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 2.
Step 2: Update the DVD driver loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain an updated driver for the DVD drive, and then follow the manufacturer’s instructions to install the driver. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 3.
Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer’s instructions to install the decoder.
Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. b. Try to read the disc again. c. If you still experience problems with the disc, make sure that the sound card in the computer is compatible with the DVD drive.
Note Hardware and software decoders usually need a sound card to play back DVD movies. d. Try to read the disc again. e. If you still experience problems with the disc, contact the manufacturer to obtain a new disc. .
Remove Duplicate Drives loadTOCNode(2, 'moreinformation'); Remove any duplicate CD-ROM or DVD drives being loaded by Windows. To do this: 1. Click Start, point to Settings, and then click Control Panel. 2. Double-click System. 3. On the Device Manager tab, click View Devices By Type. 4. Double-click the CDROM or DVD branch to expand it. 5. Note the properties for each device listed in the branch. To do this: a. Click a device, and then click Properties. b. Click each tab in the device properties dialog box, and then record the device information and settings. c. Click OK. 6. Click OK, and then close Control Panel. 7. Restart Windows in Safe mode. To do this, use the appropriate method for your version of Microsoft Windows.
Aug 02, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Cd\dvdrom drive
go to control panel, system, hardware, device manager, locate the drive, right click update driver, if fails, try windows update, if that fails google search for make and model and include "driver download"
Nov 11, 2007 | Toshiba SD M1712 Internal DVD Drive
EliteGroup P4VMM2 Motherboard Logo
81 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
