Question about Dell Inspiron 1525 Notebook
When i try system restore when done says error not working
    President:
  • 3,278 Answers
Hello, David.
Unfortunately, System Restore does not always work. If possible, go back to a previous date. If you've tried all dates (usually the dates are bold), and are still unsuccessful, you may need to reinstall the operating system (Vista ?).
It depends on why you needed System Restore in the first place.
Often, if you have spyware, malware or a virus, the only choice is to use System Restore to "turn back the clock" to an earlier time. And, I've seen some spyware totally prevent System Restore from occurring, which may be your case.
If you have not tried System Restore from Safe Mode (press F8 repeatedly), that would be your next step.
If you have spyware, etc., you'll need to reinstall your operating system, if you have already tried to remove the spyware, etc..
Hope this helps.
Posted on Oct 08, 2009
Error messgae trying to use system restore to get rid of program stopping my computer from starting get error mess age class not registered OX80040154 please close system restore and try again
Go back further in your system restore to an earlier date until normal operation is restored. If this still doesn't work, buy yourself a new hard drive. Put your operating system and programs you use on the new drive and copy file from your old drive mounted in the slave position to copy file from your old drive. Once you have done this, format your old drive and keep it for a spare. Your new drive will have none of the old problems any more. Be careful about the WEB sites you go to and use a quality anti-virus program to screen future problems.
Paul
Feb 12, 2015 | Computers & Internet
Outtlook emails is blocked i cant get access to my emails
Step 1:
You might need to reinstall or do a system restore back to when it was working ?
You can use the System Configuration utility to perform a system restore. There are three possible restore points: System checkpoints that Windows schedules Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Apr 11, 2013 | Acer Aspire Computers & Internet
I have windows xp an error message box pops up that says at the top message from webpage [object error] it wont go away after xing it hitting ok or alt control delete. Everthing is locked up depending on...
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer this may vary depending on your computer and operating system If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details or You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps. Hope it helps.
Jan 05, 2013 | Computers & Internet
System restore has stopped working on my hp g-61 wm511 laptop
unplug, remove battery, leave battery out, plug in . repeat system restore. What is the error? Perhaps a system recovery?
Dec 01, 2012 | Computers & Internet
Runs extremely slow-maybe 5 or 10 minutes to load up at start get "not responding" on intertnet or mail connections slow response if selecting e-mails freezes during typing McAfee Security shows...
try to run your computer with your Antivirus disabled temporarily
>if it runs faster then it is an issue with your anti virus but there only is a slim chance that this a security issue, but it's worth trying it.
if system is still slow:
>Try optimizing your browser by going to Internet Options on Control Panel
>click on Delete Files check the box that says DELETE ALL OFFLINE CONTENT and Delete Cookies under General tab
>Go to Advanced tab click on Restore default Settings or Restore Advanced Settings
>click Apply
>if this doesn't work,do a Disk Cleanup,Disk Defragmenter, or System Restore follow these steps:
>click on START
>click ALL PROGRAMS
>click ACCESSORIES
>click SYSTEM TOOLS
>click Disk Cleanup / Disk Defragmenter / System Restore
(these 3 tools are all on the same folder)
*****System Restore will be the last resort. this sets your computer back to the date when you know your computer was working perfectly fine.
Sep 19, 2010 | Microsoft Windows XP Home Edition
After update download and auto install of a recent microsoft framework program, computer froze with error msg. resulting in many corrupted filesthat was probably my fault when i tried to unfreeze the...
Hi Fred,
A system restore may work in this case.
You can take the system back to before the updates were installed and probably one of the updates themselves have done this.
To access system restore click on the start menu, programs, accessories and then click on system restore.
When the restore window pops up select restore my computer to an earlier time and you should then be presented with a calendar. Choose a date before all this happened.
Good luck.
Jul 15, 2010 | Dell Latitude D600 Laptop Computer -...
Runndll 32 error.how to partition the hard disk
hi,
whenever you repartition a drive all the data is lost in those partitions
a quick way to get rid of rundll32 error is to do a system restore using safe mode, which will restore your system configuration to a date when your system was working fine without rundll32 error, it is possible if you remember the date on which your system was working fine
when the system starts at the blue dell logo start tapping the F8 key and when it gives you the option to use safe mode select it and then
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
here it will show you in bold the dates to which you can restore your system back to, select the date and continue, but restoring a system back in date will make you loose any new settings done to the system or any new software installed to the system.
If you think the above info was helpfull please do rate me
Regards
Ltoso
Jul 07, 2009 | Dell Inspiron 1525 Laptop
System restore does not work it says try another date same thing happens
Only the dates listed in bold have a system restore on them. Try one of those.
May 20, 2009 | Toshiba Satellite A75-S206 Notebook
A runtime error has ocurred. Do you want to debug?
Have you done a System restore?
GO TO: Start>>>>Accessories>>>>>System Tools>>>>System restore and set it back to a good working day.
Hope this works for you.
Jan 27, 2009 | Computers & Internet
Voice System Error.....
If you made a backup before try restoring one back.
If not;
  1. Do this regularly as this is an easy way to stay away from problems.
  2. Make a backup right now and format your phone by keeping pressed *,3,call key (green one) while turning it on.
  3. See if the problem is solved OR ELSE RESTORE THE BACKUP BACK.
BACKUP AND RESTORE:
It can be done from memory right there in Extras or Tools folder.
Rate if Satisfied!
Dec 17, 2007 | Nokia 6600
Dell Inspiron 1525 Notebook Logo
101 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
