Question about Samsung Televison & Video
The perfect focus does not work and the i can't get the conveyance to work
  • 29 Answers
U need to replace stk
Posted on Oct 09, 2009
Indicators, hazzards,do not work on drivers side,passengers side is perfect,checked bulbs are perfect,known problem in focuas,please help thanks bryan
is both hazzards on the drivers side dont work cuz if only one dosnt work it could be just a loose bulb or ground
Jun 02, 2010 | 2001 Ford Focus
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Codigo C7760 de una Kyocera kilometros 1635
C7410 C7800 C7810 C8010 C8030 Drum unit connector insertion problem • Absence of the drum unit is detected continuously for 1500 ms while there is no error on the copier. Broken external temperature thermistor wire • The input voltage is above 4.5 V. Short-circuited external temperature thermistor • The input voltage is below 0.5 V. Finisher* paper conveying motor problem • The paper conveying motor lockup signal is detected for 0.5 s or longer. Finisher* paper conveying belt problem • An on-to-off or off-to-on state change of the paper conveying belt home position sensor is not detected within 2 s of the paper conveying belt clutch turning on. Drum unit connector inserted incorrectly. Defective drum unit connector. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the paper conveying motor connector terminals. The paper conveying motor malfunctions. Defective finisher main PCB. The paper conveying belt is out of phase. The paper conveying belt clutch malfunctions. The paper conveying belt home position sensor malfunctions. The paper conveying belt home position sensor connector makes poor contact. The internal tray is incorrectly inserted. Reinsert the drum unit connector if necessary. Replace the drum unit. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the paper conveying motor and check for correct operation. Replace the finisher main PCB and check for correct operation. Adjust the paper conveying belt so that it is in phase and check for correct operation. Replace the paper conveying belt clutch and check for correct operation. Replace the paper conveying belt home position sensor and check for correct operation. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Check whether
Jan 19, 2010 | Office Equipment & Supplies
Red will not focus but blue will ...perfect focus stops in middle
REPLACE THE 2 CONVERGE I.C.'S. PLEASE LET ME KNOW IF FIXED. THANKS.
Mar 15, 2009 | Samsung HCN4727W 47" Rear Projection...
Akai PT4298HD projection tv
convergence must be adj then saved then magic focus
if cannot be adj chips need to be replaced.
Sep 21, 2008 | Akai PT4298HD Rear Projection Television
Blue blurry on perfect focus
Did you try the manual lense focus in the back? There is a wing nut on it and it's pretty easy to change. You just need someone to look at the TV and tell you when it looks good. Additionally for the Blue tube, it's on the far left. You take off the bottom panel in the back to get to this area. Good Luck.
Jan 13, 2008 | Samsung PCN5425R 54" Rear Projection...
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
White tint/haze
Check any/ all pico fuses in power supply. PVAT! Look for evidence of CRT coolant leak. Since Perfect Focus is a function of convergence,you might consider replacing convergence IC's,then perform alignment in servicer mode,then finish w/Perfect Focus.
Sep 28, 2007 | Samsung HCM4215W 42" Rear Projection...
Perfect Focus
Perfect "FOCUS" is a misnomer.Convergence is the real issue.Enter servicer mode--perform accurate convergence alignment procedure--activate perfect focus as last step to 100% alignment.If you have a High-Definition source,check procedure for that.
Sep 27, 2007 | Samsung HCN5527W 55" Rear Projection...
Perfect Focus not working
enter your service mode by pressing mute-1-8-3- a cross hatch pattern should apear,when it does and it looks alright press and hold the enter key the ,it will say data write then press the focus key the set will align your sensors and retuen to the cross hatch pattern ,tune off set and turn back on and try the magic focus ,should work.
Sep 13, 2007 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
52 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
