Question about Coby MP-C641 (256 MB) MP3 Player
0 characters
1 Points
My new hannspree 10'1 tablet has completely frozen after 10 mins of watching bbc i player the screen froze and does not respond to anything at all it wont even shut down im
Press and hold the power button for @ 10 seconds. That should shut down your device. Then, after it shuts down, again press and hold the power button until it reboots.
Jan 04, 2014 | MP3 & Digital Media Players
How would I lock and unlock the mp3 player. I have the Coby MP610-4G player.
The power switch on the side doubles as the lock. Slide it down (away from the "HOLD" position) to unlock it.
Jan 22, 2011 | Coby MP-610 MP3 Player
I do not have the passcode to access my ipod and i tried to get on itunes and restore it but itunes is not recognizing my ipod because I don't know the code. I tried to hold the sleep/wake button down...
to fix this problem you, unfortunately, will need to erase all the data on the iPod.
plug the iPod into the computer using the included USB cable. open iTunes. Hold down the home and power buttons at the same time until it shuts down and reboots. (if it doesn't open automatically) in the column on the left side of the window there is an icon showing your iPod's name. click on it then click on the button that says "restore iPod"
WARNING: this will erase all the content on the iPod (you can put it back on later)
it will ask you to confirm. hit "OK" and keep your iPod plugged in as it restores it to it original state. pick the language you prefer and then load your music back on the device.
Jan 09, 2011 | Apple iPod touch
When ever I touch the screen of my Coby MP822 it says Keypad locked. How do I unlock it?
The menu / hold button could be engaged, see button 14:
Controls at a Glance
Top View
1. Neckstrap Insert
2. USB Port
—. Connect to a computer to transfer media files to
the player.
3. 3.5mm Headphone Jack
Left View
4. Menu Navigation: Up
5. Menu Navigation: Down
6. Stylus
Front View
7. Speaker
8. LCD Touchscreen
—. Tap the display with your finger to activate the
on-screen control.
9. OK Button
Bottom View
10. Reset Button
11. miniSD Card Slot
—. Load a miniSD memory card here to upgrade
the memory capacity of the player.
Page 6 Coby Electronics Corporation English Right View
12. Power Button
—. Press and hold to power the player on/off.
13. Volume Button
14. Menu/Hold Button
—. Press and hold to disable the player controls.
Press again to re-enable.
See also page 8 and 9 of the Quick Setup guide for the MP822:
Dec 05, 2009 | Coby MP3 & Digital Media Players
How to on an COBY mp3-c7095??? can u help me?
1. See if you have a power switch on the side of your MP3 player. If your power switch is on the side, slide the switch up to put it in "Play" mode. To turn the player off, slide the switch up and hold for several seconds. If your power switch is not on the side, proceed with step 2.
2. Look at the top of the Coby MP3 player. Many Coby players that support video have their power switch on the top. Some are in the shape of a bar, and some have a small round button. If you have a bar switch, slide the bar to the right to turn the power on. If you have a round power button on the top of the player, press and hold the button until the player turns on.
Oct 03, 2009 | Coby MP-C7085 MP3 Player
Help with ipod 8gb nano
Reset your Ipod using the following procedure:
Turn hold on (lock)
Turn hold off (unlock)
Hold in Menu button and middle button until Ipod shuts down and starts up again.
This should remove the lock on the Ipod.
Mar 08, 2008 | Apple iPod nano
Jan 12, 2008 | Coby MP-C7085 MP3 Player
My coby mp-c7092 will not turn on
Make sure you have a good battery in it...check the back to see if the hold switch is on or off, and of course hold the power button until the screen lights up.
Jan 11, 2008 | Coby MP-C781 MP3 Player
Coby MP-C582 Will not turn on
Check on the side of the player and make sure it is not locked that was why ours would not turn on. Once I unlocked it worked fine
Dec 24, 2007 | Coby MP-C582 MP3 Player
My coby mp3 player will not turn on
I had the same issue with mine. Upon opening the unit, I found that one of the solders for the power switch was broken. A touch of solder fixed the problem.
Nov 04, 2007 | Coby MP-C7085 MP3 Player
Coby MP-C641 (256 MB) MP3 Player Logo
24 people viewed this question
Top Coby MP3 & Digital Media Players Experts
Gyula Lacz
Are you a Coby MP3 and Digital Media Player Expert? Answer questions, earn points and help others
