Question about Husqvarna Chain Saw 20" Bar
My name is billy .Went to use my Husqvarna saw yester day . It will cranke but it axe like it is runing out of gas.
Try fresh gas - check gas and air filters - fuel line may be restricted. Carburetor usually the last thing to go bad,, unless you mess with settings.
Posted on Oct 08, 2009
Hard starting husqvarna chain saw 450 rancher, is drowned
Take plug out of saw, ground it out on metal cylinder, slowly crank saw and see what kind of spark you have. Quick,bright blue fire is good, yellow or huge kernel fire is not. No fire is ignition module. If soaked with gas change plug if that don't do it, it is time to put a kit in the carberator.
Feb 01, 2014 | Husqvarna Garden
Cranking new chainsaws
The newer saws have emissions regulations that they have to comply with.
Jan 09, 2014 | Husqvarna Garden
Won t crank
Sounds like it will crank but just won't start. Almost always a carburetor adjustment if your gasoline is not deteriorated (old).
Pull the spark plug and prime the cylinder with a teaspoon of gas. Try again. If it fires in a few pulls and then won't fire on the next few, your carburetor isn't supplying enough or any gasoline.
Jan 08, 2014 | Garden
Saw was runing and died now it want crank
My saw also died while running and is now just giving off a gust of air on the hits it would usually crank. Is yours doing this also?
Jan 12, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
18" Husqvarna chain saw purchased from lowes in 2009. Cranks fine when cold. After running for some time, and the saw is warm, if it is cut off, I can't seem to get it to crank again. If it cools back...
Check to see if your saw is still under warranty, if it is Husky should fix it. Otherwise- when the saw is cold, pull the plug out and ground it on the cylinder head somewhere and pull it through. (Make sure the on switch is in the ON position) You should see spark. Run the saw until it gets warm and dies, as you say it does. Then re check the spark as when it was cold. If it doesn't have spark then you probably have a short in the coil/ignition system caused by heat. You will have to replace the coil/spark plug wire assembly. Since the saw is new, there is a good chance this is the problem.
Oct 24, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Model 445 chainsaw. Was cutting all day and no problem. Good gasoline, Husqvarna 2 cycle oil. All of a sudden started racing like the carb was stuck full open even when throttle trigger released. Then...
Engine speeding up on idle is normally due to an air leak, check the carb securing screws are tight, if you have a leaking crank seal it will be a shop repair.
Feb 28, 2010 | Husqvarna Forest & Garden #966906636 445...
My husqvarna chain saw won't start.... i brought it new,, used it a dozen times (light work) and storeds it for about 2 yrs.. got it out the outher day and could not get it to crank...
The oil and gas is probably bad if it was stored with them. I would change out the oil and gas and try then. If it still doesnt start change out the spark plug. SHould start right up after its primed.
Jun 15, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 350 quits under load
had the same problem the other day with my model 55 rancher found the pin missing that
holds the handle to the trigger mechanism once i found the pin put it back in the handle the unit works fine. the pin is about 1/8 X11/4 " long.
Apr 22, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna mod 41 chain saw wont start
If checking spark make shore the out side if plug is earthed to chain saw.
Fresh clean fuel, clean fuel filter filter pull exhaust off and check piston is ok. Than check for flooding. start there.
Jan 03, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Chain Saw 20" Bar Logo
87 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
