How many tons and what Seer is my Bryant model 561CJ048-A
  • HANK MCNEIL May 11, 2010
    how old? what is serial #
  • Clay Elder
    Clay Elder May 04, 2017
    Serial #is 4598E06708
    Problem Solver:
  • 13 Answers
12000 btu/hr equals 1 ton. The 48 in your model number tells me it is probably a 4 ton unit. 48 divided by 12(000) equals 4. Not sure on the SEER
Posted on Oct 09, 2009
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
May 04, 2017 | Bryant Heating & Cooling
Have a bryant 3.5 ton outside can I change to a bryant 4.0 ton and still use the same inside equipment
This is true as long as it is not a heat pump. Make sure they replace the piston (metering device to match the outdoor units required piston size. Or if the indoor coil is metered via TXV, it will automatically meter the refrigerant flow. If you are mismatching a system, make sure an acid test is performed on the old refrigerant and take appropriate measures with the new system if the test shows positive acid. They need to definitely install a liquid line drier. Hope this helps.
Jan 28, 2013 | Bryant 3.5 Ton R22 12 Seer Condenser Only/...
I HAVE A GOODMAN MODEL CKL36-1D I'M TRYING TO FIND OUT THE SEER RATING ON THIS MODEL.CAN ANYONE HELP?
Your going to need to know the age of the unit. If its less than 5 years old, its most likely a 13 SEER. If its anything more than 5 years old, its most likely a 10 SEER. If its anything over 10 years old, its most likely an 8 or 6 SEER.
Remember, that a unit will loose an average of 1-2 SEER for every full year of operation. This is just due to age, wear and tear, and usage.
So, if its a 10 SEER unit that is 7 years old, you could say that it is about as efficient as something in the 4-6 SEER range.
Jul 12, 2010 | Goodman CKL36AR36 Air Conditioner
What is the seer rating and tonnage of a bryant model fb4anf030
The Tonnage appears to be 2 1/2 ton,
024=24,000 BTU=2ton
030=30,000 BTU=2 1/2ton
036=36,000 BTU= 3ton
I dont think you have the correct Model Number, Look
on the outdoor unit, the model number might start with a 38. Hint Carrier and Bryant Products are the Same, just different nametag
Feb 17, 2010 | Heating & Cooling
I have a bryant 24-567c condenser. need replacement
you have a 3.5 ton unit.The evap will work with a new unit but it will not have the 13 seer performance that the new condencer with matching coil will give you.It is getting and harder to find the old 10 seer units check ebay and craigslist.
Aug 18, 2009 | Carrier 38CKC042 Air Conditioner
The AC unit is not working on my bryant model number 561cj048-A
Does the blower inside work. If so check breaker and float switch on Air handler. That is about as far as you can go without a service tech. Rus
Jun 24, 2009 | Bryant Heating & Cooling
Heating & Cooling Logo
2,306 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
