Question about Singer 20U73
What is the application of his model?. - Singer 20U73
  • 208 Answers
You have an industrial straight stitch/zig zag sewing machine for lightweight to medium weight fabrics.
Posted on Oct 08, 2009
  • Tally Girl
    Tally Girl May 23, 2011
    I have this model in a table with 3/4 HP motor and its a real workhorse, I sew vinyl onto car door trim foam with it, foam is 1/4" thick plus backing fabric. It handles it well and feeds the vinyl fine.
Is it Contemporary Fabric Architecture for shading applications ?
That is a fascinating statement...
Is there something in particular you need help with?
Jan 31, 2018 | Sewing Machines
I NEED TO KNOW WHAT NUMBER NEEDLES CAN I USE FOR MY SINGER TRONIC 2010?
google singer needle applications and find what you want from the chart
singer needles are all the same length but the eye dimension varies for different thread thickness and applications
Dec 13, 2016 | Singer Sewing Machines
Singer simple manual
Try this link: http://www.singerco.com/accessories/instruction-manuals Type model no. in the search field and press Search. You'll be able to choose to pay or download for free! Good luck!
Jan 31, 2014 | Sewing Machines
Any advice on shirring with an old elna lotus sp. Brought out of retirement as my Brother refuses to shirr! bobbin threading etc can't find the manuals.
Suggest you watch in utube 'sewing with shirring elastic' not necessary be your model as the basic application is similar in other models.
Nov 11, 2013 | White Sewing 1521
My fabric wasn't moving so I lowered the feed dogs and now I cannot raise them. The button in the back of the machine moves both ways but the feed dogs are not moving. They are staying in the down...
Hello
Turn off the power. Remove the accessory compartment located in front of the machine, if applicable.
Open the hook cover that shields the bobbin area. Please note that you do not need to remove the bobbin case.
Locate the drop feed lever near the bobbin case. Some machines have the lever towards the back of the free arm. Press down on the lever and then move it to the next notch or position. The raised metal feed dogs should be visible through the openings on the needle plate. You may need to rotate the big balance wheel one rotation to engage the mechanism on some machine models. The metal teeth will then spring up.
Close the hook cover. Insert the accessory compartment, if applicable.
Turn on the power. Try test stitching a piece of fabric. The raised feed dogs should help guide the fabric under the presser foot.
Jul 12, 2011 | Janome 4623 Mechanical Sewing Machine
I am looking for a belt for a kenmore zig zag model # 158.480. Do you know the belt size or part #. Thank you
If you go to SewingStyle.com they have parts listed with applicable machine model numbers. I think the belt you want is DP6912 which they have listed for 8.99.
Jan 13, 2011 | Kenmore Sewing Machines
I have a Bernina Nova sewing machine, and am unable to get the foot pedal to work. The light turns on, and it works by manually turning the knob. Is it the foot pedal that is at fault? Or have i missed a...
Some Bernina models have a three application switch.
Light, light and power pedal and just the power pedal.
Inside the machine, at the back of the tower is a circuit board. It could be the contact or wire is broken.
May 09, 2010 | Sewing Machines
Application error when trying to open futura
Futura installation integrity might be damaged, you need to uninstall everything Futura related, reboot pc and install from the beginning.
If you already did reinstall Futura but still get the error, you may launch troubleshooting utility and send its report to Singer.
Mar 23, 2010 | Singer CE-200 Quantum Futura Computerized...
Bernina 830 old style need replacment part -under extention table
The clamping yokes for Bernina sewing tables for models 830 and earlier models were hand fitted parts. Welding this may change the geometry so that the table may not fit at all. Additionally the material is diecast AL, not cast iron, and may or may not accept TIG welding applications.
Aug 27, 2009 | Bernina Sewing Machines
Model 385.15718500..machine only goes in reverse
Sounds like the reverse mechanism has jammed...either with lint or lack of use and oil/lint has frozen the mechanism.
Unplug the machine and remove the base. Clean all the lint with small brush and vacuum.
Try the reverse lever to see where the connecting rods are and identify the collar around the bottom shaft....try to move manually, use a little lubricant where the collar moves on the shaft.
In extreme cases it may take several applications over several days to rectify this, but as this is only 3 years old, should respond quickly
Aug 02, 2009 | Sewing Machines
Singer 20U73 Logo
73 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
