Question about Refrigerators
Refrigerator not cooling
Freezer works great but the refrigerator is not cooling on our side by side Whirlpool model ED25DW.
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent(damper)between the freezer and fridge.The fan in the freezer blows air through it.Make sure this fan is running. You may have to hold the door switch in for itto run. There is a flap you adjust withthe fridge temp. control. Make sure it's opening and closing when you adjustthe fridge temp.
The problem could be the electronic control ifyou have one or the mechanical linkages.
OR
The evaporator coil behind the cover on the backwall inside the freezer will ice up under normal conditions. Every 8 to 10hours for around 20 minutes the defrost timer (or in most newer models the electronicadaptive defrost control) will turn the defrost heater on tomelt the built up ice. There is a defrost thermostat which prevents the heater fromoverheating the freezer by breaking the heater circuit when the temp reachesclose to 32 degrees F. The entire cooling system shuts off during the defrostcycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue tobuild up until the air can’t flow over the coil to circulate the cold airthrough the freezer and into the fridge. The temperature change in the fridgeis usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater fromcoming on OR it won’t turn the heater off when it gets too warm. It is clampedto the evaporator coil at the top to sense the temp. If it appears to bemisshapen it is bad.
With an ohm meter it should show continuity whencold and none when warm.
You can also bypass the thermostat to see if theheater comes on then. If it does then you know the thermostat is bad and needsreplaced.
The defrost heater islocated on the evaporator. It is in a tube which is at the bottom and can alsogo up the sides of the evaporator. On some types you can see a burnt spot ifit’s bad. With an ohm meter it should show continuity from end to end whendisconnected from the wiring in the freezer. You can also test the wiring forvoltage when it’s in the defrost mode.
Ifyou have a defrosttimer youcan test it. It can be located under the fridge behind the kick panel on thefront. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shutsdown. The heater should now come on. If it does, replace the timer because thatmeans the timer is not running. If itdoesn't, check the heater and defrost thermostat. Turn the timer again tilleverything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer,replace it if the heater and thermostat test good. It is located in the fridgewith the controls in some models and on the back in others.
If you need help finding your model number seehere> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptivedefrost control , enter your model number and search for the part or post backon Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Oct 08, 2009
  • 86 Answers
It is probably the temperature selector button is bad or the temperature sensor.
WARM FRIDGE FREEZER WORKING MODEL NUMBER, ART721 3XART721F01
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 04, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our side-by-side Whirlpool refrigerator (Model #GD5YHAXNL00) is not getting cold ...everything in the freezer defrosted. Is it an expensive fix?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 19, 2011 | Whirlpool Refrigerators
Whirlpool 6th sense side by side fridge/freezer 25rid4 model,freezer working fine but fridge part does not cool
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold Model GS5SHA Side by side. Freezer working, refrigerator side not getting cold.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 06, 2010 | Whirlpool Refrigerators
Whirlpool model ED22TEXHW00..fan works but no
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 31, 2010 | Whirlpool 21.7 cu. ft. Side-by-Side...
Refrig. stopped cooling then the freezer side. then started back
heatman101
Jul 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freeze and fridge not cooling the compressor is running and warm fans are working but not cooling whirlpool side by side
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
fsdtyr6t
Nov 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Refrigerator is not cooling but light is on.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jul 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
310 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
