Question about Krups XP7230 Compact Super Automatic Espresso Machine
My xp7220 will not rinse - no water passes but if I ask for hot water only it works. Can you help and tell why is this? Thanks PS
  • 14 more comments
  • mexsto Oct 12, 2009
    Hi - thanks for your response. Here is a little more detail if you can help
    I have an XP 7220 D coffee machine which I upgraded from an XP 7220 B last year. It has worked fine but recently developed malfunctions which result in a number of problems. Currently the main problem is that the machine starts the coffee cycle to produce coffee but water does not seem to go in and coffee therefore does not come out. It remains dry. The thermoblock heats up the mechanical actions of the tamping head and balista valve seem to work but no fluid comes out. After a period of time I get an ERROR 06 displayed and I have to shut down the machine. Staring from cold again, if I select 'hot water only' then the correct amount of hot water comes out and all is fine for this function.
    Prior to this problem I did have coffee coming out of the nozzle but water remained in the thermoblock after the cycle and was not drained away. It bubbled away when it should have been dry and the cake was wet - not good
    I have consulted the repair manual and it says that the ERROR 06 code is caused by an electronic bug and I should change the PEC or the Display board. I do not think this is correct. Can you please help?
    Thanks.
    Phil
    By the way i have signed up and paid my dues to FixYa
    Thanks.
    Phil
  • mexsto Oct 13, 2009
    Thanks.
    Phil
  • mexsto Oct 14, 2009
    Hi Taran,
    Thanks - yes in fact I have previously already removed the filter altogther so there is no reduction or blockage to the flow and the water is getting through just fine. The machine seems to be working better now - I get coffee out of the nozzle when I select ESPRESSO etc which is good but it still does not evacuate (drain away) the water out of the bottom of the thermoblock after the cycle and you get the sound of bubbling boiling water at the end - this is not right. Grateful for your solution
    Thanks Phil
    Thanks protek480 but I think the cold water solenoid is OK because I do get water into the thermoblock when I demand HOT water only.
    Thanks - any other ideas
    Phil
  • mexsto Oct 15, 2009
    I have an XP 7220 D coffee machine which I upgraded from an XP 7220 B last year. It has worked fine but recently developed a malfunction which resulted in coffee coming out of the nozzle but water remained in the thermoblock after the cycle and was not drained away. It bubbled away when it should have been drained and the cake was wet - not a good sign
    I have consulted the repair manual and it says that this may be due to a faulty distributor plunger. I have checked this but it seems fine. Can you please help?
    Thanks.
    Phil
  • mexsto Oct 17, 2009
    - I have an XP 7220 D coffee machine which I upgraded from an XP 7220 B last year. It has worked fine but recently developed a malfunction which resulted in coffee coming out of the nozzle but water remained in the thermoblock after the cycle and was not drained away. It bubbled away when it should have been drained and the cake was wet - not a good sign
    Thanks.
    Phil
    Thanks Herbalgarden - this is useful. I would like to know how to get at this switch. Is it part of the Distributor????? I think I know most of the separate parts of the system now.
    I have thought that something must be clogged but have been afraid to dismantle the distributor in case I get some sequencing cogs in the wrong order. Very grateful for your advice
    Cheers
    Phil
    Thanks.
    Phil
  • mexsto Oct 18, 2009
    Thanks.
    Phil
  • mexsto Oct 19, 2009
    Thanks.
    Phil
  • mexsto Oct 20, 2009
    I am really not getting the advice I need to fix my XP 7220 problem. Just to recap - I always seem to get water left in the thermobloc AFTER the rinsing or coffee cycle. This is not right and I want to solve this problem
    Thanks
    Mexsto
  • mexsto Oct 21, 2009
    XP 7220
    I have water remaining in the thermobloc AFTER making coffee. It should be drained away but it is not
    Pse help
  • mexsto Oct 23, 2009
    The real problem now is that I have water remaining in the thermobloc AFTER making coffee. It bubbles away and makes the cake wet when it should be drained away. I have checked the drain pipe and it is not blocked, the plunger is fine and I have replaced the O-ring seals and greased them. Pse help with a diagnosis
    Thanks Phil
  • mexsto Oct 26, 2009
    Thanks but I regret this advice is no help at all
    Phil
    Oct 23, 2009 - The real problem now is that I have water remaining in the thermobloc AFTER making coffee. It bubbles away and makes the cake wet when it should be drained away. I have checked the drain pipe and it is not blocked, the plunger is fine and I have replaced the O-ring seals and greased them. Pse help with a diagnosis
    Thanks Phil
There is a design flaw with this machine - the flow-meter, made by AWECO, is erratic - you will get Error 06. Open the machine and look for a circular object in the bottom-rear-right corner as you look from the front - it has two small water-pipes attached to it. Unhook this flow-meter and rotate it so that it sits in the same orientation as a bike wheel and your problem will be solved -
Enjoy . . .
Graham
Posted on Jan 19, 2010
  • 3,741 Answers
remove the filter basket,and looked at the bottom where there is a small spring action "thing" push that up and down and that allows the coffee to then flow into the carafe, that spring action "thing" should work automatically but if that system is not working then it will not work. -------- the hot steam droplets always remain in the thermo block which is later converted into water.
------------ Most espresso machines advantageously make use of boilers or thermoblocks for brewing the espresso. In case of home coffe machines usually it is the same boiler that is used to also produce the steam for frothing milk. Thus, this is referred to as a single boiler system. The temperature and pressure in the boiler is made higher upon pressing the steam button. Within a minute or so the required pressure is built up.
In case of some coffe machines, especially in the automatic and semiautomatic machine types, there is provided a separate boiler or thermoblock for the steam generation function. Solid performers among coffee machines like Capresso espresso Classic etc etc have stainless steel lined thermoblocks or boilers. This helps in the prevention of water from coming into contact with aluminum at any time while the brewing process is in progress.
The thermoblocks heat the water as it passes through a tube that remains encased in an aluminum block with a built in element. Applying a pulsing action the pump pushes water drops into the thermoblock or boiler where it soon gets transformed to steam. While the water held by the boiler remains at a constant temperature for coffee making, steam is quickly produced by the thermoblock.
The ability of the thermoblocks to continuously make steam renders them suitable for preparing coffee on a large scale for serving bigger groups. That is the reason why even superautomatic machines make use of the thermoblock or boiler. Indeed, the thermoblock technology has provided an impetus to the development of the advanced coffee machines.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Oct 18, 2009
  • 344 Answers
There is a switch valve for the hot and cold water, it sounds as if the valve is faulty or clogged. If you have hard water (lime,Iron, or calcium deposites) it clogs the switch. Not so much with the hot water as the minerals in hot water generally don't flow as freely as they do in cold water therefore they have a harder time building up on the hot water side of the valve, as with cold water the minerals have more travel ability and can attack and eventually clog the passage. If you have a water softener or you do not have hard water then its a faulty valve switch. Hope this helps
Posted on Oct 17, 2009
  • 79 Answers
Try this :
Remove the coffee cleaning tray. Clean it under hot water with liquid detergent and dry thoroughly before re-fitting it. Remove and empty the coffee ground collector. Clean it under hot water with liquid detergent thoroughly and re-fit it. Empty and clean the drip tray under hot water with liquid detergent.
If you do not fit the coffee grounds collector back correctly, a warning message will come up. Just re-fit it until it asks for you to confirm that you've emptied it. You can not make espresso or coffee with this warning message displayed, so be sure you get this fitted properly.
Next, to preform the cleaning program, you will need a recipient with a minimum capacity of 0.6 litres and a KRUPS (XS 3000) cleaning tablet.
Press the PROG key then choose MAINTENANCE, then OK, then CLEANING to start the automatic cleaning program. Just follow the instructions shown on the screen. The automatic cleaning program cleans itself, then rinses twice. It lasts about 20 minutes.
Now descale it. You will need a recipient with a minimum capacity of 0.6 litres and a KRUPS F 054 (40 g) cleaning sachet. Press the PROG key, then choose MAINTENANCE, then OK, then SCALE REMOVAL to start the descaling process. Follow the instructions on the screen.
After this process is over, remove the power supply cord from the socket and let your appliance cool down. Rinse the water tank with fresh water.
This will probably help your problem, especially if the machine is scaled or clogged near a sensor, which would block certain functions. If this does not work, please leave a comment and I will be glad to further assist you.
Hope this helps. =)
Posted on Oct 23, 2009
  • 3,267 Answers
For the m/c to make coffee needs steam & steam is not being generated at all. Therefore the heating element is unable to generate steam due to deposition of calcium or some other suspended solids present in the water which have accumulated in the aluminum pipe thus not heating the water enough to produce steam. You can try rinsing with vinegar, at let it stay for half an hour and then simply rinse/drain the vinegar at least twice, so that all the vinegar is washed out. The other explanation for this type of behavior is that it seems(remote possibility) that the unit steam holes have worn out and are not in good condition, The aluminum pipes could be a deformed inside that's why you have this kind of problem, this can be due to heat and esp.. the steam nozzle deform. Thus no steam for the espresso but will give you hot water when asked for. Hope this helps............................sodeep
Posted on Oct 21, 2009
  • Sudeep Chatterjee
    Sudeep Chatterjee Oct 27, 2009
    Sorry, I had thought in a comment ( by me ) mentioned therein To check the small filter attached to the drain plug( an elbow) & a reverse flow by a piece of garden hose+ a rubber adapter one end larger than the other(hole).....Oops! Sorry no puns intended please.
    Well this back-flow + a empty ball-point refill sliced off to look like injection needle, used as poker ought to clean any jam. Have to hurry before the house comes to life......sodeep
  • Krups Master
  • 19,396 Answers
Hi.
The lines are probably clogged by scale, and pressure is insufficient to brew or to get steam.
This can be caused either by clogged lines, or by limescale on thermostat and heating element that wont allow the machine to reach enough temperature and pressure.
Try to descale the machine using a descaler product:
Cleancaf Home Coffee Maker and Espresso Machine Cleaner / Descaler ...
Urnex Cafiza, 20oz Espresso and coffee machine cleaner powder 2 ...
Posted on Oct 19, 2009
  • 10,865 Answers
Hello. Here is the info for you to get your xp7220 repaired. It may still be under warranty. The problem you are experiencing has no quick fix and requires special tools.
http://www.krupsusa.com/Consumer+Services/Service+Centers/List/CentersList.htm
Posted on Oct 15, 2009
    President:
  • 1,714 Answers
The cold water solenoid is not working. It could be jammed with hard water and need a cleaning or replace.
Posted on Oct 13, 2009
  • Craig Butler
    Craig Butler Oct 17, 2009
    I think the drain is plugged and needs to be cleaned. Try to force something down, even 'liquid draino' to see if the drain is plugged. Maybe you could straighten a clothes hanger and try to push it in the drain.
  • Craig Butler
    Craig Butler Oct 23, 2009
    Check drain tube for obstructions and elevation with respect to machine thermoblock. Is the drain hose kinked or elevated in some way?
  • 10,515 Answers
I am sorry as i cannot READ the earlier solutions, would not be able to comment.
Switch OFF the machine and then check the CAUSE.
There might be 3 possibilities :-
1. Water supply to machine interrupted - Check all supply tabs are open.
2. Water Mains Failure - Check other water supply points / faucet are working
3. Damaged Water Feed pipe - Check for damaged / kinked pipe
For all this, you need to do De Scaling ( I am surprised if no one tell you about this. I have most repaired all this by De scaling the machine ) .
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 12, 2009
  • taran_2005
    taran_2005 Oct 13, 2009
    Thanks for your response!!
    You never mention the Error Code earlier. That might be one of the reasons, you are getting some other information. Check the below option that was given by an expert and it was in par with this problem with another customer :-
    The issue is with the water filter. If you haven't changed it for a long
    time - change it. If you recently got a new one follow these steps:
    - take the filter out
    - unplug the machine from electricity
    - plug it back in
    - install filter (go into prog- service- install new filter)
    It should remove the error.
    Let me know, if the problem still remains.
    Thanks.
  • taran_2005
    Oops now, i saw that error code in Comments!!
    Huh, still try and let me know the result.
    Thanks!!
  • 11,896 Answers
Sounds like valve or circuit is fualty. Valves can get wornout or stuck, circuits can get overheated and cause faulty or burnt out capacitors
  • Nate Stansfield
    Nate Stansfield Oct 26, 2009
    You can check and see if there is a water level sensor or a pump timer. Does it happen no matter how much water is in it?
    Brigadier General:
  • 5,158 Answers
Is this a new machine recently installed ?
Posted on Oct 27, 2009
  • 6,927 Answers
The brain of this thing is the boss,I think it has brain damage.The pc board is the brains behind this machine and it distributes the commands to each mode.I believe that this is the problem,you have been very good at the test and trials so far,according to your text.All the testing(good on your part)is done.Now it all points to the p c board.I am going by what you have done and tested,and suggestions from other techs.I hope my input was helpful,and you have done all the testing I would have asked about,and according to your results,well,the board is the problem.If this was at all helpful please let us know,thank you.
Posted on Oct 22, 2009
  • 3,866 Answers
This is probably a pump that failed most of these have two pumps that pump the water from a container this pump **** the water from one area to a heating element and then to the next area that might be bad you might want to check that.
Please do click the accept button if you found this helpful
Posted on Oct 20, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Oct 22, 2009
    I was reading up on this same problem and the fix was what was in the manual anyhow but you seem to think otherwise so I invite your concerns you went threw what 6-10 experts sounds like you found the answer or you know what the issue truly is?
    All 10 experts are hitting on the same area 1.plunger 2,distribution unit 3. sensors solenoid
    Recommend hitting the accept button I think the issue needs to be solved if none of our solutions worked with the manufacture..
    Thanks
    Rulds2008
Can I hook the wash and rinse to cold water hose?
Not sure what you are asking. If you want to wash and rinse you clothes in cold water only, there should be a water temp selection switch to allow you to do that. If you are asking if you can hook cold water hose to both ports on the washer back the answer is yes but it is easier to just cap off the hot side of the water valve on the back of the machine. Most machine water inlet valves are a 3/4 thread garden hose connection. Go to a hardware store or a Lowes/ Homedepot and ask for a screw on cap. They come in both plastic and brass. If you do cap the hot side of the inlet valve, make sure your washer has a cold only setting for wash and rinse and keep it set there. If it gets moved to hot nothing will fill or run.
Apr 15, 2015 | Washing Machines
The hot water was mistakenly on the right and cold on the left. Hoses were hooked up, not knowing this. Half way thru the cycle, the error was noted. We reversed the hoses, but it works the...
unplug it and let it sit for 30 seconds then plug it back up.
Then wait for the water to be replaced in the hoses. (The hot water will still be in the hose, you have to wait for the lines to clear, then it should be right.
Thank you!
If this helps please say thanks by giving me a high rating!
Jun 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a Krups XP7220.The waters commes out cold under the appliance. Is the boiler as the guy from service says ? Thanks Ovidiu
When you brew a cup is the coffee cold? Or is just the excess water that come out into the water tray cold?
Sep 20, 2010 | Krups Small Appliances Espresso Machine
Type: sup 015 st no water passes during rinse or
First, check / remove the water filter in the tank, next try to run hot water thru the wand, not steam but water, this should prime the system, then turn off and back on, that should do the trick, unless you have a bad pump. Good Luck!
Jun 27, 2010 | Saeco Stratos Coffee Maker, Espresso...
Washing cycle stops before finishing
Hello, i have exactly the same problem. Did you find the solution?
Thanks
May 24, 2010 | Zanussi ZWD12270 Front Load Washer / Dryer
Never Runs Cold Water LG Model WM0532HW
When set to Cold it Fills Hot ?
What does it rinse with ?
Have you had the fill pipes off the back for some reason and put them back wrong or has a plumber been messing with the supplies
If the machine is told to fill cold it should, it should also use cold water to rinse with.
What hapens if you tell it to fill Hot only
Jun 13, 2009 | LG WM-1832C Front Load Washer
Cannot find repair manual for Hoover H3044
I found the inner round valve where the tube connects for the cleaning fluid was stuck shut. Although the "trigger" was working fine and the rod pushed againstthe valeve it wasn't working. Here's how I found this out. I tried to blow air through it and nothing would pass. I soaked it in hot water for a while and heard a "click." Tried blowing air through it and it passed through. It works like new now. It appears the "cleaning solution" causes a build up of "stickiness" that eventually causes the valve to stick in the closed position. Heating it in hot water caused it to become unstuck. I rinsed it well with hot soapy water before reassembling the machine.
Mar 06, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
No rinsing water coming in
There are 2 versions of this washer dryer, a cold fill only one and a hot and cold fill version.
If it is the cold fill version, it could be the water level switch that is malfunctioning, cutting off before the correct level is reached, or a sticking water inlet valve.
If it is the other version, then the same thing applys, plus the coil on the valve that controls the rinse cycle could be open circuit.
You need a meter to test the valve coils for continuity..
Make sure that there is actually cold water to the valve, if it is a hot and cold fill model.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Indesit W 123 Front Load Washer
Frigidaire washer hot water only
sundsas if you have a bad temp select switch. only selecting hot/hot
Oct 31, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Hot water cycle flow problem
hi thanks for the question their is a screen in the water valve to catch any dirt you can try and remove the screen in the water valve and try again if it works ok . it usually works thanks the appliance doc
Sep 24, 2008 | Washing Machines
Krups XP7230 Compact Super Automatic Espresso Machine Logo
3,425 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
