Question about Bunn NHB Coffee Maker
Bunn coffee maker leaks water only during operation...near end of the cycle (not when it just sits & not when water is first added).
There is a gasket where the water inters the tank,you have to remove the tank to get to it .mark down how it is wired so you can hook it back up.Use a high-temp
silacone ( auto ) and seal it under the the gasket and around the edge of the gasket.. 2 screws holding the metal plate plate. 4 screws holding tank need a 12 or 14 " phillips to reach down on the side of the tank to remove outer cover.
Posted on Oct 11, 2009
Why is the coffee spilling/leaking everywhere during a brew cycle?
wrong filter possibly my Bunn does that with non bunn fliters
Apr 14, 2015 | Conair Cuisinart DTC-975 12-Cup...
How to fix a leak on a bunn NHBX coffee maker
The leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
Re-install the reservoir and reassemble the unit.
Aug 09, 2014 | Bunn NHB Coffee Maker
Bunn coffee maker ITCB-DV not pouring enough water
The pulse program does not result in lower volume. The control board adds time to account for the pulses. If you are encountering less water than before clean your spray head and spray head fitting. 75% of low volume service calls are from calcified spray heads.
Mar 29, 2013 | Bunn Infusion ITCB DV Coffee Maker
Leaks water
the tray you pour the water into sits directly on the tank that heats the water with a gasket between tray and tank, this gasket has worn away, Bunn no longer sends replacement gasket, I made one myself
Feb 25, 2013 | Bunn 10 Cup Home Coffee Brewer
We need to store a Bunn VPR Series coffee pot. How do I remove the water from the tank?
try hitting 'brew' until all the water evaporates, or look for a 'leak' valve to empty it. usually on the bottom or the side near the tank.
-swish-
May 06, 2011 | Bunn VPR Coffee Maker
The coffee is very weak. Have tried several different coffees but the same with all Brands. Have cleaned the top were the water comes out. Have run several cycles of water through it but coffee still is...
Make sure the 'vacation' switch is turned on. In addition to the warmer switch on the front of the unit, there should be another switch located on the side/rear of the coffee maker. If that is turned off, the water won't be pre-heated, and you end up with luke-warm water going through the coffee during the brew cycle. If that is not the problem, then there is an issue with the tank heating element and the unit will have to be repaired.
Dec 12, 2010 | Bunn NHB Coffee Maker
Bunn thermal coffee maker used at home does not spray the grounds correctly and water overflows out of the basket during brew cycle. what can I do to correct this. I have already checked filters.
Please call Bunn Customer Service. There is a different sprayhead that can be used to prevent this problem from happening and is free of charge.
May 20, 2010 | Bunn NHB Coffee Maker
Bunn coffee brewer leaking
Is this a lot of water, or just a small amount.
As the unit sits over time and runs heating cycles, it may have some vapor come out of the vents. That will cool and collect around the unit.
try turning the unit off for the weekends. If you still have water around the unit, then it may have a leak in the tank.
Nov 11, 2009 | Bunn VPS Coffee Maker
The water starts flowing for about a minute then stops for a minute then starts for a minute and continues that cycle until it fills the air pot and stops. I have cleaned all the filters in line, checked...
This sounds like normal operation of this type of unit.
Look at the brew funnel. is coffee coming out of it all the time during the brew cycle?
If so, then what you are hearing is the water supply solenoid cycling.
Oct 16, 2009 | Bunn GMB-PS Coffee Maker
MY BUNN COFFEE MAKER LEAKES WATER
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Mar 16, 2009 | Wega Mininova EPU Espresso Machine
Bunn NHB Coffee Maker Logo
250 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
