Question about Zanussi ZDC5350W Electric Dryer
I have a Zanussi ZDC5350W with error code 360 that is not heating clothes. Please advise
I downloaded the service manual which gave me the details of what the error was reporting..
Posted on Oct 09, 2009
Why is my zanussi machine 6k9 1200apm error code e60
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty,
PCB faulty, wiring.
Dado
Feb 29, 2016 | Zanussi Washing Machines
Drum won't rotate
what is your model number is then we can get started then okay
Feb 05, 2013 | Zanussi ZDC5350W Electric Dryer
Tumble dryer displaying E90 error
do you have the machine's manual ? if you do try and find out what the message mean
Mar 23, 2012 | Zanussi ZDC5350W Electric Dryer
Zanussi IZ161W Front Load Washer Can you supply this from hot water feed rather than cold water outlet? I intend to use a heat pump which will generate hot water to 40-50DegC cheaply and the HW cylinder...
Not adviseable as you will be rinsing the clothes in hot water as opposed to cold, this could cause problems such as shrinkage depending upon what you are washing at the time.
Dec 09, 2010 | Zanussi IZ161W Front Load Washer
Error E20 showing ........stops during wash cycle and clothes not dry on drying cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Apr 06, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
Nov 14, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
ZDC5350W 'full tank' sensor
Look for the sensor in the tank. If it is a float sensor then check it is not stuck. If it is a probe then clean the insulator.
Oct 06, 2007 | Zanussi ZDC5350W Electric Dryer
ZANUSSI TC7103W
There is a thermostat inside the machine just inside and top, put your head in and look up. Took my whole machine apart before finding the wire which led to it!! It should be Normally Closed (NC) and cuts the power to the heating element when too hot or broken! Hope this helps.
Bolts
Mar 28, 2007 | Zanussi TC7114W Electric Dryer
Zanussi ZDC5350W Electric Dryer Logo
185 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
