Question about MSI K8MM-V Motherboard
Forgot password for bios setting - MSI K8MM-V Motherboard
  • wezz77 Dec 20, 2009
    need acer 5710 HDD PASSWORD
  • 154 Answers
For this issue if you need to fix it with your self you need to follow the instruction from me. First you need to open your unit. Locate where the CMOS battery located.
The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is.
If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
Posted on Oct 08, 2009
    Problem Solver:
  • 9 Answers
For recovering Windows OS Password safely, I strongly recommend softwareWindows Password Reset 9.0 . Not just support XP/Vista/2000/NT, but also compatible with windows 7, it works perfectly to reset Windows login Passwords. I burned it to a USB flash drive. Booting up and clearing my password in 4 minutes. You can Google Windows Password Reset 9.0 or download it from:
http://www.reset-windows-password.com
Posted on Mar 13, 2012
    Scholar:
  • 74 Answers
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Oct 16, 2009
2 Suggested Answers
  • 13433 Answers
SOURCE: set bios password and forgot password :(
There is a bios reset jumper on the motherboard Il check the manual to see where it is, if you have the manual go for it.
Posted on Jun 18, 2008
Forgot the password of bios
try going in setting at start up or usef8 key while powering up
Oct 02, 2012 | Acer Mb.aag06.001 Aspire 1640z & 1650z...
I could not break the BIOS password. I forgot the password.
BIOS passwords can be reset in two ways:
1. using software 2. using hardware.
I would first try resetting using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html
CmosPwd - Cmos password recovery tools
http://www.syschat.com/download121.html&act=down
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
Good Luck!
Jun 28, 2012 | Computers & Internet
Laptop SONY VAIO VPCEB32FM: how to remove BIOS password
The BIOS password is probably the Power On Password.
This method may not work. Remove the BIOS battery for 20 mins until the charge in the BIOS is depleted. Insert the BIOS battery go into the BIOS setting and set the Date and Time etc.
If this does nor work then the BIOS password is stored on an EEPROM chip and removing the BIOS battery won't work and there is probable no backdoor passwords.
The Sony support maybe able to offer a solution, check the support WEB site..
May 23, 2012 | Sony vaio vpceb32fm/w Notebook
It's pretty simple got a computer in Iraq friend thought it would be funny to set bios password then stupid friend forgot password how do I reset password?
Remove the BIOS battery on the motherboard for about an hour then re-insert. The BIOS should revert to its' default setting without a password.
Oct 30, 2010 | Computers & Internet
I forgot the security password
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user password
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Aug 08, 2009 | Acer Aspire 5580 Notebook
Need help forgot password for HP Compaq NX7330
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
Please rate me .
Thanks .
Jul 29, 2009 | HP Compaq nc6320 Notebook
Bios password
try removing the cmos battery. power in on without the battery.
Jul 07, 2009 | IBM ThinkPad T21 Notebook
How do i bypass the primary drive lock password
On the mainboard near the coin battery you'll find a jumper. take it off and reboot. Replace it and reboot again. that works sometimes. If not you can go to the motherboards' BIOS like Phoenix and they have backdoors built in. Read on:
Backdoor passwords Many BIOS manufacturers have provided backdoor passwords that can be used to access the BIOS setup in the event you have lost your password. These passwords are case sensitive, so you may wish to try a variety of combinations. Keep in mind that the key associated to "_" in the US keyboard corresponds to "?" in some European keyboards. Laptops typically have better BIOS security than desktop systems, and we are not aware of any backdoor passwords that will work with name brand laptops.
WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords
Award BIOS backdoor passwords:
[TABLE]
AMI BIOS backdoor passwords:
[TABLE]
PHOENIX BIOS backdoor passwords:
phoenix, PHOENIX, CMOS, BIOS
MISC. COMMON PASSWORDS
[TABLE]
Good luck...hope this helps...
Apr 22, 2009 | Computers & Internet
Bios password acer aspire 9410 Notebook
hi im josh in cebu phils. if the you forgot the password then you can delete or changes it. you go to the bios utility setup then go to security settings then disable or change new password.then save the changes then reboot your pc. bang! problems solved.good luck
Feb 23, 2009 | Acer Aspire 9410-4317 Notebook
MSI K8MM-V Motherboard Logo
522 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
