Question about Coleman Powermate Powermate 5000W Generator
My 10 years colman generator running ... I feed 240V to the main of the house, it used to work OK. But this time, most of my light bulb went bursted after 3-5 min. However, some are not... what has happening?
  • Charles Cronin May 11, 2010
    Did you check the voltage from your Generator?
  • 34 Answers
It sounds alot like it is producing alot more power than 120 volts per leg you should really only have plus or minus 10 percent of that voltage anymore will blow lights check voltage output with meter, if voltage is high may have problem with voltage regulator and it may need be replaced. I assume that not all of the lights in the house are on the same circuit therfore not on the same leg of the generator so is probably only one leg of generated power to high there for only blowing some of the lights
Posted on Oct 10, 2009
Where is the breaker to the oven is it a certain breaker that controls the oven or s it the breaker controls the house like the lights and the TV and the main things that controls the house
The breaker for the over is normally in the main house fuse panel. Be very careful when working on any electrical feed for your oven, that is normally a 240v outlet.
Dec 24, 2014 | Frigidaire Ovens
DLP won't fire up...
Try first unplugging power cord, see if it reset.
Jul 26, 2008 | Samsung HLN437W 43" Rear Projection HDTV
What size generator do you need to run 19100 watts
if you're talking RESISTIVE (like incandescent light bulbs and radiant electric heaters), then you need about a 20KW generator. If you're talking REACTIVE (like electric motors and fluorescent lights), then you need a 40KW to 100KW generator - higher if you're starting all the motors at once, lower if you're stage-starting the motors. If you're talking about a mix of resistive and reactive loads, then you'll need something between 20KW and 100KW depending upon the mix.
If you're talking about MAXIMUM 19100W but realistically only a small part of that load is actually likely to be required at any given moment, then you can use a much smaller generator. For example, my own house has a 100A 240V breaker panel, for a total capacity of 24KW. I can realistically run what I REQUIRE from a 3.5KW generator, though, by intelligent load switching.
Jul 12, 2014 | Electrical Supplies
5000 watt inverter schematics circuit
If you have (90) 50w lamps = 4500 watts total. Assuming a 120/240 panel, if you put 1/2 on one "side" of the panel and the other 1/2 on the other "side" of the panel, that would be 2250 watts on each half. The generator should be rated *at least* 125% of the load; 4500w x 1.25 = 5625W. Using a 4500W generator on this load will cause it to overheat and shorten its life as it is running at 100% of capacity all the time..
One half of the panel is 120V to neutral, and the other is 120V to neutral - or 240V between both circuit breaker terminals. Ohms law for DC circuits and purely resistive AC circuits says Volts x Amps = Watts; or Watts / Volts = Amps. So, 2250W / 120V = 18.75A on each pole of a 2 pole circuit breaker that feeds the sub panel. A #12 copper wire is rated for 20 amps; but as per National Electrical Code - must be de-rated to 80% of rating which means it is good up to 16 amps maximum. A #10 copper wire is rated for 30 amps, but it too must be derated to 80%, making it good for 24 amps maximum. So, if you are going to feed a sub panel supplying (90) 50watt lamps, you will need to run a #10/3 copper cable from a two pole 30 amp circuit breaker at the generator to a 120/240 volt "main lug only" sub panel rated for at least 30 amps.
Divide your load evenly across the sub panel - (4) 15 amps circuits via (2) two pole 15 amp circuit breakers on each "side" of the panel if you run (2) 14/3 cables out to the lights - or (4) single pole 15 amp circuit breakers if you run (4) 14/2 cables out to the lights. No circuit breaker terminal should have more than 23 lamps that means you have (2) w/ 22 lamps and (2) with 23 lamps. The circuit w/ 23 lamps will draw 23 lamps x 50w = 1150W. 1150W / 120V = 9.6A. The 22 lamp load will be 22 x 50w = 1100W. 110W / 120V = 9.2A. Which is well within the 12A maximum allowed (after derating as required by code) by a #14 copper wire rated for 15A.
Mar 10, 2014 | Electrical Supplies
Gnerator has dropped in output
Check the Power output switch is set to 240v. Yours may not have one because you haven't said what make and model of computer the motherboard is in. Incidentally computers don't generally have generators.
Oct 31, 2012 | Computers & Internet
TWIST PLUG
go to an electric supply store and let them know it is a 20 amp plug. The big box stores only have a few selections of plugs
I had the same generator and had to modify the plug to make it fit correctly
Jan 08, 2009 | Coleman Powermate Powermate 5000W...
I have a 5000w colman generator w/ 2 standerd 120v outlets, 1twist 120/240v outlet. the grounding prong goes out all i can find are cords that go in ???
Go to an Electric supply store and tell them it is a 20 amp plug. They should be able to get the correct plug.
I had this generator and had to adjust the prong to make it work.
Coleman Powermate Powermate 5000W Generator Logo
237 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
