I just bought some speakers and a receiver, cd player no instructions, how do i connect it myself
  • 17 Answers
- Use a cinch- cable (red&white) to connect the cd player to the input (often called CD or AUX) of the receiver
- Use standard speaker cable (two copper wires per wire) to connect each speaker to one speaker-output on the receiver
- Plug in the power cables
- Select the right input (or source) on the receiver
- Voila! Press play on the cd player and sound should come out!
Posted on Oct 08, 2009
Setting up the player
The unit definately has to be connected to a receiver with a built in amp, and the speakers will then be connected to the reciever
Jul 13, 2010 | RCA RP8078 5-Disc CD Changer
Connection problems
If the CD player has left and right outputs and the receiver has those inputs for a CD or DVD then there's a start.
Speakers...match them up to positive and negative with no power to either component.
Jun 09, 2009 | Kenwood VR-307 Receiver
Hook up patio speakers and use my cd/dvd/cable/ipod outside only
i'm not sure if this will work, but you could try connecting the rca stereo cables from you cable box to the cd input on the receiver those would be analog. then you could use the music channels at least. as for an ipod maybe sort of the same thing using an av cable instead of the dock;like i said i don't know if it will work but just a thought.
luke
lukeshkin@hotmail.com
Mar 25, 2009 | Onkyo TX-SR504 Receiver
Sony CDP-CX455
This is a player only that requires a receiver or pre-amp/amp combination to drive speakers. The output from this unit is what is called "line level" and can be connected to any CD/DVD/VCR or TAPE input on a receiver.
Dan
Jun 02, 2008 | Sony CDP-CX450 400-Disc CD Changer
Low volume on left channel of Sony STR-GX4ES
The headphone is tapped before the final stage of the amp, so knowing that those work properly helps to isolate the problem. I think that this model uses an IC for the voltage amp section prior to the final amp stage. That being said, the IC is probably an UPC2598 (if memory serves). I'll confirm tonight. Try resoldering any connections that appear to be grainy or have rings. Let me know what you find.
Dan
May 08, 2008 | Audio Players & Recorders
Installing a DEH-P31000 into a 97 Cavalier
grey (-) Driver front
tan (+)
dark green (-) Pass. Front
light green (+)
brown (-) Driver Rear
yellow (+)
dark blue (-) Pass. Rear
light blue (+)
yellow (+) Battery
Black (-) Ground
hope this helps.
Mar 24, 2008 | Pioneer DEH-P2900MP CD Receiver...
No Sound.....
Do you have the speakers connected properly? If Yes check it with a 1,5 Volts batery to hear a click sound at your speakers... You will find the speaker cables behind the cd player.
Aug 10, 2007 | Panasonic CQ-C1121U CD Player
Humming from speakers when CD player running
Yes, The humming is always there you just can hear it better when the cd is playing. The humming is caused by the electrical system in your car. There is an inline filter you can buy and insert it between the car's power source and the head unit. I had a head unit I bought that was absolutly terrible until I installed that filter. Also if you did a do it yourself job on your amp wiring it is usually best practice to run your RCA cables on the opposite side of the car as your power cable. You can also purchase shielded spark plug wires which is a source of noise usually of a different kind tho. First make sure you have a good ground. This means that you have grounded your amp to bare metal not painted metal. If that didn't work put in the inline filter on the head deck as they are only $20 available at radioshack. If that doesn't work, go back an wire your car right this time and put the power and RCA on opposite sides of the car. If you still have that hum it may be the spark plug wires but that sounds more like static than hum. You have a text book case of alternator hum... Hack
Jul 11, 2007 | Xtreme Sound WMS336 CD Player
53 people viewed this question
 Grubhead
Grubhead
