Question about Whirlpool Refrigerators
Refrigerator runs fine and when it shuts off makes a banging sound
  • 4,059 Answers
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Posted on Oct 08, 2009
Testimonial: "quick response. thanks for the advice"
2 Suggested Answers
  • 1218 Answers
SOURCE: my refrigerator GE TBX22ZA makes a
Good day,
On GE products it's referred to as a rattle down. It is internal to the compressor, and short of a new one, little can be done.
They will many times run a long time before failing, even years.
The only thing you can do, is make sure the condenser coils are clean. Vacuuming doesn't always work. You need to unplug the machine, remove the back cover, and blow the coils out from back to front, and then front to back.
Ugly and dirty, but should be done. A good shop vac with a push/pull feature and crevice tool works great, if you don't have a compressed air tank.
Second, make sure the cooling fan by the compressor is running properly, and lastly Make sure you reinstall the back cover completely. IT IS A VITAL PART OF THE MACHINE.
Thank you for using FixYa
Posted on Feb 02, 2010
My refrigerator makes aloud noise
Is it a loud bang noise when the comp shuts off after running?
Aug 05, 2013 | Refrigerators
The GE Profile of 13 years old makes a loud bang sometimes a few times a day after running awhile -- does it mean it is the compressor and time for a new refrigerator or could it be something else -- we...
Good day,
If it makes the clunk or banging noise when the compressor is shutting off, then yes, internal spring or springs inside the compressor have broken.
Only solution to that problem is a new compressor.
P.S. these things can run a long time with this condition, but ultimately .....
Dec 25, 2009 | GE Refrigerators
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
Whirlpool gold makes banging noise
If the refrigerator is working fine the banging noise you hear is the isulation inside the refrigeratior walls that exand and cotract with the change of temperatures. you don t have to worried about it.
Apr 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
Refridgerater shuts off with a bang
When you look at the compressor of a refrigerator, what you see is actually just an outer case. The compressor is inside that case, supported on four springs. If you give a compressor a shake (even a new one) you will hear the inner compressor part knock on the outer case. Sometimes, if a spring brakes or gets weak, when the compressor stops running, the momentum will then cause it to strike the outer case, causing a loud knock or two. Most refrigerators will work fine for many years if this condition occurs. It is a bit annoying, but the only fix would be to replace the compressor, which is generally prohibitively expensive if the unit is no longer in warranty. Please don't bother rating this solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Mar 15, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Kenmore elite refrigerator/freezer loud banging
it is compressor shutting off,not much you can do to fix it.you can try changing the snubbers that hold it in place but most likely you will still hear it clunk.
Mar 07, 2009 | Kenmore Refrigerators
Kenmore fridge with freezer on top/condenser bangs
check rubber mounts on compressor and also make sure fan is clear of anything that could be rubbing it
Dec 17, 2008 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Noisy Fridge!
you need a new compresor that type of work will run you like 4 to 5 G'S you are better off buying a new one. i repl compressors everyday i work for one of the major companys that go to your home to repair refrigerators
Oct 15, 2008 | Refrigerators
Noisy Fridge!
Have you ever cleaned the coil under the refrigerator? If the coil is very dirty the compressor will run very hot and when it finaly shuts off its banging is a sigh of relief. Pull the bottom panel off and vacuum inside as far as u can reach. They also sell brushes for cleaning them.
Apr 08, 2008 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Refrigerators Logo
85 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
