Question about Lexmark X4550 Multifunction Wireless Color Inkjet Printer
How do you change ink - Lexmark X4550 Multifunction Wireless Color Inkjet Printer
  • 662 Answers
To Change the ink Cartridge please follow the instructions as under:
  1. Turn on your computer and open the front cover of your printer.
  2. The Cartridges will automatically come in center.
  3. Pull up the holder lid and carefully remove the print cartridge on a 60 degree angle.
  4. Press the ink cartridges into the slots and listen for a clicking noise after the insertion
  5. Remove the tape from your new print cartridge and carefully put it in on a 60 degree angle, snap the lid back in place. close the printer.
  6. Open the printer software in your computer, click the tab maintenance and click install a new cartridge and click the number. Print an alignment page.That's it !
Thank you for using Fixya
Posted on Oct 08, 2009
  • 105 Answers
Hi this is kamal,
don't try to change ink yourself go to any computer shop and say for catridge riffiling so he wud hardly take minimum amount...
regards
kamal
I dont have any coloured ink cartidges left and need to immediately print some forms in full black will be okay but i cannot change my colours to black as the ink holder stays on the far right of my epson...
To print in all black, you can change a setting through the computer to tell the printer to only use the black ink. This is better than putting black ink where the color ink normally would go as that would cause the shading to be wrong and potentially ruin the documents.
If you have enough black ink in the printer, before you finalize the printing process make sure you have black and white only selected.
This will allow you to print without getting access to the ink cartridge holders.
Good luck hope this helps.
Mar 11, 2011 | Epson PRINTER, 4800 PORTRAIT EDITION...
Ink absorber is full and must be changed. Waste ink absorber is to be changed
You might want to try just resetting your printer rather than changing the ink pad. The warning is based on a count of how much printing is done, not a measure of full the ink pad has become. Consequences of not changing the ink pad, if truly filled to capacity, could be ink leaking from the bottom of the printer.
The following video show how to perform a reset that should work for your printer. The second video will give you an appreciation for how to change an ink pad and help you to decise whether you wish to attempt.
Trust this is helpful.
Dec 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I do not know how to change the black ink on a monolta 2300 ?
http://crm01.konicaminoltaeurope.com/openmind/technic/engineer/qmspubkb.nsf/0/70744652a954e650c1256f820078e0a2/$FILE/MC24x0-Replace%20Toner%20Cartridge.pdf
Goto the above link and it shows the PDF doc. for changing the cartrides.
Jun 23, 2009 | Konica Minolta magicolor 2400 Laser...
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Changing ink carthrige
hi try to clean the contact point of ink and ink carrier.if it's not work 2 thing you need to consider....
1.maybe your ink is not compatible or not detected..
2.maybe your ink carrier is most likely defective.
hope this would help you...
Oct 27, 2008 | HP DeskJet 820cxi InkJet Printer
Ink
with injection purchase the ink from market and use injection to change the ink
Sep 29, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Changing ink in a epson stylus 8400
on the printer push setup, then push ink levels from there you should be able to select the change cartridge and be good to go
WW
Aug 02, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson stylus c66
If your having an error that says "Parts inside the printer are at the end of there Service life" it means that you ink pad is full/ what you can do is change your ink pad and then download an ink pad reset utility so that you can reset the settings/ Make sure to change ink pad before you reset it becuase ink will leak if you don't change it. For the flashing lights, try to check for obstructions inside the printer if not, make sure that ink clicked in and the cover for the tray is closed
Mar 27, 2007 | Epson Stylus C66 Inkjet Printer
Lexmark X4550 Multifunction Wireless Color Inkjet Printer Logo
117 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
