Question about Vizio L32 32 in. LCD HDTV
While the tv is operating it will lose signal for a few seconds and then come back on also there is a black line running vertically on each side of screen about 3 inches wide while operating
  • 291 Answers
The three inch black line is there because your signal is being broadcast as regular definition. Many TV stations and shows are still not being taped in high definition, so they are setup to display in the old aspect ratio. Aspect ratio is basically the width versus height of the display or TV. This is expressed as a ratio, so it will show up as 16:9, 4:3, or some other number ratio. It doesn't mean that your TV is 16" tall by 9" wide, just that it's some multiple of that.
Non HD broadcasts were almost always in the 4:3 ratio, but HDTV is in the 16:9 ratio. This means that if you put a regular definition picture on an HDTV like your Vizio, there is space left at the side, or that you would have to cut off the top and bottom of the picture. Since we don't want to lose the top and bottom, HDTV's are setup to leave the space at the sides. This space is the black band you see on the sides of your TV.
The picture going away for a few seconds is either a weak signal, or interference. Digital TV is different from analog TV in that it's either all there, or it's not. Analog TV would go from a perfect picture to a picture with static, ghosts (or double images), and lines running through the picture. This was because the analog signal could run the complete range from one level to another. In digital, the signal is a series of ones or zeros. The TV then translates that back to the picture you see on your screen. In simple terms, since it sending ones or zeros, if part of the signal is too weak, there is a gap or missing part of the picture. There isn't any static, but if your on the edge of the TV coverage area, sometimes the signal is so weak that it isn't good enough, and there are gaps.
There isn't anythying you can do about the black edges, but you can try a signal amplifier to help out with the times when you lose signal. You can buy an amplifier at Radio Shack or even at Walmart. It doesn't need to be "digital", and if you had an old amplifier it would most likely work fine.
Posted on Oct 08, 2009
Vertical lines showing up after being on for awhile
Eh, I can't be too sure, but it sounds like it's either a heat issue, a signal issue, or a backlight issue. Either way, if it's still under warranty I'd send it in.
May 06, 2013 | Sharp LC60LE835U AQUOS Quattron 60" 3D...
Black vertical line on p42w34p plasma
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Dec 31, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Two vertical black lines on the screen of my ps50b430
Unless someone played with the TV and disconnected the plasma display from the address buffer boards that go under the screen the prospects aren't good.
All vertical lines in all plasma TVs I have seen are operated by chips embedded in the fabric of the display as well.
When they fail they'd either short or burn open.
In the first case they'd prevent the TV from coming up, in the second they'd typically manifest as either black or a random color vertical line like you have.
This is not repairable...sorry.
The odds of this being something else is fairly minimal in my opinion.
Please don't kill the messenger...
bobby @ coppelltvrepair . com
Aug 25, 2012 | Televison & Video
Hello i have a black line runnig across my screen horizontally. Some times disapperar for a few seconds and tv is normal and then comes back. Some tines is black and some times l flashes in red, ...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELPOUT IN SOLVING THE PROBLEM...
May 18, 2011 | Televison & Video
Black vertical line on tv.
defective vertical ic,....no supply...devective yoke.
Jul 01, 2010 | NEC PlasmaSync 42MP3 42 in. Television
I have a 42" Vizio picture has an annoying thick red line
Ur backlight inverter video board is dying.
Need a new one.
Sep 22, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
White Horizontal Lines @ the top of my 32" Sharp Black Box TV
This Problem is usually caused by Leaky Capacitors in Vertical deflection circuit.
If you are handy with electronics,
Get a can of FREEZE Aerosol.
Open the Back Cover.
Put a mirror in front of TV.
Locate the Vertical Circuit.
Turn the TV on.
Spray FREEZE on top of individual Capacitor to see if it corrects the problem.
If it does, Replace that Capacitor.
Feb 06, 2009 | Sharp 32C-240 32" TV
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Screen Smaller on Orion1934" TV
Hello Falken94,
Your TV is losing what is called vertical deflection. This might be caused by the vertical coupling capacitor going bad, or by the vertical deflection coil on the yoke transformer going bad. In any case there is not enough vertical deflection signal getting for the vertical output section of your TV to the vertical coils on the yoke transformer. I would suggest that you get this looked at by a qualified TV technician, due to the nature of this problem.
I hope this helps,
Thank you,
Shuttle83
Jun 19, 2008 | Orion1934 19" TV
Black vertical lines is there a fix
Oct 27, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Vizio L32 32 in. LCD HDTV Logo
54 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
