Question about Sharp AR-5316 Advanced Digital Imager Copier
Code E0004 how to reset it? - Sharp AR-5316 Advanced Digital Imager Copier
    Guru:
  • 389 Answers
You it is necessary to avoid the fault a thermo block, will be a questioning sensor and the temperature and code to faults will not appear. While exists the fault fuse you do not throw the code. He points to the source of the problem. You should apply to service. Given fault there is серъQзная problem for specialist under repair, requires the knowledges and adjustments. Good luck!
Posted on Oct 08, 2009
How to fix the erroe code e0004 in ir canon 6000
press setting/function button then 2&8 same time with two fingers then gain press setting
screen will change to service mode
select mode-copier-function-clear-ok restart machine.
Oct 21, 2016 | Canon Office Equipment & Supplies
Ir 6570 error code e0004 e00103
E004-0103 The IH power supply is faulty/the IH control mechanism is faulty. After correcting the fault, be sure to reset the error. (COPIER>FUNCTION>CLEAR>ERR)
The IH current is faulty. (no current) - Check the connector for any fault in connection. - Replace the fixing heater power supply. - Replace the DC controller PCB.
This link also offers a down loadable pdf service manual.http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR6570
Apr 15, 2015 | Office Equipment & Supplies
I have an ir6570 giving me an error code e0013, e0004 please help
This is an error code dealing with the toner auger motor being bound up. Has the waste toner message been on for along time and the waste toner bottle not being emptied. Sometimes the waste toner counter has been reset several times without the bottle being emptied. This will cause the waste toner to back up in the auger mechanism. Thsi will have to be taken apart ( very tedious job ) and the toner removed from the tube. The auger spring and even some gears may have to be replaced. I've never had to replace the motor on any copier yet. Good Luck.
Sep 07, 2012 | Canon IMAGERUNNER 6570 Copier
E0004-0001
A E0004-0001 is caused by the fuser unit... Have you lost power resently? The code will need to be reset in service mode... Good Luck
Sep 30, 2011 | Canon imageRUNNER C3170U Color Copier
6570 e0004-0106
6570 e0004-0106 pls give solutions for above said problem (error code)
Apr 14, 2011 | Home
E0004-103
This problem is caused by the fuser unit that fuses the ink to the paper. You will need to reset the service error in the service mode before the code will be reset. The procedure for resetting the service error is in the manual but is entered by pressing the * 2+8 buttons together and then * again. Then select FUNCTION - CLEAR - ERR Then exit service and turn the machine off and on and the code should go. If not then replace the thermistor suggestedin the manual for such codes.
You can find the ir5570 service manual here.
Aug 20, 2010 | Canon imageRUNNER 5570 Copier
I am getting an error code E0004 on my np8530 copier
there are a motor sensor does not work properly
Apr 14, 2009 | Canon NP 6050 Copier
E0004 on Canon NP6050
it is a SSR,heater 1 or 2 ,or thermal switch error.   Try to reset,        follow this procedure. SERVICE MODE E004 SSR O FUSER WON´T SHUT OFF
To reset this code use simulation 401
SERVICE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck     CE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck
Oct 24, 2007 | Canon NP 6050 Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
127 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
